NETCDF PROBLEM WHEN RUNNING MODEL
javadi
#1 Unread post by javadi »
Dear users
I have faced an error when running upwelling_test case which is related to Netcdf. Here are the details of this error.
Please help me with your interesting comments.
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler flags : -frepack-arrays -O3 -ffast-math -O3 -ffast-math -
GIT Root URL : https://github.com/kshedstrom/roms.git
GIT Revision : kate_svn commit 45632fb01be13aae698d6c1fa99a666bfc3b4d19
Git Status : The working tree is DIRTY with 1 changes
SVN Root URL :
SVN Revision :
Local Root : /home/javadbabagoli/Documents/roms
Header Dir : /home/javadbabagoli/Documents/Test
Header file : upwelling.h
Analytical Dir : /home/javadbabagoli/Documents/Test
Resolution, Grid 01: 41x80x16, Parallel Threads: 1, Tiling: 1x1
into restart fields.
to standard output.
into history file.
into quicksave file.
time-averaged data.
72 nAVG Number of timesteps between the writing of
72 nDIA Number of timesteps between the writing of
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
for tracer 02: salt
9.0000E+01 Tnudg_SSS Nudging/relaxation time scale (days)
for sea surface salinity.
for 3D momentum.
of State.
T Hout(idStr) Write out strain.
T Hout(id3dPV) Write out potential vorticity.
T Hout(id3dPVK) Write out k component of potential vorticity.
T Hout(id3dPVJ) Write out j component of potential vorticity.
T Hout(id3dPVI) Write out i component of potential vorticity.
T Dout(M2rate) Write out 2D momentum acceleration.
T Dout(M2pgrd) Write out 2D momentum pressure gradient.
T Dout(M2fcor) Write out 2D momentum Coriolis force.
T Dout(M2hadv) Write out 2D momentum horizontal advection.
T Dout(M2xadv) Write out 2D momentum horizontal X-advection.
T Dout(M2yadv) Write out 2D momentum horizontal Y-advection.
T Dout(M2hvis) Write out 2D momentum horizontal viscosity.
T Dout(M2xvis) Write out 2D momentum horizontal X-viscosity.
T Dout(M2yvis) Write out 2D momentum horizontal Y-viscosity.
T Dout(M2sstr) Write out 2D momentum surface stress.
T Dout(M2bstr) Write out 2D momentum bottom stress.
T Dout(M3rate) Write out 3D momentum acceleration.
Output Restart File: roms_rst.nc
Output History File: roms_his.nc
Output Averages File: roms_avg.nc
Output Diagnostics File: roms_dia.nc
ROMS I/O variables Metadata File: varinfo.dat
Tile partition information for Grid 01: 41x80x16 tiling: 1x1
tile Istr Iend Jstr Jend Npts
Number of tracers: 2
0 1 41 1 80 52480
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 -1.50 42.50 0.50 81.50 RHO-points
0 -2.00 42.00 0.50 81.50 U-points
0 -1.50 42.50 0.00 81.00 V-points
Tracer Advection Scheme: NLM
Variable Grid Horizontal Vertical
temp 1 Upstream3 Centered4
salt 1 Upstream3 Centered4
Akima4 Fourth-order Akima advection
Centered2 Second-order centered differences advection
Centered4 Fourth-order centered differences advection
HSIMT Third High-order Spatial Inteporlation at Middle Time Advection with TVD limiter
MPDATA Multidimensional Positive Definite Advection Algorithm, recursive method
Splines Conservative Parabolic Splines Reconstruction Advection (only vertical; not recommended)
Split_U3 Split third-order Upstream Advection
Upstream3 Third-order Upstream-biased Advection (only horizontal)
zeta 1 Periodic Closed Periodic Closed
ubar 1 Periodic Closed Periodic Closed
vbar 1 Periodic Closed Periodic Closed
u 1 Periodic Closed Periodic Closed
v 1 Periodic Closed Periodic Closed
salt 1 Periodic Closed Periodic Closed
ANA_BSFLUX Analytical kinematic bottom salinity flux
ANA_GRID Analytical grid set-up
ANA_INITIAL Analytical initial conditions
ANA_SMFLUX Analytical kinematic surface momentum flux
ANA_SSFLUX Analytical kinematic surface salinity flux
ANA_STFLUX Analytical kinematic surface temperature flux
ANA_VMIX Analytical vertical mixing coefficients
AVERAGES Writing out time-averaged nonlinear model fields
DIAGNOSTICS_TS Computing and writing tracer diagnostic terms
DIAGNOSTICS_UV Computing and writing momentum diagnostic terms
DJ_GRADPS Parabolic Splines density Jacobian (Shchepetkin, 2002)
DOUBLE_PRECISION Double precision arithmetic numerical kernel
MIX_S_TS Mixing of tracers along constant S-surfaces
MIX_S_UV Mixing of momentum along constant S-surfaces
NONLINEAR Nonlinear Model
!NONLIN_EOS Linear Equation of State for seawater
SALINITY Using salinity
SPLINES_VDIFF Parabolic Spline Reconstruction for Vertical Diffusion
SPLINES_VVISC Parabolic Spline Reconstruction for Vertical Viscosity
TS_DIF2 Harmonic mixing of tracers
UV_ADV Advection of momentum
UV_COR Coriolis term
UV_LDRAG Linear bottom stress
Process Information:
Thread # 0 (pid= 17814) is active.
ANA_GRID - x-location of PSI-points: x_psi
(Grid = 01, Min = 0.00000000E+00 Max = 4.00000000E+04)
ANA_GRID - y-location of PSI-points: y_psi
(Grid = 01, Min = 0.00000000E+00 Max = 8.00000000E+04)
ANA_GRID - x-location of RHO-points: x_rho
(Grid = 01, Min = 5.00000000E+02 Max = 4.05000000E+04)
ANA_GRID - y-location of RHO-points: y_rho
(Grid = 01, Min = -5.00000000E+02 Max = 8.05000000E+04)
ANA_GRID - x-location of U-points: x_u
ANA_GRID - y-location of U-points: y_u
ANA_GRID - x-location of V-points: x_v
ANA_GRID - y-location of V-points: y_v
ANA_GRID - reciprocal XI-grid spacing: pm
(Grid = 01, Min = 1.00000000E-03 Max = 1.00000000E-03)
ANA_GRID - reciprocal ETA-grid spacing: pn
ANA_GRID - angle between XI-axis and EAST: angler
ANA_GRID - Coriolis parameter at RHO-points: f
(Grid = 01, Min = -8.26000000E-05 Max = -8.26000000E-05)
ANA_GRID - bathymetry at RHO-points: h
(Grid = 01, Min = 2.52004887E+01 Max = 1.50000000E+02)
16 0.0000000 0.0000000 0.000 0.000 0.000 0.000
15 -0.0625000 -0.0019442 -0.809 -0.806 -1.348 -1.589
14 -0.1250000 -0.0078455 -1.668 -1.661 -2.966 -3.687
13 -0.1875000 -0.0179119 -2.580 -2.568 -4.867 -6.321
12 -0.2500000 -0.0324983 -3.549 -3.531 -7.077 -9.535
11 -0.3125000 -0.0521190 -4.581 -4.558 -9.630 -13.397
10 -0.3750000 -0.0774659 -5.686 -5.656 -12.573 -17.996
9 -0.4375000 -0.1094327 -6.875 -6.837 -15.967 -23.445
8 -0.5000000 -0.1491465 -8.162 -8.114 -19.889 -29.890
7 -0.5625000 -0.1980075 -9.564 -9.506 -24.435 -37.512
6 -0.6250000 -0.2577387 -11.104 -11.034 -29.721 -46.531
5 -0.6875000 -0.3304460 -12.808 -12.724 -35.892 -57.218
4 -0.7500000 -0.4186931 -14.709 -14.609 -43.121 -69.903
3 -0.8125000 -0.5255915 -16.846 -16.726 -51.622 -84.987
2 -0.8750000 -0.6549105 -19.266 -19.124 -61.651 -102.953
1 -0.9375000 -0.8112096 -22.028 -21.859 -73.518 -124.388
0 -1.0000000 -1.0000000 -25.200 -25.000 -87.600 -150.000
12 0.0043042707117221 0.0335513677379153-0.0022367614257357 0.4026337758325831
13 0.0060106451121704 0.0334078920475245 0.0037738836864347 0.4360416678801076
15 0.0099910761708920 0.0329439123123590 0.0216737068001212 0.5021931174029188
16 0.0122483446563884 0.0326108764399960 0.0339220514565096 0.5348039938429148
17 0.0146692120341107 0.0322025982847830 0.0485912634906203 0.5670065921276978
18 0.0172400033810439 0.0317136245503127 0.0658312668716642 0.5987202166780105
19 0.0199444086685725 0.0311389577709445 0.0857756755402367 0.6298591744489550
20 0.0227631639997064 0.0304741441486588 0.1085388395399431 0.6603333185976138
21 0.0256737146312910 0.0297153720153352 0.1342125541712341 0.6900486906129490
22 0.0286498597812016 0.0288595815276255 0.1628624139524357 0.7189082721405746
23 0.0316613792205220 0.0279045862015855 0.1945237931729577 0.7468128583421600
24 0.0346736416507075 0.0268492068942347 0.2291974348236651 0.7736620652363948
25 0.0376471948657328 0.0256934188392112 0.2668446296893979 0.7993554840756060
26 0.0405373376992232 0.0244385123436867 0.3073819673886211 0.8237939964192927
27 0.0432936737565711 0.0230872677537126 0.3506756411451922 0.8468812641730054
28 0.0458596469320356 0.0216441452951603 0.3965352880772278 0.8685254094681656
29 0.0481720587108284 0.0201154903974257 0.4447073467880562 0.8886408998655914
30 0.0501605672561820 0.0185097551070648 0.4948679140442381 0.9071506549726561
31 0.0517471682814030 0.0168377361985254 0.5466150823256412 0.9239883911711815
32 0.0528456577069106 0.0151128305891453 0.5994607400325517 0.9391012217603267
33 0.0533610761022577 0.0133513086655816 0.6528218161348094 0.9524525304259084
34 0.0531891349131379 0.0115726061288397 0.7060109510479473 0.9640251365547481
35 0.0522156244733761 0.0097996349650684 0.7582265755213234 0.9738247715198165
36 0.0503158038019031 0.0080591141492892 0.8085423793232265 0.9818838856691057
37 0.0473537721847153 0.0063819206892258 0.8558961515079418 0.9882658063583315
38 0.0431818225418188 0.0048034616164019 0.8990779740497606 0.9930692679747335
39 0.0376397765791564 0.0033640675316746 0.9367177506289170 0.9964333355064081
40 0.0305543017255206 0.0021094083123694 0.9672720523544377 0.9985427438187775
41 0.0217382098544505 0.0010909315881854 0.9890102622088881 0.9996336754069629
42 0.0109897377911119 0.0003663245930371 1.0000000000000000 1.0000000000000000
Minimum X-grid spacing, DXmin = 1.00000000E+00 km
Maximum X-grid spacing, DXmax = 1.00000000E+00 km
Minimum Y-grid spacing, DYmin = 1.00000000E+00 km
Maximum Y-grid spacing, DYmax = 1.00000000E+00 km
Minimum Z-grid spacing, DZmin = 8.08965824E-01 m
Maximum Z-grid spacing, DZmax = 2.56123321E+01 m
Minimum barotropic Courant Number = 2.22358627E-01
Maximum barotropic Courant Number = 5.42494240E-01
Maximum Coriolis Courant Number = 2.47800000E-02
(Grid = 01, Min = 1.45204834E+01 Max = 2.19365219E+01)
ANA_INITIAL - salinity: salt
(Grid = 01, Min = 3.50000000E+01 Max = 3.50000000E+01)
Maximum grid stiffness ratios: rx0 = 6.931666E-02 (Beckmann and Haidvogel)
rx1 = 8.661243E-01 (Haney)
Initial domain volumes: TotVolume = 3.8843755884E+11 m3
MinCellVol = 8.4521383562E+05 m3
MaxCellVol = 2.5612332106E+07 m3
Max/Min = 3.0302783777E+01
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 000000000001 - 000000001440)
0 0001-01-01 00:00:00.00 0.000000E+00 6.585677E+02 6.585677E+02 3.884376E+11
(00,00,00) 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
DEF_HIS - creating history file, Grid 01: roms_his.nc
Found Error: ** Line: 8222 Source: ROMS/Modules/mod_netcdf.F, netcdf_create
NETCDF_CREATE - unable to create output NetCDF file:
roms_his.nc
call from: ROMS/Utility/def_his.F
NetCDF: Malformed URL
Found Error: 03 Line: 105 Source: ROMS/Utility/def_his.F
DEF_HIS - unable to create history NetCDF file: roms_his.nc
Found Error: 03 Line: 151 Source: ROMS/Nonlinear/output.F
Found Error: 03 Line: 600 Source: ROMS/Nonlinear/main3d.F
Found Error: 03 Line: 303 Source: ROMS/Drivers/nl_ocean.h
Thread # 0 CPU: 0.085
Total: 0.085
Allocation and array initialization .............. 0.068 (79.9226 %)
Ocean state initialization ....................... 0.009 (11.0992 %)
Reading of input data ............................ 0.000 ( 0.0106 %)
Processing of input data ......................... 0.000 ( 0.0577 %)
Processing of output time averaged data .......... 0.000 ( 0.0930 %)
Computation of vertical boundary conditions ...... 0.000 ( 0.0459 %)
Computation of global information integrals ...... 0.001 ( 1.2135 %)
2D/3D coupling, vertical metrics ................. 0.002 ( 2.7424 %)
Omega vertical velocity .......................... 0.001 ( 1.1758 %)
Equation of state for seawater ................... 0.001 ( 1.5478 %)
Total: 0.083 97.9085
Unique code regions profiled ..................... 0.083 97.9085 %
Residual, non-profiled code ...................... 0.002 2.0915 %
All percentages are with respect to total time = 0.085
Dynamic and Automatic memory (MB) usage for Grid 01: 41x80x16 tiling: 1x1
tile Dynamic Automatic USAGE
0 77.16 3.87 81.04
TOTAL 77.16 3.87 81.04
Analytical header files used:
ROMS/Functionals/ana_btflux.h
/home/javadbabagoli/Documents/Test/ana_grid.h
/home/javadbabagoli/Documents/Test/ana_initial.h
ROMS/Functionals/ana_smflux.h
ROMS/Functionals/ana_stflux.h
ROMS/Functionals/ana_vmix.h
Found Error: 03 Line: 423 Source: ROMS/Utility/close_io.F
REASON: NetCDF: Malformed URL
robertson
Re: NETCDF PROBLEM WHEN RUNNING MODEL
#2 Unread post by robertson »
It doesn't really agree with the error you're getting but are you absolutely sure you have write permissions to the directory you're writing the history file to?
javadi
#3 Unread post by javadi »
Dear Robertson
Thank you o much for your response.
I usually use the trunk to run the model and I ran my test case without any problem. However, I try to add ice in my model; thus, I add kate branch to my system. I download from git when using clone. After that, I have faced this error. I use the same method to run kate branch and trunk.
When it comes to directory, I am not sure about it because I have faced this error when compiling.
svn: E155007: '/home/javadbabagoli/Documents/roms' is not a working copy
and also, when I compile the model, I enter with root but I ran the model without using root because I have faced this error
mpirun has detected an attempt to run as root.
Running as root is *strongly* discouraged as any mistake (e.g., in
defining TMPDIR) or bug can result in catastrophic damage to the OS
file system, leaving your system in an unusable state.
We strongly suggest that you run mpirun as a non-root user.
You can override this protection by adding the --allow-run-as-root option
to the cmd line or by setting two environment variables in the following way:
the variable OMPI_ALLOW_RUN_AS_ROOT=1 to indicate the desire to override this
protection, and OMPI_ALLOW_RUN_AS_ROOT_CONFIRM=1 to confirm the choice and
add one more layer of certainty that you want to do so.
We reiterate our advice against doing so - please proceed at your own risk.
robertson
#4 Unread post by robertson »
That svn error should not stop compilation and the command that is failing is only used for informational purposes. Compiling (and running) ROMS as root is never a good idea. It's also quite likely that somewhere along the line you made a directory that is owned by root and that is probably what isn't allowing you to create files.
In the directory where you're planning to have your ROMS output (not as root) try running 'touch junk' and see if you get a permission error.
Also, I don't see how compiling with root would make that svn error go away.
javadi
#5 Unread post by javadi »
Dear Robertson
When it comes to compiling without root, I have faced some permission errors. However, when I run ‘touch junk’, a file junk is made in my output directory without errors.
The error when compiling without root:
rm -f -r core *.ipo /home/javadbabagoli/Documents/Test/Build_roms /home/javadbabagoli/make_macros.mk
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/convolve.f90': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/set_avg2_mod.mod': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/def_avg.o': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/get_bounds.o': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/set_tides.f90': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/dateclock.f90': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/mod_floats.mod': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/obc_adjust_mod.mod': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/close_io.o': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/ini_lanczos.o': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/mod_ocean.o': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/set_3dfldr.f90': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/sum_imp.f90': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/NN_corstep.o': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/set_3dfldr.o': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/abort.o': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/dotproduct.o': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/wvelocity.o': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/conv_bry2d.f90': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/round.f90': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/ccsm_flux_mod.mod': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/def_station.f90': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/nf_fread2d.o': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/get_ngfldr.o': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/bc_3d.o': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/shapiro_mod.mod': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/step3d_t_mod.mod': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/nf_fwrite4d.o': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/def_impulse.o': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/extract_sta.f90': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/mod_nesting.mod': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/congrad.f90': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/mod_coupling.mod': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/checkvars.f90': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/checkvars.o': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/set_avg_mod.mod': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/exchange_3d.f90': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/nf_fread4d.o': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/analytical.f90': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/mod_fourdvar.mod': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/wrt_rst.o': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/abort.f90': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/state_copy_mod.mod': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/mod_kinds.o': Permission denied
rm: cannot remove '/home/javadbabagoli/Documents/Test/Build_roms/strings.f90': Permission denied
robertson
#6 Unread post by robertson »
Since you executed the build script as root, the Build_roms directory is owned by root so user javadbabagoli does not have permission to remove it. Manually remove (rm -rf Build_roms) the Build_roms directory as root. Then run the build script (as javadbabagoli) again. If you still get permission errors then it's likely that your "Test" directory is also owned by root.
javadi
#7 Unread post by javadi »
Dear Robertson
Yes. Your opinion is completely right.
Thank you so much for your help
