Error to create the ww3partition_2TPAR
manhnt181
#1 Unread post by manhnt181 »
Hi everyone,
I have a problem which related to create the ww3partition_2TPAR data by using the ww3_swan_input.m program.
I can run this program successfully with the data before 2018, however I got this error immediately when using the date of 2018.
The error is displayed in the below:
Error using fgets
Invalid file identifier. Use fopen to generate a valid file identifier.
Error in fgetl (line 32)
[tline,lt] = fgets(fid);
Error in ww3partition_2TPAR (line 22)
tline = fgetl(fid);
Error in ww3_swan_input (line 76)
ww3partition_2TPAR(partfile,specpts,yearww3,mmww3)
This is my ww3_swan_input.m program:
setup_nctoolbox
% script ww3_swan_input.m
% This script is the main driver to
% download, convert and interpolate WW3 data to TPAR input for SWAN.
% Written 4/23/09 by Brandy Armstrong
% some mods, jcwarner Arpil 27, 2009
% added partition file call, jcw, 04Feb2019
% First, acquire the necessary grib, ascii (gz), or nc files from
% ftp://polar.ncep.noaa.gov/pub/history/waves/
% ************* BEGIN USER INPUT   ****************************
% 1) Enter WORKING DIRECTORY.
% This is the location of ww3 files downloaded and the
% location of output for the forcing files to be created.
working_dir='E:\Matlab'
% 2) Enter start dates of data requested.
yearww3='2018';    %input year of data yyyy
mmww3='09';        %input month of data mm
ddww3='00';        %keep this as '00'
% flag for simulations that span several months.
% 0 = one month, 1 = more than one month
% This long run flag is only coded for TPAR files for now.
long_run=0;
if long_run
    total_number_months=1; % total number of months
                        % (not the length of the run, but rather the number
                        % of ww3 files)
end
% 3) Enter path\name of SWAN grid. This is set up to use the roms grid as the same for swan.
modelgrid='E:\Matlab\ROMS_COAWST_grd1.nc';
% 4) Enter the spacings of the forcing file locations around the perimeter
% of the grid. One forcings file spans between the 'specres' points.
specres=20; % spec point resolution
% 5)
% Here you decide to use gridded field output (to make TPAR) or spectral partition data (to make 2Dspec). Read this:
% ftp://polar.ncep.noaa.gov/pub/history/waves/multi_1/00README
% Pick one of these:
use_field_output=0;     % will create TPAR files.
use_partition_data=1;   % will create 2D spec files.
if (use_field_output)
  % Enter the ww3 grid area
  ww3_area='multi_1.glo_30m';    %western north atlantic
end
if (use_partition_data)
  % Enter name of wave watch 3 partition file
  partfile='multi_1.partition.glo_30m.201809';
end
% *************END OF USER INPUT****************************
eval(['cd ',working_dir,';']);
% call to get the spectral points
[specpts]=ww3_specpoints(modelgrid,specres);
if ~long_run
    % Call routine to compute TPAR files.
      ww3gb_2TPAR(modelgrid,yearww3,mmww3,ww3_area,ddww3,specpts)
    end
    end
    % After creating the TPAR files, tell the user what info is needed to
    % be added to INPUT file.
    % Write out boundary file lines for INPUT file
    bdry_com %script writes out file Bound_spec_command to working directory
    display('BOUNDSPEC command lines can be found in the file Bound_spec_command');
    display('You must copy the lines from that file into your SWAN INPUT file');
else
    eval(['!mkdir ',yearww3,mmww3])
    eval(['!mv TPAR*.txt ',yearww3,mmww3,'/.'])
    for im=1:total_number_months-1
        yymm=datestr(datenum(str2double(yearww3),str2double(mmww3)+im,1),'yyyymm');
        eval(['!mkdir ',yymm])
        ww3gb_2TPAR(modelgrid,yymm(1:4),yymm(5:6),ww3_area,ddww3,specpts)
        eval(['!mv TPAR*.txt ',yymm,'/.'])
    end
    D=dir([yearww3,mmww3,'/TPAR*.txt']);
    dn={D.name}';
    [y,i]=sort(dn);
    D=D(i);
    for itp=1:length(D)
        data=[];
        [pfid,message]=fopen([yearww3,mmww3,'/',D(itp).name]);
        tline = fgetl(pfid);
        while 1
            if ~ischar(tline), break, end
            data=[data;str2num(tline)];
        end
%         dum=fgets(pfid);
%         data=fscanf(pfid,'%f %f %f %f %f',[5 inf])';
%         C=textscan(pfid,'','headerlines',1);
%         if ~isempty(find(isnan(C{3}),1))
%             C=textscan(pfid,'%f%f%f%f.%f','headerlines',1);
%         end
%         data=cell2mat(C);
        fclose(pfid);
            [pfid,message]=fopen([yymm,'/',D(itp).name]);
            while 1
            end
            fclose(pfid);
        end
        [CA,IA,IC] = unique(data(:,1));
        data=data(IA,:);
        [pfid,message]=fopen(D(itp).name,'w');
        fprintf(fid,'TPAR \n');
        fprintf(pfid,'%8.4f %3.2f %3.2f %3.f. %2.f\n',data');
        fclose(pfid);
    end
end
Please help me to fix this problem.
Thanks in advance!
Re: Error to create the ww3partition_2TPAR
can you please post this message on the coawst forum:
thanks, -j
