[SIGSEGV: Segmentation fault] when running SWAN only
remit
#1 Unread post by remit »
Dear community,
I have managed to compile SWAN and generate a swanM file with the following cpp file settings
#define SWAN_MODEL
but when i do the command:
mpirun -np 1 ./swanM BELAJAR_swan.in
error appears as follows:
 Model Input Parameters:  ROMS/TOMS version 4.1
                          Wednesday - December 7, 2022 - 11:39:25 AM
Backtrace for this error:
#0  0x7f6985cdead0 in ???
#1  0x7f6985cddc35 in ???
#2  0x7f698586751f in ???
#3  0x559cbe062c59 in ???
Primary job  terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun noticed that process rank 0 with PID 0 on node LAPTOP-U4JKE22G exited on signal 11 (Segmentation fault).
I really appreciate the suggestions and solutions..thank you
swanM: https://1drv.ms/u/s!AlaANJ5cRpGZlqVFzwj ... g?e=mhG8AO
BELAJAR_swan.in
(33.53 KiB) Downloaded 772 times
swan_bash.bash
(21.36 KiB) Downloaded 854 times
Re: [SIGSEGV: Segmentation fault] when running SWAN only
this post is about SWAN, and it would best placed on the coawst ticket site
as a short reply, you need to look at any Err* or PRINT* files for more info.
if you are going to follow up, post a new instance on the coawst issues.
