ROMS 3.9 MPDATA bugs
chuning
#1 Unread post by chuning »
Hi, when using MPDATA in ROMS 3.9 I found two potential issues in step3d_t.F.
The first one is a typo in line 826
              DO i=IstrUm2,IstrUm2
Where it should be
              DO i=IstrUm2,Iendp2i
The second one is related to the logical switches of SPLINES_VDIFF and MPDATA (line 1302-1433). With the current version, when SPLINES_VDIFF and MPDATA are both activated, the whole vertical diffusion section is skipped and tracer concentrations are not written back to t. I did an easy fix
# ifdef SPLINES_VDIFF
          IF (.not.((Hadvection(itrc,ng)%MPDATA).and.                   &
     &              (Vadvection(itrc,ng)%MPDATA))) THEN
          ELSE
!  Compute off-diagonal coefficients FC [lambda*dt*Akt/Hz] for the
!  implicit vertical diffusion terms at future time step, located
!  at horizontal RHO-points and vertical W-points.
!  Also set FC at the top and bottom levels.
          cff=-dt(ng)*lambda
          DO k=N(ng)-1,1,-1
            DO i=Istr,Iend
#  ifdef DIAGNOSTICS_TS
              cff1=t(i,j,k,nnew,itrc)*oHz(i,j,k)
#  endif
              DC(i,k)=DC(i,k)-CF(i,k)*DC(i,k+1)
              t(i,j,k,nnew,itrc)=DC(i,k)
              DiaTwrk(i,j,k,itrc,iTvdif)=DiaTwrk(i,j,k,itrc,iTvdif)+    &
     &                                   t(i,j,k,nnew,itrc)-cff1
#  endif
This will still put the original vertical diffusion code in when MPDATA is used. The only issue is that it messes with the indentation in built code. Another option is to copy and paste the diffusion code in the SPLINE_VDIFF section.
jivica
Re: ROMS 3.9 MPDATA bugs
#2 Unread post by jivica »
I wonder if it is related to the post submitted long time ago:
viewtopic.php?f=19&t=4864&p=18889&hilit=MPDATA#p18887
Regards,
Ivica
#3 Unread post by arango »
Yes, Great catch :!: Thank you for reporting these two bugs. I updated the :arrow: repositories.
