Dear ROMS users,
after compiling build_roms.csh in the test/WC13/RBL4DVAR directory, I get the error below
rbl4dvar.f90(542): error #6404: This name does not have a type, and must have an explicit type. [ISFSUR]
IF (balance(isFsur)) THEN
compilation aborted for rbl4dvar.f90 (code 1)
make: *** [/homes/DMA/CCRLB93M/mydir/Build_roms/rbl4dvar.o] Error 1
Could you help me to fix this problem?
Thank you very much!
WC13/RBL4DVAR PROBLEM
Re: WC13/RBL4DVAR PROBLEM
Yes, this was fixed but that version is not ready for release. You have to wait. This is simply solved by deactivating the BALANCE_OPERATOR C-preprocessing option. We don't activate that option in the tutorials. The balance operator is an advanced feature for experienced users that know their application well because the bathymetry affects the level-of-no-motion that is needed in the inverse problem.
- Location: Università degli studi di Napoli "Federico II"- Co
Thank you!
Thank you again for your response.
Now I’m considering RBL4D-Var with RPCG subject to the weak constraint. I edited build_roms.csh and chose the following cpp options
setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DRBL4DVAR"
setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DRPCG"
setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DTIME_CONV”.
I edited roms_wc13_2hours.in to indicate that the weak constraint will be used (i.e. NADJ =48 ).
Then, I run WC13/RBL4DVAR subject to the weak constraint and I get the error below:
TIME_CORR - error while writing variable: ubar at time record = 5
into NetCDF file: /homes/DMA/CCRLB93M/ex4_RBL4DVAR_weak/ex1_2hours/wc13_tlf.nc
Found Error: 03 Line: 617 Source: ROMS/Utility/convolve.F, error_covariance
Found Error: 03 Line: 1218 Source: ROMS/Drivers/rbl4dvar.F, increment
Found Error: 03 Line: 305 Source: ROMS/Drivers/rbl4dvar_ocean.h, ROMS_run
Found Error: 03 Line: 119 Source: ROMS/Utility/stats_modobs.F
Could you give me some advice ?
Hi there,
did you manage to fix this issue? I am running into the same problem.
All best and thank you
