Is it a must to use VolCons if RadNud activated?
corvianawatie
#1 Unread post by corvianawatie »
I want to know, if is it a must activate the VolCons if I am using RadNud boundary condition for 3D U,V,T,and S?
I have 4 open boundary conditions, with boundary value from reanalysis ocean model. And I am forcing the model with surface heat flux, freshwater flux (calculated using bulk fluxes). And in the next, I will add wind stress, and I won't use tidal forcing. Maybe anyone can help me to explain how the VolCons doing in the boundary?
!                   W       S       E       N
!                   e       o       a       o
!                   s       u       s       r
!                   t       t       t       t
!                           h               h
!                   1       2       3       4
   LBC(isFsur) ==   Cha     Cha     Cha     Cha         ! free-surface
   LBC(isUbar) ==   Fla     Fla     Fla     Fla         ! 2D U-momentum
   LBC(isVbar) ==   Fla     Fla     Fla     Fla         ! 2D V-momentum
   LBC(isUvel) ==   RadNud  RadNud  RadNud  RadNud      ! 3D U-momentum
   LBC(isVvel) ==   RadNud  RadNud  RadNud  RadNud      ! 3D V-momentum
   LBC(isMtke) ==   Gra     Gra     Gra     Gra         ! mixing TKE
   LBC(isTvar) ==   RadNud  RadNud  RadNud  RadNud \    ! temperature
                    RadNud  RadNud  RadNud  RadNud      ! salinity
! conditions keywords.
ad_LBC(isFsur) ==   Per     Clo     Per     Clo         ! free-surface
ad_LBC(isUbar) ==   Per     Clo     Per     Clo         ! 2D U-momentum
ad_LBC(isVbar) ==   Per     Clo     Per     Clo         ! 2D U-momentum
ad_LBC(isUvel) ==   Per     Clo     Per     Clo         ! 3D U-momentum
ad_LBC(isVvel) ==   Per     Clo     Per     Clo         ! 3D V-momentum
ad_LBC(isMtke) ==   Per     Clo     Per     Clo         ! mixing TKE
ad_LBC(isTvar) ==   Per     Clo     Per     Clo \       ! temperature
                    Per     Clo     Per     Clo         ! salinity
   VolCons(west)  ==  F                           ! western  boundary
   VolCons(east)  ==  F                           ! eastern  boundary
   VolCons(south) ==  F                           ! southern boundary
   VolCons(north) ==  F                           ! northern boundary
ad_VolCons(west)  ==  F                            ! western  boundary
ad_VolCons(east)  ==  F                            ! eastern  boundary
ad_VolCons(south) ==  F                            ! southern boundary
ad_VolCons(north) ==  F                            ! northern boundary
Re: Is it a must to use VolCons if RadNud activated?
I never, ever use VolCons. If you have the Flather boundary condition, the model should not fill or drain excessively - unless of course the zeta boundary conditions you give it suggest that it should fill or drain excessively.
corvianawatie
#3 Unread post by corvianawatie »
Thank you Kate.
venuscheung
#4 Unread post by venuscheung »
I would like to change my boundary condition too
LBC(isFsur) == Clo Cha Cha Cha ! free-surface
LBC(isUbar) == Clo Fla Fla Fla ! 2D U-momentum
LBC(isVbar) == Clo Fla Fla Fla ! 2D V-momentum
however, it gives out error
I also modified my .h file.
upwelling.h
(2.37 KiB) Downloaded 337 times
run.log
(75.62 KiB) Downloaded 325 times
#5 Unread post by kate »
It's blowing up at point 2, 13, 8. Your Courant numbers are getting rather large, so you might start by trying a shorter timestep. You could also look at the fields it has saved for you in the restart file.
       122 2018-01-01 20:20:00.00  3.461952E-03  7.113528E+02  7.113563E+02  5.699591E+12
                     (002,013,10)  1.679782E-01  1.956149E+00  1.810685E+00  4.047855E+00
       123 2018-01-01 20:30:00.00  4.049395E-03  7.113517E+02  7.113557E+02  5.699581E+12
                     (002,012,08)  1.643369E+00  4.621281E+00  6.603845E+00  1.164080E+01
       124 2018-01-01 20:40:00.00  5.038083E-02  7.113511E+02  7.114015E+02  5.699570E+12
                     (002,013,08)  6.699952E+00  5.775705E+01  1.952329E+01  1.316330E+02
 DIAG speed trouble    131.633017309940
 DIAG speed ijk    178.759582292795                2          13           8
#6 Unread post by wilkin »
You can't mix Periodic and Closed on the same boundary for different variables.
zeta 1 Closed Chapman Imp Chapman Imp Chapman Imp
ubar 1 Closed Flather Flather Flather
vbar 1 Closed Flather Flather Flather
u 1 Periodic Closed Periodic Closed
v 1 Periodic Closed Periodic Closed
salt 1 Periodic Closed Periodic Closed
If it's periodic for one it only makes sense to be periodic for all.
venuscheung
#7 Unread post by venuscheung »
I have turn the timestep from 600 to 60 seconds but still there are error
roms_upwelling_cp.in
(137.25 KiB) Downloaded 350 times
run.log
(61.26 KiB) Downloaded 354 times
#8 Unread post by wilkin »
Look at the log file report on the grid ...
ANA_GRID - bathymetry at RHO-points: h
The water depth is zero everywhere!
Which explains why the vertical grid spacing is zero ...
Minimum Z-grid spacing, DZmin = 0.00000000E+00 m
Maximum Z-grid spacing, DZmax = 0.00000000E+00 m
and the grid stiffness ratios are singular ...
Maximum grid stiffness ratios: rx0 = NaN (Beckmann and Haidvogel)
rx1 = NaN (Haney)
venuscheung
#9 Unread post by venuscheung »
wilkin wrote: Fri Nov 15, 2019 3:01 pm Look at the log file report on the grid ...
rx1 = NaN (Haney)
I see the problem.
However, if I change nothing to the boundary conditions, the file can be run sucessfully.
Also, I cant see any problem in my bathymetry file
