Increase Bottom Vertical Grid Resolution
osean
#1 Unread post by osean »
Hello ROMS experts
I am currently looking for a way to modify the vertical grid scheme so that I can have increased bottom vertical grid numbers to resolve the bottom mixed layer, for example. Ideally, I would like to have a grid that has high resolution for the surface mixed layer and the bottom mixed layer, with relatively sparse points in the interior.
So I thought of starting with a vertical grid scheme similar to that of the UPWELLING case, with a seemingly exponential increase in grid spacing from the surface to the bottom. Then I would like to modify it so that I can have an exponential decrease in grid spacing from the middle of the interior to the bottom. In that case, I can have a vertical grid that have high resolution near the surface and the bottom, but with a relatively low resolution in the interior.
Now I wonder how to proceed with such a change? I looked through the ROMS manual (2018 version) and files in trunk folder, but achieved little success. Perhaps I am missing out something obvious, or due to my poor ability to disentangle the information in the code. From the manual, I found the following initial set-up files are associated with the grid:
>> ana_grid Compute the grid(s) internally.
>> get_grid Read in the curvilinear coordinate arrays as well as f and h from one NetCDF file per grid.
>> mod_grid.F This provides the storage for the model grid fields.
These appear to be relevant. So I went into the \trunk file in the ROMS folder, and I went through ana_grid.h, it doesn’t show where I can modify the vertical grid spacing/scheme. So I feel mod_grid.F might be where the information is hidden, but I can't quite figure out where it is embedded within the code (if it is).
Appreciate any advice on how to proceed with this! many thanks
Re: Increase Bottom Vertical Grid Resolution
here is a good start:
https://www.myroms.org/wiki/Vertical_S-coordinate
there is also an m file "roms_getnplot_grid_rutgers" that you can use to see what an adjustment to the various parameters will do to the vertical stretching.
osean
#3 Unread post by osean »
jcwarner wrote: Mon Apr 12, 2021 5:08 pm here is a good start:
Oh this is very helpful, thank you!
c.drinkorn
#4 Unread post by c.drinkorn »
HI Osean,
our application has a vertical grid like the one you are aiming at. We achieved this with the vertical transformation formulation 2 and the vertical stretching formulation 3 with theta_b = 1.5 and theta_s = 1.0. Our vertical resolution ranges from 0.3m in places at the bottom and surface to 240m in the interior. To "stabilize" this a bit we set Tcline = 100.
But I also encourage you to read about the s-coordinate like suggested by John. It's definitely worth understanding what's happening! :) Good luck!
Cate
osean
#5 Unread post by osean »
c.drinkorn wrote: Tue Apr 13, 2021 8:38 am HI Osean,
Cate
Hi Cate,
Thank you!! This is very helpful. I tried to configure with the default Vtransform == 2 and Vstretching == 4, but my best attempt so far could only get me down to approx. 12 m resolution at the bottom. I will attempt your values.
