I am running a case which blows up within 3 months so I want to see the results to detect some details. But I found something that I cannot understand.
There are some variables in dia.nc and his.nc such as 'temp' and 'salt'. They have four dimensions in a format of (xi_rho,eta_rho,s_rho,ocean_time). I want to draw some surface temperature and salt figures at each ocean time steps. However, it does not change along time. Can I ask what 's the reason?
And How can I convert my variables at S coordinate to Z coordinate?
It will be very grateful if someone can answer these questions.
Best Regards
variables don't change at the dimension of time
Re: variables don't change at the dimension of time
If the model is blowing up, it has to be changing in time.
Looking at the surface is looking at the highest k level. To look at other depths, there are codes for computing that in matlab, python, etc. What are you using now?
Dear Kate,
Thank you for your reply.
I am using matlab to plot figures. I chose a s-rho (maximum number =32 for my case) and let stemp=squeeze(temp (:,:,32,:)) . Then I plotted stemp at each ocean_time, but the figures are totally same. I am wondering if I need some key calculations?
Best regards
Best regards
