How to extract all sea surface height data along the lon, lat path
zhaolv
Location: Changsha University of Science and Technology
#1 Unread post by zhaolv »
I have recently been using the "roms_wilkin-master" toolkit. I would like to know how I should extract all the sea surface height data along the lon, lat paths.
So far I have found that the roms_genslice function can extract 4-D data along the path, but how should I get the zeta data?
MIDHILAVARNAV
Re: How to extract all sea surface height data along the lon, lat path
#2 Unread post by MIDHILAVARNAV »
I think you could use the roms_2d slice.m function in the same repository or use secondary software like Ferret (sample_xyt) to extract the data from the post-processed ROMS output data.
#3 Unread post by wilkin »
Just code it yourself using the scatteredInterpolant class:
% some ROMS output
f = 'http://tds.marine.rutgers.edu/thredds/dodsC/roms/doppio/2017_da/his/History_Best';
% get some zeta output
t0 = 1000;
tcount = 100;
zeta = ncread(f,'zeta',[1 1 t0],[Inf Inf tcount]);
% get the lon/lat coordinates
lon = ncread(f,'lon_rho');
lat = ncread(f,'lat_rho');
% construct a scatteredInterpolant class - do this only once because
% lon_rho,lat_rho don't change on subsequent uses of F
tindex = 1;
data = squeeze(zeta(:,:,tindex));
F = scatteredInterpolant(lon(:),lat(:),data(:));
% define the lon,lat path you want to "slice"
N = 100;
lontrk = linspace(-72.5,-70.5,N);
lattrk = linspace(40.0,36.5,N);
% Demo: step through the subset of zeta you downloaded and plot along
% the lon,lat path
for tindex = 1:tcount
  % no need to recompute the scatteredInterpolant for every zeta, just
  % update the Values
  F.Values = data(:);
  % evalute along lontrk,lattrk
  dattrk = F(lontrk,lattrk);
  % plot
  plot(lontrk,dattrk)
  ylim([-1 1])
  drawnow
end
zhaolv
#4 Unread post by zhaolv »
Thank you very much for your guidance, it has helped me a lot
