Hi everyone,
I want to simulate an river plume by inputing only the grid, initial field, river and boundary files, and the boundary file contains a tidal signal,
but I got the error when I ran the ROMS, the log file are described in the below, and the in and h files are added as attachments:
(just output quicksave file)
%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% log%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
nohup: 忽略输入
Wednesday - March 2, 2022 - 5:15:21 PM
Test_tide
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : /opt/software/mpich2-intel/bin/mpif90
Compiler flags : -heap-arrays -fp-model precise -ip -O3 -free -free -free
Input Script :
SVN Revision : 853M
Local Root : /disk3/chenzhixing/ROMS/trunk_853
Header Dir : /disk3/chenzhixing/ROMS/cases/laizhou
Header file : test_tide.h
Analytical Dir: /disk3/chenzhixing/ROMS/cases/laizhou
Resolution, Grid 01: 1054x1094x020, Parallel Nodes: 24, Tiling: 004x006
264840 ntimes Number of timesteps for 3-D equations.
30.000 dt Timestep size (s) for 3-D equations.
86400 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
0 nHIS Number of timesteps between the writing fields
into history file.
120 nQCK Number of timesteps between the writing fields
into quicksave file.
1440 ndefQCK Number of timesteps between creation of new
brief snpashots files.
0 ntsAVG Starting timestep for the accumulation of output
time-averaged data.
0 nAVG Number of timesteps between the writing of
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
0.0000E+00 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
2.5000E-03 rdrg2 Quadratic bottom drag coefficient.
4.0000E+00 theta_s S-coordinate surface control parameter.
8.0000E-01 theta_b S-coordinate bottom control parameter.
5.000 Tcline S-coordinate surface/bottom layer width (m) used
1028.000 rho0 Mean density (kg/m3) for Boussinesq approximation.
20210601.00 time_ref Reference time for units attribute (yyyymmdd.dd)
1.2000E+02 Tnudg(01) Nudging/relaxation time scale (days)
1.2000E+02 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
1.2000E+02 Znudg Nudging/relaxation time scale (days)
1.2000E+02 M2nudg Nudging/relaxation time scale (days)
1.2000E+02 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
6.0000E+01 obcfac Factor between passive and active
T Qout(idFsur) Write out free-surface.
T Qout(idUvel) Write out 3D U-momentum component.
T Qout(idVvel) Write out 3D V-momentum component.
T Qout(idWvel) Write out W-momentum component.
T Qout(idTvar) Write out tracer 02: salt
Output Restart File: /disk3/chenzhixing/ROMS/cases/laizhou/laizhou_rst.nc
Output Averages File: /disk3/chenzhixing/ROMS/cases/laizhou/laizhou_avg.nc
Input Grid File: /disk3/chenzhixing/ROMS/cases/laizhou/laizhou-grid.nc
Input Nonlinear Initial File: /disk3/chenzhixing/ROMS/cases/laizhou/laizhou-ini.nc
Input Boundary File: /disk3/chenzhixing/ROMS/cases/laizhou/laizhou-bry.nc
Tile partition information for Grid 01: 1054x1094x0020 tiling: 004x006
tile Istr Iend Jstr Jend Npts
0 1 263 1 181 952060
1 264 527 1 181 955680
2 528 791 1 181 955680
3 792 1054 1 181 952060
4 1 263 182 364 962580
5 264 527 182 364 966240
6 528 791 182 364 966240
7 792 1054 182 364 962580
8 1 263 365 547 962580
9 264 527 365 547 966240
10 528 791 365 547 966240
11 792 1054 365 547 962580
12 1 263 548 730 962580
13 264 527 548 730 966240
14 528 791 548 730 966240
15 792 1054 548 730 962580
16 1 263 731 913 962580
17 264 527 731 913 966240
18 528 791 731 913 966240
19 792 1054 731 913 962580
20 1 263 914 1094 952060
21 264 527 914 1094 955680
22 528 791 914 1094 955680
23 792 1054 914 1094 952060
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 263.50 0.50 181.50 RHO-points
1 263.50 527.50 0.50 181.50 RHO-points
2 527.50 791.50 0.50 181.50 RHO-points
3 791.50 1054.50 0.50 181.50 RHO-points
4 0.50 263.50 181.50 364.50 RHO-points
5 263.50 527.50 181.50 364.50 RHO-points
6 527.50 791.50 181.50 364.50 RHO-points
7 791.50 1054.50 181.50 364.50 RHO-points
8 0.50 263.50 364.50 547.50 RHO-points
9 263.50 527.50 364.50 547.50 RHO-points
10 527.50 791.50 364.50 547.50 RHO-points
11 791.50 1054.50 364.50 547.50 RHO-points
12 0.50 263.50 547.50 730.50 RHO-points
13 263.50 527.50 547.50 730.50 RHO-points
14 527.50 791.50 547.50 730.50 RHO-points
15 791.50 1054.50 547.50 730.50 RHO-points
16 0.50 263.50 730.50 913.50 RHO-points
17 263.50 527.50 730.50 913.50 RHO-points
18 527.50 791.50 730.50 913.50 RHO-points
19 791.50 1054.50 730.50 913.50 RHO-points
20 0.50 263.50 913.50 1094.50 RHO-points
21 263.50 527.50 913.50 1094.50 RHO-points
22 527.50 791.50 913.50 1094.50 RHO-points
23 791.50 1054.50 913.50 1094.50 RHO-points
0 1.00 263.50 0.50 181.50 U-points
1 263.50 527.50 0.50 181.50 U-points
2 527.50 791.50 0.50 181.50 U-points
3 791.50 1054.00 0.50 181.50 U-points
4 1.00 263.50 181.50 364.50 U-points
5 263.50 527.50 181.50 364.50 U-points
6 527.50 791.50 181.50 364.50 U-points
7 791.50 1054.00 181.50 364.50 U-points
8 1.00 263.50 364.50 547.50 U-points
9 263.50 527.50 364.50 547.50 U-points
10 527.50 791.50 364.50 547.50 U-points
11 791.50 1054.00 364.50 547.50 U-points
12 1.00 263.50 547.50 730.50 U-points
13 263.50 527.50 547.50 730.50 U-points
14 527.50 791.50 547.50 730.50 U-points
15 791.50 1054.00 547.50 730.50 U-points
16 1.00 263.50 730.50 913.50 U-points
17 263.50 527.50 730.50 913.50 U-points
18 527.50 791.50 730.50 913.50 U-points
19 791.50 1054.00 730.50 913.50 U-points
20 1.00 263.50 913.50 1094.50 U-points
21 263.50 527.50 913.50 1094.50 U-points
22 527.50 791.50 913.50 1094.50 U-points
23 791.50 1054.00 913.50 1094.50 U-points
0 0.50 263.50 1.00 181.50 V-points
1 263.50 527.50 1.00 181.50 V-points
2 527.50 791.50 1.00 181.50 V-points
3 791.50 1054.50 1.00 181.50 V-points
4 0.50 263.50 181.50 364.50 V-points
5 263.50 527.50 181.50 364.50 V-points
6 527.50 791.50 181.50 364.50 V-points
7 791.50 1054.50 181.50 364.50 V-points
8 0.50 263.50 364.50 547.50 V-points
9 263.50 527.50 364.50 547.50 V-points
10 527.50 791.50 364.50 547.50 V-points
11 791.50 1054.50 364.50 547.50 V-points
12 0.50 263.50 547.50 730.50 V-points
13 263.50 527.50 547.50 730.50 V-points
14 527.50 791.50 547.50 730.50 V-points
15 791.50 1054.50 547.50 730.50 V-points
16 0.50 263.50 730.50 913.50 V-points
17 263.50 527.50 730.50 913.50 V-points
18 527.50 791.50 730.50 913.50 V-points
19 791.50 1054.50 730.50 913.50 V-points
20 0.50 263.50 913.50 1094.00 V-points
21 263.50 527.50 913.50 1094.00 V-points
22 527.50 791.50 913.50 1094.00 V-points
23 791.50 1054.50 913.50 1094.00 V-points
HaloSizeI(1) = 834
HaloSizeJ(1) = 591
TileSide(1) = 272
TileSize(1) = 51952
ubar 1 Flather Flather Flather Flather
vbar 1 Flather Flather Flather Flather
u 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
v 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
temp 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
salt 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
tke 1 Gradient Gradient Gradient Gradient
TEST_TIDE Test_tide
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
RST_SINGLE Single precision fields in restart NetCDF file.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
Node # 0 (pid= 20873) is active.
Node # 8 (pid= 20881) is active.
Node # 12 (pid= 20885) is active.
Node # 16 (pid= 20889) is active.
Node # 4 (pid= 20877) is active.
Node # 18 (pid= 20891) is active.
Node # 20 (pid= 20893) is active.
Node # 10 (pid= 20883) is active.
Node # 6 (pid= 20879) is active.
Node # 14 (pid= 20887) is active.
Node # 19 (pid= 20892) is active.
Node # 11 (pid= 20884) is active.
Node # 7 (pid= 20880) is active.
Node # 15 (pid= 20888) is active.
Node # 1 (pid= 20874) is active.
Node # 17 (pid= 20890) is active.
Node # 2 (pid= 20875) is active.
Node # 3 (pid= 20876) is active.
Node # 22 (pid= 20895) is active.
Node # 23 (pid= 20896) is active.
Node # 9 (pid= 20882) is active.
Node # 5 (pid= 20878) is active.
Node # 13 (pid= 20886) is active.
Node # 21 (pid= 20894) is active.
20 0.0000000 0.0000000 0.000 0.000 0.000 0.000
19 -0.0500000 -0.0086212 -0.250 -0.250 -0.333 -0.417
18 -0.1000000 -0.0205861 -0.500 -0.500 -0.699 -0.898
17 -0.1500000 -0.0373105 -0.750 -0.750 -1.111 -1.472
16 -0.2000000 -0.0606038 -1.000 -1.000 -1.586 -2.173
15 -0.2500000 -0.0926076 -1.250 -1.250 -2.146 -3.042
14 -0.3000000 -0.1355364 -1.500 -1.500 -2.811 -4.122
13 -0.3500000 -0.1911203 -1.750 -1.750 -3.599 -5.448
12 -0.4000000 -0.2597592 -2.000 -2.000 -4.513 -7.026
11 -0.4500000 -0.3396662 -2.250 -2.250 -5.536 -8.822
10 -0.5000000 -0.4265802 -2.500 -2.500 -6.627 -10.754
9 -0.5500000 -0.5145610 -2.750 -2.750 -7.728 -12.706
8 -0.6000000 -0.5977111 -3.000 -3.000 -8.783 -14.565
7 -0.6500000 -0.6718995 -3.250 -3.250 -9.750 -16.251
6 -0.7000000 -0.7355623 -3.500 -3.500 -10.616 -17.732
5 -0.7500000 -0.7894233 -3.750 -3.750 -11.387 -19.025
4 -0.8000000 -0.8356515 -4.000 -4.000 -12.084 -20.169
3 -0.8500000 -0.8770322 -4.250 -4.250 -12.735 -21.220
2 -0.9000000 -0.9164330 -4.500 -4.500 -13.366 -22.232
1 -0.9500000 -0.9565735 -4.750 -4.750 -14.004 -23.259
0 -1.0000000 -1.0000000 -5.000 -5.000 -14.674 -24.349
37 0.0473537721847153 0.0063819206892258 0.8558961515079423 0.9882658063583315
42 0.0109897377911118 0.0003663245930371 1.0000000000000004 0.9999999999999999
Minimum X-grid spacing, DXmin = 1.22152151E-01 km
Maximum X-grid spacing, DXmax = 1.24165565E-01 km
Minimum Y-grid spacing, DYmin = 1.22154924E-01 km
Maximum Y-grid spacing, DYmax = 1.24164651E-01 km
Minimum Z-grid spacing, DZmin = 2.50000000E-01 m
Maximum Z-grid spacing, DZmax = 1.95233487E+00 m
Minimum barotropic Courant Number = 7.97921689E-02
Maximum barotropic Courant Number = 1.78930152E-01
Maximum Coriolis Courant Number = 2.70245031E-03
NLM: GET_STATE - Read state initial conditions, 2021-06-01 00:00:00.00
(Grid 01, t = 0.0000, File: laizhou-ini.nc, Rec=0001, Index=1)
- free-surface
- u-momentum component
- v-momentum component
- potential temperature
(Min = 0.00000000E+00 Max = 1.98465481E+01)
- salinity
(Min = 0.00000000E+00 Max = 3.01934223E+01)
Image PC Routine Line Source
oceanM 0000000000710094 Unknown Unknown Unknown
oceanM 00000000006FC429 Unknown Unknown Unknown
oceanM 000000000064421A Unknown Unknown Unknown
oceanM 00000000004A01E2 Unknown Unknown Unknown
oceanM 00000000004054CF Unknown Unknown Unknown
oceanM 0000000000404E3D Unknown Unknown Unknown
oceanM 0000000000404D0C Unknown Unknown Unknown
libc.so.6 0000003244A1ED5D Unknown Unknown Unknown
oceanM 0000000000404C09 Unknown Unknown Unknown
nohup: 忽略输入
Test_tide
Input Script :
SVN Revision : 853M
to standard output.
into history file.
time-averaged data.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
HaloSizeI(1) = 834
HaloSizeJ(1) = 591
TileSide(1) = 272
TileSize(1) = 51952
TEST_TIDE Test_tide
- free-surface
- salinity
test_tide.in
- (129.46 KiB) Downloaded 1276 times
test_tide.h
- (1.67 KiB) Downloaded 1236 times
Re: forrtl: severe (174): SIGSEGV, segmentation fault occurred
Recompile your code in debug mode (un-comment the USE_DEBUG line in your build_roms.sh or build_roms.csh), then run your model again with the resulting romsG (instead of romsM or romsS) executable. That will hopefully give you an idea where in the code the segfault is coming from to narrow down the possible causes.
Thanks for your reply, this suggestion is really useful. After modification according to your suggestion, the problem is as follows,
******************** log *********************
forrtl: severe (408): fort: (2): Subscript #2 of the array FRC has value 1 which is greater than the upper bound of -1
oceanG 00000000021A266E Unknown Unknown Unknown
oceanG 00000000021A1106 Unknown Unknown Unknown
oceanG 00000000021553F2 Unknown Unknown Unknown
oceanG 000000000211509B Unknown Unknown Unknown
oceanG 00000000021155B1 Unknown Unknown Unknown
oceanG 00000000014F36CD get_data_ 101 get_data.f90
oceanG 000000000071DDAE initial_ 274 initial.f90
oceanG 0000000000406260 ocean_control_mod 130 ocean_control.f90
oceanG 0000000000404F00 MAIN__ 95 master.f90
oceanG 0000000000404D2C Unknown Unknown Unknown
oceanG 0000000000404C29 Unknown Unknown Unknown
How can we fix this problem?
The error occurs in get_data, so there is something wrong with one of your netcdf forcing files.
Look in get_data.f90 at what ROMS is reading at when the error occurs, and fix that file.oceanG 00000000014F36CD get_data_ 101 get_data.f90
"forrtl: severe (408): fort: (2): Subscript #2 of the array FRC has value 1 which is greater than the upper bound of -1"
i looked in your ocean.in and you have:
!NFFILES = 1 ! number of unique forcing files
!FRCNAME == /disk3/chenzhixing/ROMS/cases/laizhou/laizhou-frc.nc ! forcing file 1, grid 1
depending on your compiler and version of the code, it may need to read these values even if they are not used.
so uncomment them and try again:
Thanks for your reply. I annotated these two lines because there is no frc file when using ROMS
Sincerely thank you, I will carefully read the get_data.f90. Does this 101 stand for line 101 in get_data.f90 ?wilkin wrote: Sat Mar 05, 2022 1:07 pm The error occurs in get_data, so there is something wrong with one of your netcdf forcing files.
You don't have any ANA_* functionals defined for forcing (wind stress, heat flux etc.), so ROMS is trying to read those from a forcing netcdf file. Even if you want zero forcing, you need to set how that is implemented. The default ANA_SMFLUX for example will set stresses to zero. But you have to define it.... I annotated these two lines because there is no frc file when using ROMS
Thank you very much. I'll give it a try.
When I build and run roms standalone , everything gose well. But If I mpirun oceanG after build ROMS coupled with CICE (i.e. the METROMS https://github.com/metno/metroms), it turned forrtl: severe (174): SIGSEGV, segmentation fault occurred.robertson wrote: Fri Mar 04, 2022 5:33 pm Recompile your code in debug mode (un-comment the USE_DEBUG line in your build_roms.sh or build_roms.csh), then run your model again with the resulting romsG (instead of romsM or romsS) executable. That will hopefully give you an idea where in the code the segfault is coming from to narrow down the possible causes.
Could you please help me out ? I have tried many ways but still not solved it. I have upload my output log file and in file:
https://github.com/joeailvyou/METROMS-output-log
Even in debug mode (but coupled to CICE), the error is not detail enouth:
oceanG 00000000012153C1 Unknown Unknown Unknown
oceanG 0000000001213B17 Unknown Unknown Unknown
libmpi.so.12 00002AF06FB10762 Unknown Unknown Unknown
libmpi.so.12 00002AF06FB105B6 Unknown Unknown Unknown
libmpi.so.12 00002AF06FAFEE1C Unknown Unknown Unknown
libmpi.so.12 00002AF06FAE07C8 Unknown Unknown Unknown
libpthread.so.0 00002AF07015B5E0 Unknown Unknown Unknown
oceanG 0000000000FD44A8 Unknown Unknown Unknown
oceanG 0000000000FD156C Unknown Unknown Unknown
oceanG 0000000000FBC6FC Unknown Unknown Unknown
oceanG 0000000000F13600 Unknown Unknown Unknown
oceanG 0000000000408403 MAIN__ 106 master.f90
oceanG 0000000000406DCE Unknown Unknown Unknown
libc.so.6 00002AF07058DC05 Unknown Unknown Unknown
oceanG 0000000000406CD9 Unknown Unknown Unknown
libmpi.so.12 00002B8F2D10F762 Unknown Unknown Unknown
libmpi.so.12 00002B8F2D10F5B6 Unknown Unknown Unknown
libmpi.so.12 00002B8F2D0FDE1C Unknown Unknown Unknown
libmpi.so.12 00002B8F2D0DF7C8 Unknown Unknown Unknown
libpthread.so.0 00002B8F2D75A5E0 Unknown Unknown Unknown
libc.so.6 00002B8F2DB8CC05 Unknown Unknown Unknown
real 0.49
user 5.06
sys 5.64
