converting roms grid to swan grid
venuscheung
#1 Unread post by venuscheung »
hi all,
i would like to convert roms grid to swan but somethings strange happened, many point in swan.grid show -999
here's my file, Thank you.
swan_coord.txt
(85.92 KiB) Downloaded 768 times
roms2swan.m
(2.01 KiB) Downloaded 735 times
roms_roms.nc
(448.63 KiB) Downloaded 688 times
Re: converting roms grid to swan grid
please read the swan manual.
the 999.. values tell swan those are land mask locations.
those 999.. values need to be the same as the Exception value you list in your swan.input file.
venuscheung
#3 Unread post by venuscheung »
but when I run ./scrip_coawst, the following error comes out
temp.log
(3.45 MiB) Downloaded 921 times
venuscheung
#4 Unread post by venuscheung »
I am here to update the problem.
I believed that the problem happens in converting the grid from roms to swan.
I make roms grid and converted it to swan grid by roms2swan.m.
Then I used scrip_coawst_WW3SWAN.in for remapping and error in temp comes out.
When I run ./coawstM, the following error comes out.
MCT::m_ExchangeMaps::ExGSMapGSMap_:: MCTERROR, Grid Size mismatch
LocalMap Gsize = 9447 RemoteMap Gsize = 9514
MCT::m_ExchangeMaps::ExGSMapGSMap_: Map Grid Size mismatch error, stat =3
030.MCT(MPEU)::die.: from MCT::m_ExchangeMaps::ExGSMapGSMap_()
application called MPI_Abort(MPI_COMM_WORLD, 2) - process 48
LocalMap Gsize = 9514 RemoteMap Gsize = 9447
temp.txt
(1.13 MiB) Downloaded 790 times
swan_coord.txt
(241.57 KiB) Downloaded 801 times
swan_bathy.txt
(141.65 KiB) Downloaded 686 times
(2.38 KiB) Downloaded 716 times
roms2swan.m
(2.01 KiB) Downloaded 711 times
venuscheung
#5 Unread post by venuscheung »
the prooblem is found. Thank you all.
HONGWANG
#6 Unread post by HONGWANG »
hi, i meet the same problem with you. Could you please give any suggestion for me? thank you so much!
#7 Unread post by jcwarner »
if you are using coawst, you can post a message here:
also i suggest you look at the Inlet_test case and the User manual for descriptions on how to set these up.
master
#8 Unread post by master »
I'm running ROMS-SWAN model. I also have the same question. I set up my own application according to the Inlet_test case. Would you please give me any suggestions?
