erro about MPDATA
fereshteh
erro about MPDATA
#1 Unread post by fereshteh »
I am running my test in parallel mode (shared-memory)
TS-MPDATA option is active in header file, so such error appeared in running step:
cannot active option:TS-MPDATA in serial with partitions or shared-memory..
Use distributed-memory (MPI) in parallel run
could you please tell me which option could be use instead of TS-MPDATA in shared-memory?
cheers
fereshte
Re: erro about MPDADA
Any of the other advection schemes should work. Is there any reason you can't use MPI on that shared-memory cluster?
fereshteh
#3 Unread post by fereshteh »
many thanks for your reply. shared-memory is active cluster on my university server.
i used
#define TS_C4VADVECTION
#define TS_C4HADVECTION
Also, in older revision i used #define spline that i think reconstruct vertical diffusion and advection,simultaneously. my test does not have very high vertical resolution (20 layers for maximum depth about 1000 m).So, is it good to use following option?
SPLINES_VDIFF and SPLINES_VVISC
cheers
Fereshte
