i4dvar ex1 blowup at first time step
briskbamboo
#1 Unread post by briskbamboo »
Dear
I am studying I4dvar and trying to run it's exercises. After compiled the model I run with the default in file "roms_wc13_2hours.in" The model blow up at first time step with log file
log_dt1800.txt
(82.13 KiB) Downloaded 1072 times
As other has suggested that I can reduce the timestep to pass this case problem then I try to smaller time step from 1800 to 180 then the model blow up at the second steps with the log file
log_dt180.txt
(82.44 KiB) Downloaded 1048 times
My input file is
roms_wc13_2hours.txt
(142.95 KiB) Downloaded 999 times
I have already read 3 papers and the tutorial files related to 4dvar recommended by the guide but found no information about this case of blow up with it default setting.
