Nudging related queries
sun_92
#1 Unread post by sun_92 »
Dear all
I'm trying to use nudging for my simulation. I used the CPP options TCLIMATOLOGY AND TCLM_NUDGING in my header file to activate nudging. I also created the climatology file and nudging coefficients file. Although I'm able to switch on Nudging for Temperature and Salinity, I get the following error while i use nudging for NO3 using the fennel module.
INQUIRY     - unable to assign file counter, Fcount =    0
               while processing structure:
               and variable; NO3
 Found Error: 04   Line: 150      Source: ROMS/Utility/inquiry.F
 Found Error: 04   Line: 130      Source: ROMS/Utility/get_3dfld.F
 Found Error: 04   Line: 1067     Source: ROMS/Nonlinear/get_data.F
 Found Error: 04   Line: 772      Source: ROMS/Nonlinear/initial.F
 Found Error: 04   Line: 188      Source: ROMS/Drivers/nl_ocean.h
Also I have used the following settings in my biofennel.in
LtracerCLM == T F F F F F F F F F F F
! Logical switches (TRUE/FALSE) to nudge the desired biological tracer
! climatology field. If not analytical climatology fields, users need to
! turn on the logical switches above to process the fields from the
! climatology NetCDF file that are needed for nudging; [NBT,Ngrids]
! values are expected. See glossary below for details.
  LnudgeTCLM == T F F F F F F F F F F F
I have also added NO3__NudgeCoef to my NUDNAME.
Any suggestions in this regard will be deeply appreciated
