Graphite loop optimizations cannot be used (isl is not available)
cloudy4568
#1 Unread post by cloudy4568 »
I encountered the same error while compiling coawst(v3.6) project inlet_test and installing SCRIP_COAWST :
f951: sorry, unimplemented: Graphite loop optimizations cannot be used (isl is not available) (-fgraphite, -fgraphite-identity, -floop-nest-optimize, -floop-parallelize-all)
make: *** [Build/mod_kinds.o] Error 1
I am using gfortran and the version is 8.3.0. Roms could be compiled and run well. Do you have any idea about how to solve this problem? Any help would be appreciated.
Re: Graphite loop optimizations cannot be used (isl is not available)
you need to edit a file in your Compilers dir. most likely:
Compilers/Linux-gfortran.mk
but i did a search and dont see any graphite flags in there. maybe post more of the build.
where is that flag coming from??
cloudy4568
#3 Unread post by cloudy4568 »
Thank you, John. The full build is:
rm -f -r core *.ipo ./Build /mnt/home/cyue/make_macros.mk
cp -f /opt/ohpc/pub/libs/gnu8/openmpi3/netcdf-fortran/4.5.2/include/netcdf.mod ./Build
cp -f /opt/ohpc/pub/libs/gnu8/openmpi3/netcdf-fortran/4.5.2/include/typesizes.mod ./Build
cp -p /mnt/home/cyue/make_macros.mk ./Build
cd ./Build;        \
cpp -P -DINLET_TEST -D'HEADER="inlet_test.h"' -D'ROMS_HEADER="/mnt/home/cyue/coawst/Projects/Inlet_test/Coupled/inlet_test.h"' -I/mnt/home/cyue/coawst/ROMS/Include /mnt/home/cyue/coawst/Master/MCT_coupler/mod_coupler_kinds.F > mod_coupler_kinds.f90; \
/mnt/home/cyue/coawst/ROMS/Bin/cpp_clean mod_coupler_kinds.f90;                                                              \
/opt/ohpc/pub/mpi/openmpi3-gnu8/3.1.4/bin/mpif90 -c -frepack-arrays -O3 -ffast-math -O3 -ftree-vectorize -ftree-loop-linear -funroll-loops -w -ffree-form -ffree-line-length-none -frecord-marker=4 -fconvert=big-endian -I/usr/include -Imnt/home/cyue/cooo/MCT/include mod_coupler_kinds.f90;                                                  \
cpp -P -DINLET_TEST -D'HEADER="inlet_test.h"' -D'ROMS_HEADER="/mnt/home/cyue/coawst/Projects/Inlet_test/Coupled/inlet_test.h"' -I/mnt/home/cyue/coawst/ROMS/Include /mnt/home/cyue/coawst/Master/MCT_coupler/mct_coupler_params.F > mct_coupler_params.f90; \
/mnt/home/cyue/coawst/ROMS/Bin/cpp_clean mct_coupler_params.f90;                                                             \
/opt/ohpc/pub/mpi/openmpi3-gnu8/3.1.4/bin/mpif90 -c -frepack-arrays -O3 -ffast-math -O3 -ftree-vectorize -ftree-loop-linear -funroll-loops -w -ffree-form -ffree-line-length-none -frecord-marker=4 -fconvert=big-endian -I/usr/include -Imnt/home/cyue/cooo/MCT/include mct_coupler_params.f90;
f951: Warning: Nonexistent include directory ‘mnt/home/cyue/cooo/MCT/include’ [-Wmissing-include-dirs]
make: *** [mct_params] Error 1
make: Nothing to be done for `wrfclean'.
make: Nothing to be done for `wrf'.
make: Nothing to be done for `wrfhydroclean'.
make: Nothing to be done for `wrfhydro'.
make: Nothing to be done for `ww3clean'.
make: Nothing to be done for `ww3'.
/usr/bin/cpp -P -traditional -w               -DMPI -DLINUX -DX86_64 -DGFORTRAN -D'ROOT_DIR="/mnt/home/cyue/coawst"' -DINLET_TEST -D'HEADER="inlet_test.h"' -D'ROMS_HEADER="/mnt/home/cyue/coawst/Projects/Inlet_test/Coupled/inlet_test.h"' -DNestedGrids= -D'ANALYTICAL_DIR="/mnt/home/cyue/coawst/Projects/Inlet_test/Coupled"' -D'MY_ANALYTICAL="on"' -D'SVN_URL="https://coawstmodel.sourcerepo.com/coawstmodel/COAWST"' -D'SVN_REV="1484"' -IROMS/Include -I/mnt/home/cyue/coawst/Projects/Inlet_test/Coupled -IROMS/Nonlinear -IROMS/Nonlinear/Biology -IROMS/Nonlinear/Sediment -IROMS/Nonlinear/Wec -IROMS/Nonlinear/Vegetation -IROMS/Utility -IROMS/Drivers -IROMS/Functionals -I/mnt/home/cyue/coawst/Projects/Inlet_test/Coupled -ISWAN/Src -IMaster -ICompilers -D'HEADER_DIR="/mnt/home/cyue/coawst/Projects/Inlet_test/Coupled"'  ROMS/Nonlinear/my25_prestep.F > Build/my25_prestep.f90
ROMS/Bin/cpp_clean Build/my25_prestep.f90
/usr/bin/cpp -P -traditional -w               -DMPI -DLINUX -DX86_64 -DGFORTRAN -D'ROOT_DIR="/mnt/home/cyue/coawst"' -DINLET_TEST -D'HEADER="inlet_test.h"' -D'ROMS_HEADER="/mnt/home/cyue/coawst/Projects/Inlet_test/Coupled/inlet_test.h"' -DNestedGrids= -D'ANALYTICAL_DIR="/mnt/home/cyue/coawst/Projects/Inlet_test/Coupled"' -D'MY_ANALYTICAL="on"' -D'SVN_URL="https://coawstmodel.sourcerepo.com/coawstmodel/COAWST"' -D'SVN_REV="1484"' -IROMS/Include -I/mnt/home/cyue/coawst/Projects/Inlet_test/Coupled -IROMS/Nonlinear -IROMS/Nonlinear/Biology -IROMS/Nonlinear/Sediment -IROMS/Nonlinear/Wec -IROMS/Nonlinear/Vegetation -IROMS/Utility -IROMS/Drivers -IROMS/Functionals -I/mnt/home/cyue/coawst/Projects/Inlet_test/Coupled -ISWAN/Src -IMaster -ICompilers -D'HEADER_DIR="/mnt/home/cyue/coawst/Projects/Inlet_test/Coupled"'  ROMS/Nonlinear/exchange_3d.F > Build/exchange_3d.f90
ROMS/Bin/cpp_clean Build/exchange_3d.f90
/usr/bin/cpp -P -traditional -w               -DMPI -DLINUX -DX86_64 -DGFORTRAN -D'ROOT_DIR="/mnt/home/cyue/coawst"' -DINLET_TEST -D'HEADER="inlet_test.h"' -D'ROMS_HEADER="/mnt/home/cyue/coawst/Projects/Inlet_test/Coupled/inlet_test.h"' -DNestedGrids= -D'ANALYTICAL_DIR="/mnt/home/cyue/coawst/Projects/Inlet_test/Coupled"' -D'MY_ANALYTICAL="on"' -D'SVN_URL="https://coawstmodel.sourcerepo.com/coawstmodel/COAWST"' -D'SVN_REV="1484"' -IROMS/Include -I/mnt/home/cyue/coawst/Projects/Inlet_test/Coupled -IROMS/Nonlinear -IROMS/Nonlinear/Biology -IROMS/Nonlinear/Sediment -IROMS/Nonlinear/Wec -IROMS/Nonlinear/Vegetation -IROMS/Utility -IROMS/Drivers -IROMS/Functionals -I/mnt/home/cyue/coawst/Projects/Inlet_test/Coupled -ISWAN/Src -IMaster -ICompilers -D'HEADER_DIR="/mnt/home/cyue/coawst/Projects/Inlet_test/Coupled"'  ROMS/Modules/mod_param.F > Build/mod_param.f90
ROMS/Bin/cpp_clean Build/mod_param.f90
/usr/bin/cpp -P -traditional -w               -DMPI -DLINUX -DX86_64 -DGFORTRAN -D'ROOT_DIR="/mnt/home/cyue/coawst"' -DINLET_TEST -D'HEADER="inlet_test.h"' -D'ROMS_HEADER="/mnt/home/cyue/coawst/Projects/Inlet_test/Coupled/inlet_test.h"' -DNestedGrids= -D'ANALYTICAL_DIR="/mnt/home/cyue/coawst/Projects/Inlet_test/Coupled"' -D'MY_ANALYTICAL="on"' -D'SVN_URL="https://coawstmodel.sourcerepo.com/coawstmodel/COAWST"' -D'SVN_REV="1484"' -IROMS/Include -I/mnt/home/cyue/coawst/Projects/Inlet_test/Coupled -IROMS/Nonlinear -IROMS/Nonlinear/Biology -IROMS/Nonlinear/Sediment -IROMS/Nonlinear/Wec -IROMS/Nonlinear/Vegetation -IROMS/Utility -IROMS/Drivers -IROMS/Functionals -I/mnt/home/cyue/coawst/Projects/Inlet_test/Coupled -ISWAN/Src -IMaster -ICompilers -D'HEADER_DIR="/mnt/home/cyue/coawst/Projects/Inlet_test/Coupled"'  ROMS/Modules/mod_kinds.F > Build/mod_kinds.f90
ROMS/Bin/cpp_clean Build/mod_kinds.f90
cd ./Build; /opt/ohpc/pub/mpi/openmpi3-gnu8/3.1.4/bin/mpif90 -c -frepack-arrays -O3 -ffast-math -O3 -ftree-vectorize -ftree-loop-linear -funroll-loops -w -ffree-form -ffree-line-length-none -frecord-marker=4 -fconvert=big-endian -I/usr/include -Imnt/home/cyue/cooo/MCT/include mod_kinds.f90
Should it be related to MCT compiling? The path does exist.
#4 Unread post by jcwarner »
it does not relate to MCT. It has to do with your compiler, maybe the gcc, ?? , maybe the optimizations?
i did a little googling
https://gcc.gnu.org/gcc-4.8/changes.html
that page has some info. i am really not sure, have not seen this one before. looks like a compiler issue, not the code.
cloudy4568
#5 Unread post by cloudy4568 »
Thank you, John. You are right, I changed the following code in Compilers/Linux-gfortran.mk:
FFLAGS += -ftree-vectorize -ftree-loop-linear -funroll-loops -w -ffree-form -ffree-line-length-none -frecord-marker=4 -fconvert=big-endian
to
FFLAGS += -ftree-vectorize -funroll-loops -w -ffree-form -ffree-line-length-none -frecord-marker=4 -fconvert=big-endian
then coawst.M is compiled completely, and Inlet_test example can be run successfully.
This is compiled with DEBUG=off.
I also tried DEBUG=on, though I can get coawst.G, but there are errors when running examples.
Thank you for your help!
