typo in mod_arrays.F and missing in read_phypar.F?
mjfconan
#1 Unread post by mjfconan »
(1) mod_arrays.F
Line 67
     &                         deallocate_seabed,                       &
Line 266
                          CALL allocate_sedbed (ng)
should be
     &                         deallocate_sedbed,                       &
                         CALL deallocate_sedbed (ng)
(2) read_phypar.F
Block of "#ifdef AVERAGES" from line 4095
Line 4097
          OutFiles=ntimes(ng)/ndefAVG(ng)
should add the same process as other blocks:
          IF ((nAVG(ng).eq.ndefAVG(ng)).or.                             &
     &        (MOD(ntimes(ng),ndefAVG(ng)).ge.nAVG(ng))) THEN
            OutFiles=Outfiles+1
Re: typo in mod_arrays.F and missing in read_phypar.F?
Thank you for bringing this to my attention. I agree with the correction to mod_arrays.F. Now, I need to think about the issue with the AVERAGES files and also the DIAGNOSTICS files in read_phypar.F. They are special since the creation of the time-averaged files is delayed due to the time-averaging. I will have to look at this at the debugger and test it.
carlosag
#3 Unread post by carlosag »
Thank you. I am brand new in this community and I am still leaning the to do's and the don't, as well as the generalities. The typo in read_phypar.F was accepted or is it still under review?
All best and thank you.
#4 Unread post by arango »
Yes, I updated the repository but I rejected the changes to read_phypar.F. As I mentioned above, the suggested change is not needed because the time-averaged NetCDF files activated with AVERAGES and DIAGNOSTICS options are special.
The user Jianfei Ma didn't provide enough information as to why the change was needed. That logic is delicate and I looked in the debugger for issues. The multi-file logic is correct for the delayed I/O. I suspect that the user has inconsistent values for NTIMES, NAVG, and NDEFAVG in the standard input file roms.in. They must be exact integer multiples of each other for the time-averaging to work correctly!
mjfconan
#5 Unread post by mjfconan »
Thanks! Sometimes, my NTIMES is not integer multiples of NDEFAVG, which causes the problem. :shock:
Moreover, when I checked the output.F, it says:
Line 399-402
        IF (((iic(ng).gt.ntstart(ng)).and.                              &
     &       (MOD(iic(ng)-1,nAVG(ng)).eq.0)).or.                        &
     &      ((iic(ng).ge.ntsAVG(ng)).and.(nAVG(ng).eq.1))) THEN
          CALL wrt_avg (ng, tile)
Why dose the 1st condition use ntstart(ng) not ntsAVG(ng)? such as:
        IF ((iic(ng).ge.ntsAVG(ng)).and.                              &
     &       ((MOD(iic(ng)-1,nAVG(ng)).eq.0).or.(nAVG(ng).eq.1))) THEN
The old one seems to write out every AVG field from the first NAVG step, but without a correct ocean_time until ntsAVG step.
