Error to compile WRF+SWAN
manhnt181
#1 Unread post by manhnt181 »
Hi everyone,
I'm compiling COAWSTv3.7 model with WRF+SWAN option, I got the error like that:
get_wrf_moving_grids.f90(49): error #6404: This name does not have a type, and must have an explicit type.   [A2ONAME]
            nc_name=A2Oname(ia,1)
get_wrf_moving_grids.f90(49): error #6054: A CHARACTER data type is required in this context.   [A2ONAME]
compilation aborted for get_wrf_moving_grids.f90 (code 1)
make: *** [Build/get_wrf_moving_grids.o] Error 1
The log file of compiling process and the project file are attached in the below.
Please help me to resolve this problem.
Thanks all,
Bests,
Manh
sandy.h.txt
(2.22 KiB) Downloaded 731 times
build.log.txt
(1.49 MiB) Downloaded 714 times
Re: Error to compile WRF+SWAN
ok. so you have set
#undef ROMS_MODEL
#undef NESTING
#define WRF_MODEL
#define SWAN_MODEL
#undef WW3_MODEL
#define MCT_LIB
#define MCT_INTERP_OC2AT
#define MCT_INTERP_WV2AT
#define MCT_INTERP_OC2WV
if you only use swan and wrf, then you do not need INTERP_OC2AT or INTERP_OC2WV
so set this as
#undef ROMS_MODEL
#undef NESTING
#define WRF_MODEL
#define SWAN_MODEL
#undef WW3_MODEL
#define MCT_LIB
#undef MCT_INTERP_OC2AT
#undef MCT_INTERP_OC2WV
and recompile. I am working to remove those flags, but they are needed for now.
if you have more troubles, since this is the coupled system, please post an issue here:
thanks,
john
