Vertical segmentation issue
Information about ongoing ROMS/TOMS applications
MoeinDst
#1 Unread post by MoeinDst »
Hi all.
I'm trying to set-up my apllication in ROMS for different cases.I'm interested in setting-up a test-case in 2D but I receive the error mentioned below. I closed all the lateral boundaries, with constant temperature and salinity all over the domain without any forcing (everything to zero).
Resolution, Grid 01: 572x1198x1, Parallel Threads: 1, Tiling: 1x1
4400 ntimes Number of timesteps for 3-D equations.
30.000 dt Timestep size (s) for 3-D equations.
1 ndtfast Number of timesteps for 2-D equations between
<pre>At line 258 of file wvelocity.f90
Fortran runtime error: Index &apos;2&apos; of dimension 3 of array &apos;z_r&apos; above upper bound of 1
Error termination. Backtrace:
#0 0x7f946c982640 in ???
#1 0x7f946c983185 in ???
#2 0x7f946c98352a in ???
#3 0xf70767 in wvelocity_tile
at /home/moein/myROMS/my_cases/mozambique_channel/mozambique2D/Build_romsG/wvelocity.f90:258
#4 0xf813fc in __wvelocity_mod_MOD_wvelocity
at /home/moein/myROMS/my_cases/mozambique_channel/mozambique2D/Build_romsG/wvelocity.f90:74
#5 0x40f14f in main3d_
at /home/moein/myROMS/my_cases/mozambique_channel/mozambique2D/Build_romsG/main3d.f90:199
#6 0x407132 in __roms_kernel_mod_MOD_roms_run
at /home/moein/myROMS/my_cases/mozambique_channel/mozambique2D/Build_romsG/roms_kernel.f90:178
#7 0x408e54 in myroms
at /home/moein/myROMS/my_cases/mozambique_channel/mozambique2D/Build_romsG/master.f90:88
#8 0x408f8c in main
at /home/moein/myROMS/my_cases/mozambique_channel/mozambique2D/Build_romsG/master.f90:50
<font color="#C01C28"><b>==1650==ERROR: LeakSanitizer: detected memory leaks</b></font></pre>
I know it has something to do with the way I'm defining my vertical levels. However I could not figure it out. I ran the same conditions for my 3D case -started from upwelling case definitions and conditions, changing step by step to get closer to my application- but I fail to do it in 2D. I would appreciate it if you could help me in this regard. I'm also putting here some of the (maybe) useful info:
Tile partition information for Grid 01: 572x1198x1 tiling: 1x1
tile Istr Iend Jstr Jend Npts
0 1 572 1 1198 685256
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 573.50 0.50 1199.50 RHO-points
0 0.00 573.00 0.50 1199.50 U-points
0 0.50 573.50 0.00 1199.00 V-points
Tracer Advection Scheme: NLM
Variable Grid Horizontal Vertical
temp 1 Upstream3 Centered4
salt 1 Upstream3 Centered4
MOZAMBIQUE2D Mozambique 2D case with constant temperature/salinity
ANA_BSFLUX Analytical kinematic bottom salinity flux
ANA_INITIAL Analytical initial conditions
ANA_SMFLUX Analytical kinematic surface momentum flux
ANA_SSFLUX Analytical kinematic surface salinity flux
ANA_STFLUX Analytical kinematic surface temperature flux
ANA_VMIX Analytical vertical mixing coefficients
AVERAGES Writing out time-averaged nonlinear model fields
DIAGNOSTICS_TS Computing and writing tracer diagnostic terms
DIAGNOSTICS_UV Computing and writing momentum diagnostic terms
DOUBLE_PRECISION Double precision arithmetic numerical kernel.
MASKING Land/Sea masking
MIX_S_TS Mixing of tracers along constant S-surfaces
MIX_S_UV Mixing of momentum along constant S-surfaces
NONLINEAR Nonlinear Model
!NONLIN_EOS Linear Equation of State for seawater
PRSGRD31 Standard density Jacobian formulation (Song, 1998)
RHO_SURF Include difference between rho0 and surface density
SALINITY Using salinity
TS_DIF2 Harmonic mixing of tracers
UV_ADV Advection of momentum
UV_COR Coriolis term
UV_QDRAG Quadratic bottom stress
rx0 = 9.895012E-01 (Beckmann and Haidvogel)
rx1 = 9.895012E-01 (Haney)
roms_mozambique2d.in
(154.56 KiB) Downloaded 1302 times
MoeinDst
Re: Vertical segmentation issue
#2 Unread post by MoeinDst »
error:
Fortran runtime error: Index 2 of dimension 3 of array z_r above upper bound of 1
#3 Unread post by wilkin »
You have ...
so you need enough vertical layers for ROMS to be able to compute vertical gradients for such things as vertical mixing and hence to impose surface and bottom stresses, etc.,
If you want a strictly 2-D solution where you are solving the shallow water equations, #undef SOLVE3D.
MoeinDst
#4 Unread post by MoeinDst »
wilkin wrote: Wed Mar 29, 2023 2:26 pm You have ...
maybe I misunderstood the concept, but it was written that if I have temperature in my model, I have to introduce SOLVE3D in the header file! It made sense to not have it in 2D configuration, but I kept facing an error with istvar out of bound 0.
The main issue is that I face the same problem with the roms_canyon test-case. I cannot run it in 2D but if I set some vertical levels and #define SOLVE3D, I'm able to run it. Undefining SOLVE3D to run 2D yields:
At line 1030 of file mod_ncparam.f90
Fortran runtime error: Index '1' of dimension 1 of array 'istvar' above upper bound of 0
This is the part that I don't really get. Even if I run my test without temperature, I receive same error with istvar being out of bound 0. However, if I #define SOLVE3D and set vertical levels, I can run the model.
