Error while running Fjord test case for the first time
neelbasak08
Location: Thapar Institute of Engineering and Technology, Patiala, PN, India
#1 Unread post by neelbasak08 »
Sir,
I am running ROMS for the first time and tried to run Fjord test case. The makefile compilation went well, build_roms.sh command ran perfectly. I followed each and every step in the tutorial https://www.myroms.org/wiki/FJORD_TIDAL_CASE .While running the final command : ./romsG < External/roms_fjord.in , I ran into following error:
sbasak08@DESKTOP-UOIVLQT:~/roms/Projects/fjord$ ./romsG < External/roms_fjord.in
Friday - January 8, 2021 - 5:56:57 PM
Tidal Fjord
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler flags : -frepack-arrays -g -O0 -fbounds-check -fbacktrace -fcheck=all -fsanitize=address -fsanitize=undefined -finit-real=nan -ffpe-trap=invalid,zero,overflow -
SVN Revision : 1053
Local Root : /home/sbasak08/roms
Header Dir : /home/sbasak08/roms/Projects/fjord
Header file : fjord.h
Analytical Dir : /home/sbasak08/roms/Projects/fjord
Resolution, Grid 01: 90x24x10, Parallel Threads: 1, Tiling: 1x1
1866241 ntimes Number of timesteps for 3-D equations.
10.000 dt Timestep size (s) for 3-D equations.
360 nRST Number of timesteps between the writing of data
into restart fields.
360 ninfo Number of timesteps between print of information
to standard output.
60 nHIS Number of timesteps between the writing fields
into history file.
into quicksave file.
0.0000E+00 nl_visc4 NLM Horizontal, biharmonic mixing coefficient
(m4/s) for momentum.
1.0000E+00 Akv_bak Background vertical mixing coefficient (m2/s)
2.6500E-04 rdrg Linear bottom drag coefficient (m/s).
12 levsfrc Deepest level to apply surface stress as a
bodyforce.
READ_PHYPAR - Invalid input parameter, levsfrc = 12
Out of range surface bodyforce level.
Found Error: 05 Line: 191 Source: ROMS/Utility/inp_par.F
Found Error: 05 Line: 115 Source: ROMS/Drivers/nl_ocean.h, ROMS_initialize
Dynamic and Automatic memory (MB) usage for Grid 01: 90x24x10 tiling: 1x1
tile Dynamic Automatic USAGE
0 0.98 0.42 1.40
TOTAL 0.98 0.42 1.40
Found Error: 05 Line: 361 Source: ROMS/Utility/close_io.F, close_out
ERROR STOP
Error termination. Backtrace:
#0 0x7f7468950d01 in ???
#1 0x7f7468951849 in ???
#2 0x7f7468952f77 in ???
#3 0x7f746c95e462 in ocean
at /home/sbasak08/roms/Projects/fjord/Build_roms/master.f90:101
#4 0x7f746c95e4bb in main
at /home/sbasak08/roms/Projects/fjord/Build_roms/master.f90:50
Here are my location of files:
build_roms.sh : /home/sbasak08/roms/Projects/fjord
makefile: /home/sbasak08/roms/Projects/fjord
fjord.h file : /home/sbasak08/roms/Projects/fjord
romsG : /home/sbasak08/roms/Projects/fjord
ana_fsobc.h and ana_m2obc.h : /home/sbasak08/roms/Projects/fjord/Functionals
roms_fjord.in : /home/sbasak08/roms/Projects/fjord/External
varinfo.dat: /home/sbasak08/roms/Projects/fjord/External
Drivers: /home/sbasak08/roms/ROMS
Utility: /home/sbasak08/roms/ROMS
Fjord_grd.nc and Fjord_ini.nc : /home/sbasak08/roms/Projects/fjord
I am also attaching Utility, Build_roms and Drivers folder for your reference combined in a zip folder.
Fjord_ini.nc
(3.33 MiB) Downloaded 690 times
Fjord_grd.nc
(334.23 KiB) Downloaded 675 times
error_fjord.txt
(4.38 KiB) Downloaded 793 times
all_folder_mentioned.zip
(52.3 MiB) Downloaded 1057 times
robertson
Re: Error while running Fjord test case for the first time
#2 Unread post by robertson »
you problem is:
bodyforce.
You only have 10 vertical levels and and you're asking roms to apply surface stress 12 layers deep.
