The code is compiled in serial mode with ifort, USE_DEBUG and USE_NETCDF4.
At the end of the year, when ROMS is ready to switch to the next BRY file, it enters this block of inquiry.F:
! If multi-files, increase (decrease if backward logic) file counter
! and set new file names.
IF (Lmulti) THEN
DO ifile=1,nfiles
IF (TRIM(Cinfo(ifield,ng)).eq.TRIM(S(ifile)%name)) THEN
IF (job.gt.0) THEN
Fcount=S(ifile)%Fcount+1
ELSE
Fcount=S(ifile)%Fcount-1
IF ((1.gt.Fcount).and.(Fcount.gt.S(ifile)%Nfiles)) THEN
IF (Master) THEN
WRITE (stdout,10) TRIM(Vname(1,ifield)), &
& Fcount, S(ifile)%Nfiles
exit_flag=4
IF (FoundError(exit_flag, NoError, &
& __LINE__, MyFile)) RETURN
S(ifile)%Fcount=Fcount
S(ifile)%name=TRIM(S(ifile)%files(Fcount))
CALL netcdf_close (ng, model, ncid)
The 5th argument (not present here) is a logical variable called "Lupdate".
The call to netcdf_close leads to the following block of mod_netcdf.F:
#ifdef BIOLOGY
! Determine updating value of biology header files global attribute.
! This is only possible in output files. An error occurs in input
! files open for reading only. This allows to use ROMS input files
! with the "bio_file" attribute.
IF (.not.PRESENT(Lupdate)) THEN
my_Lupdate=.TRUE.
ELSE
my_Lupdate=Lupdate
! Update global attribute with the biology header files used.
IF (my_Lupdate) THEN
is=1
DO i=1,512
bio_file(i:i)=' '
DO i=1,4
lstr=LEN_TRIM(BIONAME(i))
IF (lstr.gt.0) THEN
ie=is+lstr-1
bio_file(is:ie)=TRIM(BIONAME(i))
is=ie+1
bio_file(is:is)=','
is=is+2
lstr=LEN_TRIM(bio_file)-1
IF (lstr.gt.0) THEN
status=nf90_put_att(ncid, nf90_global, 'bio_file', &
& bio_file(1:lstr))
NETCDF_CLOSE - error while writing global attribute: bio_file
file:
call from: ROMS/Utility/inquiry.F, inquiry_nf90
NetCDF: Write to read only
Lupdate=.FALSE.
in the call to netcdf_close? It would prevent ROMS from trying to modify the BRY file when BIOLOGY is activated.
