I downloaded the latest version of ROMS3.0 today, and tried to compile it on my Linux workstation using ifort compiler (serial run without MPI). There are error messages caused by "USE netcdf" in mod_netcdf.f90. I compared mod_netcdf.F of the latest version with the previous version, and found that "USE netcdf" is a new statement to replace "#include netcdf.inc" of the older version.
Any suggestion is greatly appreciated.
compiling the latest version of ROMS
ROMS no longer supports the F77 NetCDF interface. You need to compile NetCDF with f90 interface. This is pretty much what everybody does when intalling the NetCDF library which can build both F77 and F90 objects.
This was done to suport NetCDF-4x and parallel IO. See trac ticket:
https://www.myroms.org/projects/src/ticket/47
