Adding a river runoff in simulation
mmonim
#1 Unread post by mmonim »
Dear ROMS users,
I am trying to add a river source in my simulation but it is not working. I think I am not understanding the steps or missing something in the process. I was trying to implement it by defining the CPP option described here - https://www.myroms.org/wiki/River_Runoff
Here are the steps I am taking -
1. Specifying the Isrc (6), Jsrc (60), Dsrc (river flowing through the right-sided u face of the cell), Nsrc (one river source), and Qbar (30m3/s) in the ana_psource.h file -
#if defined RIVERPLUME1
IF (Master.and.DOMAIN(ng)%SouthWest_Test(tile)) THEN
Nsrc(ng)=1
SOURCES(ng)%Dsrc(Nsrc(ng))=0.0_r8
SOURCES(ng)%Isrc(Nsrc(ng))=6
SOURCES(ng)%Jsrc(Nsrc(ng))=60
IF ((tdays(ng)-dstart).lt.0.5_r8) THEN
fac=1.0_r8+TANH((time(ng)-43200.0_r8)/43200.0_r8)
ELSE
fac=1.0_r8
DO is=1,Nsrc(ng)
SOURCES(ng)%Qbar(is)=fac*34.0_r8
For Qshape, I have not changed anything in the file.
I am not sure if it is a good idea to specify the parameters under RIVERPLUME1 but could not come up with a better idea
2. Before building the executable I added the following in my header file -
# define ANA_PSOURCE
# define RIVERPLUME1
3. In my .in file I turned the logical switch on for horizontal momentum transport
LuvSrc == T ! horizontal momentum transport
LwSrc == F ! volume vertical influx
LtracerSrc == F F ! temperature, salinity, inert
I used F for salinity and temperature as tracer sensitivity is not required for my simulation.
The model runs with these changes but I don't see any u component through the cell where I specified the river source. My question is what is wrong with the aforementioned steps and what am I missing to make the river source work. Also if I want to add multiple source points using horizontal momentum transport, where and how in ana_psource.h (and the header file) I should make the changes. I would really appreciate it if you could share an example of the header file and ana_psource.h to help me understand.
Best,
Mahmud
Re: Adding a river runoff in simulation
i just downloaded the code the other day, and the RIVERPLUME1 test case worked fine for me.
give that a try.
i dont understand if you are using RIVERPLUME1 or trying to use that as a guide.
if it is a guide, then you need to define your own application in ana_psource and copy those lines of code to that section. for example:
#ifdefined RIVERPLUME1
#elif defined MYAPPNAMEHERE
#3 Unread post by wilkin »
Is it possible you have placed your source in the land? In the wiki notes ...
When using option LuvSrc = T, river_Xposition and river_Eposition refer to the i,j index of the u-face or v-face the flow crosses - NOT the i,j index of the rho cell it flows into. The i,j values must follow ROMS Fortran numbering convention for the appropriate u-point or v-point on the ROMS staggered grid.
u and v cells do not number starting at (1,1).
