DYNAMICS OPTION: Eulerian Mass Coordinate forrtl: severe (174): SIGSEGV, segmentation fault occurred
agpc
#1 Unread post by agpc »
Hi everyone,
When I run the coawst model it reported that:
coawstM            0000000003C4696A  Unknown               Unknown  Unknown
libpthread-2.17.s  00002B4CA7C955D0  Unknown               Unknown  Unknown
coawstM            000000000091D1D2  read_phypar_             3082  read_phypar.f90
coawstM            000000000078E749  inp_par_                   87  inp_par.f90
coawstM            00000000004426D9  ocean_control_mod          90  ocean_control.f90
coawstM            000000000041E93B  MAIN__                    373  master.f90
coawstM            0000000000418AA2  Unknown               Unknown  Unknown
libc-2.17.so       00002B4CA83CA495  __libc_start_main     Unknown  Unknown
coawstM            00000000004189A9  Unknown               Unknown  Unknown
   alloc_space_field: domain            1 ,               89554972  bytes allocated
Fatal error in MPI_Send: Other MPI error, error stack:
MPI_Send(173)..................: MPI_Send(buf=0xa06f380, count=4, MPI_INTEGER, dest=0, tag=2, MPI_COMM_WORLD) failed
MPIDI_EagerContigShortSend(262): failure occurred while attempting to send an eager message
MPIDI_CH3_iStartMsg(36)........: Communication error with rank 0
Can anyone help me to solve this problem?
The log files are included in this post.
I'm really appreciate that.
-Manh
coawst.out.txt
(31.39 KiB) Downloaded 901 times
COAWST.err.txt
(20.6 KiB) Downloaded 928 times
Re: DYNAMICS OPTION: Eulerian Mass Coordinate forrtl: severe (174): SIGSEGV, segmentation fault occurred
What is on this line in your code? You say you are using COAWST, but where did you get your roms.in file? Does it have lines for how many boundary and climatology files you have? NCLMFILES and NBCFILES, also NSSFFILES. These need to be non-zero.
agpc
#3 Unread post by agpc »
Hi Kate,
The line in my code is "fname=BRY(i,ng)%files(ifile)", it is displayed clearly below:
          IF (ObcData(ng)) THEN
            DO i=1,nBCfiles(ng)
              DO ifile=1,BRY(i,ng)%Nfiles
                IF (.not.find_file(ng, fname, 'BRYNAME')) GO TO 30
                IF (ifile.eq.1) THEN
                  WRITE (out,230) '             Input Boundary File:  ',&
After I add the HOTFILE command in SWAN's namelist, it reported that:
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   RANK 1 PID 67104 RUNNING AT compute-1-17
=   KILLED BY SIGNAL: 9 (Killed)
I aslo attach all of my namelist files of my project in this post.
Can you help me to address this problem?
Many thanks,
-manh
swan_sarika.in.txt
(4.08 KiB) Downloaded 951 times
ocean_sarika.in.txt
(147.49 KiB) Downloaded 1000 times
namelist.input.txt
(4.67 KiB) Downloaded 1076 times
coupling_sarika.in.txt
(8.47 KiB) Downloaded 1210 times
#4 Unread post by jcwarner »
ok. you have this
NCLMFILES == 2 ! number of climate files
CLMNAME == Projects/Sarika4/coawst_clm_20161016.nc |
Projects/Sarika4/coawst_clm_20161017.nc
NBCFILES == 2 ! number of boundary files
! BRYNAME == Projects/Sandy/Sarika_bdy.nc
BRYNAME == Projects/Sarika4/coawst_bdy_20161016.nc |
Projects/Sarika4/coawst_bdy_20161017.nc |
But I think there are 2 problems here.
- IF the information in *clm_20161016 and *clm_20161017 are the same fields but with different dates, then you list as 1 file with a continuation symbol |.
- Also, for the BRY files, there should not be a | or any symbol after the last file name.
Give this a try:
NCLMFILES == 1 ! number of climate files
NBCFILES == 1 ! number of boundary files
agpc
#5 Unread post by agpc »
Hi John,
Thank you for your help. I changed my ROMS's namelist file following your suggestion, however it still errored:
=   RANK 1 PID 75646 RUNNING AT compute-1-17
=   RANK 2 PID 75647 RUNNING AT compute-1-17
#6 Unread post by jcwarner »
there is not enough information for me to determine what is going wrong.
You need to dig into the full output being written.
Did SWAN give Err* files? Maybe try to run the system with one model at a time, to see if each model can handle your new application. then slowly add each component.
agpc
#7 Unread post by agpc »
Hi John,
In this post, I give you all of my output files.
I hope it is enough to determine what is going wrong.
Thank you very much!
swaninit01-001.txt
(1.16 KiB) Downloaded 886 times
PRINT01-001.txt
(897 Bytes) Downloaded 1006 times
coawst.out.txt
(22.72 KiB) Downloaded 1052 times
COAWST.err.txt
(17.94 KiB) Downloaded 1001 times
#8 Unread post by jcwarner »
in the *.err file we have:
libpthread-2.17.s 00002AAF329CD5D0 Unknown Unknown Unknown
coawstM 000000000092471A edit_file_struct_ 212 edit_multifile.f90
coawstM 000000000090A307 read_phypar_ 2198 read_phypar.f90
libc-2.17.so 00002AAF33102495 __libc_start_main Unknown Unknown
so this is a problem ROMS reading the ocean.in file, and maybe opening up some files. i think this was an error earlier, so it has not been solved.
Can you step through read_phypar.f90 line 2198 and see what files it is trying to open, and see what edit_multifile.f90 line 212 is trying to do? this will help solve the problem.
agpc
#9 Unread post by agpc »
HI John,
The line 2198 of read_phypar.f90 is:
CALL edit_file_struct (ng, OutFiles, QCK)
The line 212 of edit_multifile.f90 is "end if" which located below:
        IF (associated(S(ng)%files))    deallocate (S(ng)%files)
        allocate ( S(ng)%Nrec(Nfiles) )
        allocate ( S(ng)%time_min(Nfiles) )
        allocate ( S(ng)%time_max(Nfiles) )
        allocate ( S(ng)%files(Nfiles) )
#10 Unread post by jcwarner »
ok. so this is looking for the Quick output file writes.
Your ocean.in has
! NQCK == 0
! NDEFQCK == 0
lets try it with this:
NQCK == 0
NDEFQCK == 0
and see if that works.
agpc
#11 Unread post by agpc »
Hi John,
Thank you for your suggestion. I changed my ROMS namelist file and the problem was solved.
However, I had another issue is that:
 MULTIFILE_INFO_S2D - Error while processing lateral boundary multi-files:
                      data does not include initialization time = 2174-09-15 00:00:00.00
   ****-**-** 00:00:00.00  ****-**-** 00:00:00.00     Projects/Sarika/merged_coawst_bdy.nc
 Found Error: 04   Line: 484      Source: ROMS/Utility/check_multifile.F
 Found Error: 04   Line: 111      Source: ROMS/Utility/check_multifile.F
 Found Error: 04   Line: 846      Source: ROMS/Nonlinear/initial.F
 Found Error: 04   Line: 211      Source: ROMS/Drivers/nl_ocean.h
 Found Error: 05   Line: 443      Source: ROMS/Utility/close_io.F
 ROMS/TOMS - Configuration error ..... exit_flag:   5
 == SWAN grid  1 sent wave data to ROMS grid  1
I check the line 443 of the close_io.F program is " IF (Master.and.(FoundError(exit_flag, NoError, __LINE__, &"
This line is located in the below:
     &               __FILE__))) THEN
        WRITE (stdout,40) Rerror(exit_flag), exit_flag
      IF (blowup.ne.0) THEN
        IF (Master) WRITE (stdout,50) TRIM(blowup_string)
      ELSE IF (exit_flag.eq.NoError) THEN
Please help me to tackle this problem. I'm really appreciate that!
-Manh,
#12 Unread post by jcwarner »
looks to me like something is wrong with "time". the error is:
"MULTIFILE_INFO_S2D - Error while processing lateral boundary multi-files:
****-**-** 00:00:00.00 ****-**-** 00:00:00.00 Projects/Sarika/merged_coawst_bdy.nc"
Your input files for lateral boundary conditions are starting with a time in the year 2174, .... that is probably wrong.
Then, the model time is not even being displayed accurately, it says ****-**-** 00:00:00.00 . that means the number is too big to be displayed with that formatting.
So first i suggest you look at the information for the time variables in the boundary netcdf files. you can do a
ncdump -h merged_coawst_bdy.nc
and see what that shows for the v3dtime etc.
Then you need to compare that with the way you are running ROMS, using DSTART and TIME_REF. there is information at the bottom of the ocean.in to help with those settings.
agpc
#13 Unread post by agpc »
Hi John,
Here is my bdy.nc file:
[cloud@igplogin Sarika]$ ncdump -c merged_coawst_bdy.nc
netcdf merged_coawst_bdy {
dimensions:
	xpsi = 299 ;
	xrho = 300 ;
	xu = 299 ;
	xv = 300 ;
	epsi = 219 ;
	erho = 220 ;
	eu = 220 ;
	ev = 219 ;
	s_rho = 16 ;
	zeta_time = 2 ;
	v2d_time = 2 ;
	v3d_time = 2 ;
	salt_time = 2 ;
	temp_time = 2 ;
variables:
	double zeta_time(zeta_time) ;
		zeta_time:long_name = "zeta_time" ;
		zeta_time:units = "days" ;
		zeta_time:field = "zeta_time, scalar, series" ;
	double v2d_time(v2d_time) ;
		v2d_time:long_name = "v2d_time" ;
		v2d_time:units = "days" ;
		v2d_time:field = "v2d_time, scalar, series" ;
	double v3d_time(v3d_time) ;
		v3d_time:long_name = "v3d_time" ;
		v3d_time:units = "days" ;
		v3d_time:field = "v3d_time, scalar, series" ;
	double salt_time(salt_time) ;
		salt_time:long_name = "salt_time" ;
		salt_time:units = "days" ;
		salt_time:field = "salt_time, scalar, series" ;
	double temp_time(temp_time) ;
		temp_time:long_name = "temp_time" ;
		temp_time:units = "days" ;
		temp_time:field = "temp_time, scalar, series" ;
	double zeta_south(zeta_time, xrho) ;
		zeta_south:long_name = "free-surface southern boundary condition" ;
		zeta_south:units = "meter" ;
		zeta_south:field = "zeta_south, scalar, series" ;
	double zeta_east(zeta_time, erho) ;
		zeta_east:long_name = "free-surface eastern boundary condition" ;
		zeta_east:units = "meter" ;
		zeta_east:field = "zeta_east, scalar, series" ;
	double zeta_west(zeta_time, erho) ;
		zeta_west:long_name = "free-surface western boundary condition" ;
		zeta_west:units = "meter" ;
		zeta_west:field = "zeta_west, scalar, series" ;
	double zeta_north(zeta_time, xrho) ;
		zeta_north:long_name = "free-surface northern boundary condition" ;
		zeta_north:units = "meter" ;
		zeta_north:field = "zeta_north, scalar, series" ;
	float ubar_south(v2d_time, xu) ;
		ubar_south:long_name = "2D u-momentum southern boundary condition" ;
		ubar_south:units = "meter second-1" ;
		ubar_south:field = "ubar_south, scalar, series" ;
	float ubar_east(v2d_time, eu) ;
		ubar_east:long_name = "2D u-momentum eastern boundary condition" ;
		ubar_east:units = "meter second-1" ;
		ubar_east:field = "ubar_east, scalar, series" ;
	float ubar_west(v2d_time, eu) ;
		ubar_west:long_name = "2D u-momentum western boundary condition" ;
		ubar_west:units = "meter second-1" ;
		ubar_west:field = "ubar_west, scalar, series" ;
	float ubar_north(v2d_time, xu) ;
		ubar_north:long_name = "2D u-momentum northern boundary condition" ;
		ubar_north:units = "meter second-1" ;
		ubar_north:field = "ubar_north, scalar, series" ;
	float vbar_south(v2d_time, xv) ;
		vbar_south:long_name = "2D v-momentum southern boundary condition" ;
		vbar_south:units = "meter second-1" ;
		vbar_south:field = "vbar_south, scalar, series" ;
	float vbar_east(v2d_time, ev) ;
		vbar_east:long_name = "2D v-momentum eastern boundary condition" ;
		vbar_east:units = "meter second-1" ;
		vbar_east:field = "vbar_east, scalar, series" ;
	float vbar_west(v2d_time, ev) ;
		vbar_west:long_name = "2D v-momentum western boundary condition" ;
		vbar_west:units = "meter second-1" ;
		vbar_west:field = "vbar_west, scalar, series" ;
	float vbar_north(v2d_time, xv) ;
		vbar_north:long_name = "2D v-momentum northern boundary condition" ;
		vbar_north:units = "meter second-1" ;
		vbar_north:field = "vbar_north, scalar, series" ;
	float u_south(v3d_time, s_rho, xu) ;
		u_south:long_name = "3D u-momentum southern boundary condition" ;
		u_south:units = "meter second-1" ;
		u_south:field = "u_south, scalar, series" ;
	float u_east(v3d_time, s_rho, eu) ;
		u_east:long_name = "3D u-momentum eastern boundary condition" ;
		u_east:units = "meter second-1" ;
		u_east:field = "u_east, scalar, series" ;
	float u_west(v3d_time, s_rho, eu) ;
		u_west:long_name = "3D u-momentum western boundary condition" ;
		u_west:units = "meter second-1" ;
		u_west:field = "u_west, scalar, series" ;
	float u_north(v3d_time, s_rho, xu) ;
		u_north:long_name = "3D u-momentum northern boundary condition" ;
		u_north:units = "meter second-1" ;
		u_north:field = "u_north, scalar, series" ;
	float v_south(v3d_time, s_rho, xv) ;
		v_south:long_name = "3D v-momentum southern boundary condition" ;
		v_south:units = "meter second-1" ;
		v_south:field = "v_south, scalar, series" ;
	float v_east(v3d_time, s_rho, ev) ;
		v_east:long_name = "3D v-momentum eastern boundary condition" ;
		v_east:units = "meter second-1" ;
		v_east:field = "v_east, scalar, series" ;
	float v_west(v3d_time, s_rho, ev) ;
		v_west:long_name = "3D v-momentum western boundary condition" ;
		v_west:units = "meter second-1" ;
		v_west:field = "v_west, scalar, series" ;
	float v_north(v3d_time, s_rho, xv) ;
		v_north:long_name = "3D v-momentum northern boundary condition" ;
		v_north:units = "meter second-1" ;
		v_north:field = "v_north, scalar, series" ;
	float temp_south(temp_time, s_rho, xrho) ;
		temp_south:long_name = "3D temperature southern boundary condition" ;
		temp_south:units = "C" ;
		temp_south:field = "temp_south, scalar, series" ;
	float temp_east(temp_time, s_rho, erho) ;
		temp_east:long_name = "3D temperature eastern boundary condition" ;
		temp_east:units = "C" ;
		temp_east:field = "temp_east, scalar, series" ;
	float temp_west(temp_time, s_rho, erho) ;
		temp_west:long_name = "3D temperature western boundary condition" ;
		temp_west:units = "C" ;
		temp_west:field = "temp_west, scalar, series" ;
	float temp_north(temp_time, s_rho, xrho) ;
		temp_north:long_name = "3D temperature northern boundary condition" ;
		temp_north:units = "C" ;
		temp_north:field = "temp_north, scalar, series" ;
	float salt_south(salt_time, s_rho, xrho) ;
		salt_south:long_name = "3D salinity southern boundary condition" ;
		salt_south:units = "psu" ;
		salt_south:field = "salt_south, scalar, series" ;
	float salt_east(salt_time, s_rho, erho) ;
		salt_east:long_name = "3D salinity eastern boundary condition" ;
		salt_east:units = "psu" ;
		salt_east:field = "salt_east, scalar, series" ;
	float salt_west(salt_time, s_rho, erho) ;
		salt_west:long_name = "3D salinity western boundary condition" ;
		salt_west:units = "psu" ;
		salt_west:field = "salt_west, scalar, series" ;
	float salt_north(salt_time, s_rho, xrho) ;
		salt_north:long_name = "3D salinity northern boundary condition" ;
		salt_north:units = "psu" ;
		salt_north:field = "salt_north, scalar, series" ;
// global attributes:
		:history = "Created by updatclim on 16-Dec-2020 23:39:24" ;
		:type = "climate forcing file from http://hycom.coaps.fsu.edu:8080/thredds/dodsC/glb_analysis" ;
data:
 zeta_time = 4983379200, 4983465600 ;
 v2d_time = 4983379200, 4983465600 ;
 v3d_time = 4983379200, 4983465600 ;
 salt_time = 4983379200, 4983465600 ;
 temp_time = 4983379200, 4983465600 ;
I want to forecast during 48h of lead time begin at 20161016, why is my set-up going wrong?
      DSTART =   2.0d0         ! days
  TIDE_START =   0.0d0                  ! days
    TIME_REF =  20161016.0d0               ! yyyymmdd.dd
Can you help me to address this issue.
Thank you.
#14 Unread post by jcwarner »
what does this give
ncks -v v2d_time Projects/Sarika/merged_coawst_bdy.nc
agpc
#15 Unread post by agpc »
Hi John,
This is my result:
[cloud@igplogin Sarika]$ ncks -v v2d_time merged_coawst_bdy.nc
v2d_time: type NC_DOUBLE, 1 dimension, 3 attributes, compressed? no, chunked? no, packed? no
v2d_time size (RAM) = 2*sizeof(NC_DOUBLE) = 2*8 = 16 bytes
v2d_time dimension 0: v2d_time, size = 2 NC_DOUBLE (Coordinate is v2d_time)
v2d_time attribute 0: long_name, size = 8 NC_CHAR, value = v2d_time
v2d_time attribute 1: units, size = 4 NC_CHAR, value = days
v2d_time attribute 2: field, size = 24 NC_CHAR, value = v2d_time, scalar, series
v2d_time[0]=4983379200 days
v2d_time[1]=4983465600 days
#16 Unread post by jcwarner »
so the problem is that the forcing time is at 4983379200 days.
that number is probably in seconds (not days),
4983379200/3600/24=57678
and that number is probably
julian(2016,10,1)-2400000=57678
So you need to change the values of time in that forcings file from
to
v2d_time[0]=57678 days
v2d_time[1]=57679 days
for all the vars in the bdy and init and clm.
For the ocean model iteself, i am not sure what that is doing. you need to look closely at what it writes in the output file.
agpc
#17 Unread post by agpc »
Hi John,
I had changed my time vars in my clm.nc file to:
 ocean_time = 57678, 57679 ;
 zeta_time = 57678, 57679 ;
 v2d_time = 57678, 57679 ;
 v3d_time = 57678, 57679 ;
 salt_time = 57678, 57679 ;
 temp_time = 57678, 57679 ;
and my bdy.nc file to:
The ocean_time in Sarika_ini.nc file to:
ocean_time = 57678 ;
The result is that my problem is solved.
Although I saw the line
NLM: GET_STATE - Reading state initial conditions, 2174-09-16 00:00:00.00
(Grid 01, t = 57678.0000, File: Sarika_ini.nc, Rec=0001, Index=1)
my model still ran, isn't it?
I also attached my log file in this post.
thank you very much!
coawst.out.txt
(715.28 KiB) Downloaded 1030 times
#18 Unread post by jcwarner »
getting close, but it still looks like something is wrong with the ocean times.
what is the ocean_time in the ocean ini netcdf file?
and what are the attributes for that (ncdump and ncks the ocean_time in the ini file).
these need to be consistent with the dstart and time_ref.
try to figure it out.
agpc
#19 Unread post by agpc »
Hi John,
Finally, I can fix it.
-Manh
