DIAG speed trouble
hpd14thu
DIAG speed trouble
#1 Unread post by hpd14thu »
I'm trying to run ROMs by bulk forcing, river forcing and boundary values, but it blows up from the beginning. And ROMS doesn't show the details.
I wonder that which problems can result in this blow-up, then I can have a check.
Thank you!
mab
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler command : /usr/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -ftree-vectorize -ftree-loop-linear -funroll-loops -w -ffree-form -ffree-line-length-none -frecord-marker=4 -fconvert=big-endian
Input Script :
SVN Root URL : https:://myroms.org/svn/src
SVN Revision : 65M
Local Root : /home/ubuntu/app/COAWST_V3.2
Header Dir : /home/ubuntu/app/COAWST_V3.2/Projects/mab
Header file : mab.h
Analytical Dir: /home/ubuntu/app/COAWST_V3.2/Projects/mab
Resolution, Grid 01: 0166x0198x036, Parallel Nodes: 1, Tiling: 001x001
9216 ntimes Number of timesteps for 3-D equations.
150.000 dt Timestep size (s) for 3-D equations.
40 ndtfast Number of timesteps for 2-D equations between
120 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
1 nHIS Number of timesteps between the writing fields
into history file.
time-averaged data.
360 nAVG Number of timesteps between the writing of
2.0000E-01 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
2.0000E-01 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
1.0000E-01 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
0.000 wec_alpha WEC factor for roller/breaking energy distribution.
2.0000E+00 blk_ZQ Height (m) of surface air humidity measurement.
2.0000E+00 blk_ZT Height (m) of surface air temperature measurement.
1 lmd_Jwt Jerlov water type.
50.000 Tcline S-coordinate surface/bottom layer width (m) used
1.0000E+00 Tnudg(01) Nudging/relaxation time scale (days)
1.0000E+00 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
0.0000E+00 Tnudg_SSS Nudging/relaxation time scale (days)
for sea surface salinity.
1.0000E+00 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
1.5000E+00 obcfac Factor between passive and active
T LuvSrc Turning ON momentum point Sources/Sinks.
T LtracerSrc(01) Turning ON point Sources/Sinks on tracer 01: temp
T LtracerSrc(02) Turning ON point Sources/Sinks on tracer 02: salt
T Aout(idSdif) Write out averaged vertical diffusion: AKt(isalt).
Output Restart File: mab_rst.nc
Output History File: mab_his.nc
Output Averages File: mab_avg.nc
Input Grid File: /home/ubuntu/app/COAWST_V3.2/Projects/mab/mab_grid.nc
Input Nonlinear Initial File: /home/ubuntu/app/COAWST_V3.2/Projects/mab/mab_init.nc
Input Sources/Sinks File: /home/ubuntu/app/COAWST_V3.2/Projects/mab/mab_rivers.nc
Input Forcing File 01: /home/ubuntu/app/COAWST_V3.2/Projects/mab/mab_wind.nc
Input Boundary File 01: /home/ubuntu/app/COAWST_V3.2/Projects/mab/mab_boundary.nc
Tile partition information for Grid 01: 0166x0198x0036 tiling: 001x001
tile Istr Iend Jstr Jend Npts
Number of tracers: 2
0 1 166 1 198 1183248
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 166.50 0.50 198.50 RHO-points
0 1.00 166.00 0.50 198.50 U-points
0 0.50 166.50 1.00 198.00 V-points
HaloSizeI(1) = 354
HaloSizeJ(1) = 418
TileSide(1) = 203
TileSize(1) = 34713
ubar 1 Flather Flather Flather Flather
vbar 1 Flather Flather Flather Flather
u 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
v 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
temp 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
salt 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
tke 1 Gradient Gradient Gradient Gradient
MAB mab
ATM_PRESS Impose atmospheric pressure onto sea surface.
BULK_FLUXES Surface bulk fluxes parameterization.
CHARNOK Charnok surface roughness from wind stress.
EMINUSP Compute Salt Flux using E-P.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
Node # 0 (pid= 26220) is active.
36 0.0000000 0.0000000 0.000 0.000 0.000 0.000
35 -0.0277778 -0.0001601 -0.053 -0.698 -1.798 -2.251
34 -0.0555556 -0.0006434 -0.107 -1.405 -4.471 -6.268
33 -0.0833333 -0.0014592 -0.160 -2.120 -8.045 -12.102
32 -0.1111111 -0.0026229 -0.214 -2.843 -12.561 -19.837
31 -0.1388889 -0.0041565 -0.267 -3.576 -18.079 -29.593
30 -0.1666667 -0.0060892 -0.321 -4.319 -24.678 -41.529
29 -0.1944444 -0.0084574 -0.375 -5.073 -32.457 -55.845
28 -0.2222222 -0.0113058 -0.428 -5.838 -41.536 -72.785
27 -0.2500000 -0.0146880 -0.482 -6.617 -52.062 -92.642
26 -0.2777778 -0.0186675 -0.536 -7.411 -64.205 -115.761
25 -0.3055556 -0.0233186 -0.589 -8.222 -78.167 -142.551
24 -0.3333333 -0.0287278 -0.643 -9.052 -94.182 -173.482
23 -0.3611111 -0.0349951 -0.697 -9.903 -112.522 -209.103
22 -0.3888889 -0.0422359 -0.751 -10.778 -133.499 -250.042
21 -0.4166667 -0.0505823 -0.805 -11.681 -157.470 -297.023
20 -0.4444444 -0.0601856 -0.859 -12.616 -184.846 -350.870
19 -0.4722222 -0.0712180 -0.914 -13.586 -216.093 -412.527
18 -0.5000000 -0.0838752 -0.968 -14.597 -251.740 -483.061
17 -0.5277778 -0.0983788 -1.023 -15.654 -292.389 -563.683
16 -0.5555556 -0.1149791 -1.077 -16.763 -338.717 -655.762
15 -0.5833333 -0.1339573 -1.132 -17.932 -391.486 -760.833
14 -0.6111111 -0.1556284 -1.187 -19.168 -451.549 -880.618
13 -0.6388889 -0.1803439 -1.243 -20.481 -519.857 -1017.038
12 -0.6666667 -0.2084930 -1.298 -21.879 -597.467 -1172.218
11 -0.6944444 -0.2405049 -1.354 -23.374 -685.539 -1348.504
10 -0.7222222 -0.2768484 -1.410 -24.977 -785.343 -1548.457
9 -0.7500000 -0.3180318 -1.467 -26.701 -898.257 -1774.856
8 -0.7777778 -0.3645994 -1.524 -28.559 -1025.755 -2030.672
7 -0.8055556 -0.4171263 -1.581 -30.567 -1169.394 -2319.050
6 -0.8333333 -0.4762095 -1.639 -32.739 -1330.792 -2643.251
5 -0.8611111 -0.5424547 -1.698 -35.089 -1511.589 -3006.584
4 -0.8888889 -0.6164579 -1.757 -37.634 -1713.399 -3412.306
3 -0.9166667 -0.6987799 -1.817 -40.386 -1937.742 -3863.481
2 -0.9444444 -0.7899141 -1.877 -43.359 -2185.953 -4362.806
1 -0.9722222 -0.8902454 -1.938 -46.562 -2459.076 -4912.382
0 -1.0000000 -1.0000000 -2.000 -50.000 -2757.723 -5513.446
Time Splitting Weights for Grid 01: ndtfast = 40 nfast = 56
1-0.0006038999279304 0.0250000000000000-0.0006038999279304 0.0250000000000000
2-0.0011053727845635 0.0250150974981983-0.0017092727124939 0.0500150974981983
3-0.0015044206959555 0.0250427318178123-0.0032136934084494 0.0750578293160106
4-0.0018010519301026 0.0250803423352112-0.0050147453385520 0.1001381716512218
5-0.0019952879837948 0.0251253686334638-0.0070100333223467 0.1252635402846856
6-0.0020871735042116 0.0251752508330587-0.0090972068265583 0.1504387911177443
7-0.0020767890452586 0.0252274301706640-0.0111739958718169 0.1756662212884082
8-0.0019642666586465 0.0252793498967954-0.0131382625304634 0.2009455711852036
9-0.0017498083197106 0.0253284565632616-0.0148880708501740 0.2262740277484652
10-0.0014337071879729 0.0253722017712543-0.0163217780381469 0.2516462295197196
11-0.0010163717024450 0.0254080444509537-0.0173381497405919 0.2770542739706733
12-0.0004983525116731 0.0254334537435148-0.0178365022522649 0.3024877277141881
13 0.0001196277614762 0.0254459125563066-0.0177168744907887 0.3279336402704947
14 0.0008366419202876 0.0254429218622697-0.0168802325705011 0.3533765621327644
15 0.0016515227599278 0.0254220058142625-0.0152287098105733 0.3787985679470269
16 0.0025628247984349 0.0253807177452643-0.0126658850121384 0.4041792856922913
17 0.0035687831729657 0.0253166471253035-0.0090971018391727 0.4294959328175947
18 0.0046672697013015 0.0252274275459793-0.0044298321378712 0.4547233603635741
19 0.0058557461086128 0.0251107458034468 0.0014259139707416 0.4798341061670209
20 0.0071312144194823 0.0249643521507315 0.0085571283902239 0.5047984583177524
21 0.0084901645151857 0.0247860717902444 0.0170472929054096 0.5295845301079968
22 0.0099285188562319 0.0245738176773648 0.0269758117616416 0.5541583477853615
23 0.0114415743701613 0.0243256047059590 0.0384173861318028 0.5784839524913206
24 0.0130239415046020 0.0240395653467049 0.0514413276364049 0.6025235178380255
25 0.0146694804455855 0.0237139668090899 0.0661108080819904 0.6262374846471154
26 0.0163712345011199 0.0233472297979502 0.0824820425831103 0.6495847144450656
27 0.0181213606500220 0.0229379489354222 0.1006034032331323 0.6725226633804878
28 0.0199110572560077 0.0224849149191717 0.1205144604891400 0.6950075782996595
29 0.0217304889470413 0.0219871384877715 0.1422449494361813 0.7169947167874310
30 0.0235687086599425 0.0214438762640955 0.1658136580961238 0.7384385930515265
31 0.0254135768502523 0.0208546585475969 0.1912272349463761 0.7592932515991234
32 0.0272516778673573 0.0202193191263406 0.2184789128137333 0.7795125707254640
33 0.0290682334948725 0.0195380271796567 0.2475471463086058 0.7990505979051207
34 0.0308470136562825 0.0188113213422849 0.2783941599648883 0.8178619192474056
35 0.0325702442858409 0.0180401460008778 0.3109644042507291 0.8359020652482834
36 0.0342185123647286 0.0172258898937318 0.3451829166154578 0.8531279551420151
37 0.0357706681224704 0.0163704270846136 0.3809535847379282 0.8694983822266287
38 0.0372037244036097 0.0154761603815518 0.4181573091415379 0.8849745426081804
39 0.0384927531996420 0.0145460672714616 0.4566500623411799 0.8995206098796420
40 0.0396107793462069 0.0135837484414705 0.4962608416873868 0.9131043583211125
41 0.0405286713855386 0.0125934789578153 0.5367895130729254 0.9256978372789278
42 0.0412150295941741 0.0115802621731769 0.5780045426670996 0.9372780994521047
43 0.0416360711759210 0.0105498864333225 0.6196406138430206 0.9478279858854273
44 0.0417555126200830 0.0095089846539245 0.6613961264631036 0.9573369705393517
45 0.0415344492249439 0.0084650968384224 0.7029305756880475 0.9658020673777742
46 0.0409312317865102 0.0074267356077988 0.7438618074745578 0.9732288029855730
47 0.0399013404525124 0.0064034548131361 0.7837631479270702 0.9796322577987091
48 0.0383972557416642 0.0054059213018233 0.8221604036687344 0.9850381791005324
49 0.0363683267281804 0.0044459899082817 0.8585287303969148 0.9894841690088140
50 0.0337606363915535 0.0035367817400771 0.8922893667884684 0.9930209507488911
51 0.0305168641315885 0.0026927658302883 0.9228062309200569 0.9957137165791794
52 0.0265761454486959 0.0019298442269986 0.9493823763687528 0.9976435608061780
53 0.0218739287894439 0.0012654405907812 0.9712563051581966 0.9989090013969592
54 0.0163418295573680 0.0007185923710451 0.9875981347155646 0.9996275937680043
55 0.0099074812890402 0.0003100466321109 0.9975056160046047 0.9999376404001151
56 0.0024943839953957 0.0000623595998849 1.0000000000000004 1.0000000000000000
ndtfast, nfast = 40 56 nfast/ndtfast = 1.40000
1.000000000000 1.039265571007 0.519632785503 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.21300
Minimum X-grid spacing, DXmin = 4.68165556E+00 km
Maximum X-grid spacing, DXmax = 5.28701590E+00 km
Minimum Y-grid spacing, DYmin = 5.03543630E+00 km
Maximum Y-grid spacing, DYmax = 5.03543631E+00 km
Minimum Z-grid spacing, DZmin = 5.34311187E-02 m
Maximum Z-grid spacing, DZmax = 6.01063990E+02 m
Minimum barotropic Courant Number = 4.59023827E-03
Maximum barotropic Courant Number = 2.39919205E-01
Maximum Coriolis Courant Number = 1.46732585E-02
(Grid 01, File: mab_init.nc, Rec=0001, Index=1)
- free-surface
(Min = -5.15861928E-01 Max = 1.01138091E+00)
(Min = -4.19422179E-01 Max = 1.48187801E-01)
- u-momentum component
(Min = -8.79346848E-01 Max = 1.79157114E+00)
- v-momentum component
(Min = -1.20992875E+00 Max = 1.26725924E+00)
- potential temperature
(Min = -1.39353603E-01 Max = 3.04190636E+01)
- salinity
(Min = 0.00000000E+00 Max = 3.68937263E+01)
GET_NGFLD - river runoff XI-positions at RHO-points
(Min = 1.60000000E+01 Max = 6.40000000E+01)
GET_NGFLD - river runoff ETA-positions at RHO-points
(Min = 4.40000000E+01 Max = 1.66000000E+02)
GET_NGFLD - river runoff direction
(Min = 0.00000000E+00 Max = 1.00000000E+00)
GET_NGFLD - river runoff mass transport vertical profile
(Min = 2.77777778E-02 Max = 2.77777778E-02)
GET_NGFLD - river runoff mass transport, t = 0 00:00:00
(Rec=0000001, Index=2, File: mab_rivers.nc)
(Tmin= 0.0000 Tmax= 16.0000)
(Min = -4.24755000E+02 Max = 6.96598200E+01)
GET_NGFLD - river runoff potential temperature, t = 0 00:00:00
(Min = 2.28000000E+01 Max = 2.74000000E+01)
GET_NGFLD - river runoff salinity, t = 0 00:00:00
GET_2DFLD - surface u-wind component, t = 0 00:00:00
(Rec=0000001, Index=1, File: mab_wind.nc)
(Min = -2.48879018E+00 Max = 9.48846082E+00)
GET_2DFLD - surface v-wind component, t = 0 00:00:00
(Min = -3.85694262E+00 Max = 8.27674899E+00)
GET_2DFLD - surface air pressure, t = 0 00:00:00
(Min = 9.41213884E+02 Max = 1.02045113E+03)
GET_2DFLD - surface air temperature, t = 0 00:00:00
(Min = 1.99932619E+01 Max = 2.83775444E+01)
GET_2DFLD - surface air relative humidity, t = 0 00:00:00
(Min = 6.49802349E-01 Max = 9.73909050E-01)
GET_2DFLD - solar shortwave radiation flux, t = 0 00:00:00
(Min = 5.84608824E-05 Max = 1.85498452E-04)
GET_2DFLD - net longwave radiation flux, t = 0 00:00:00
(Min = -3.63744317E-05 Max = 8.11468262E-07)
GET_2DFLD - rain fall rate, t = 0 00:00:00
(Min = -7.73038670E-05 Max = 6.48162364E-04)
GET_NGFLD - free-surface western boundary condition, t = 0 00:00:00
(Rec=0000001, Index=2, File: mab_boundary.nc)
GET_NGFLD - free-surface eastern boundary condition, t = 0 00:00:00
GET_NGFLD - free-surface southern boundary condition, t = 0 00:00:00
GET_NGFLD - free-surface northern boundary condition, t = 0 00:00:00
GET_NGFLD - 2D u-momentum western boundary condition, t = 0 00:00:00
(Min = 0.00000000E+00 Max = 3.87438655E-01)
GET_NGFLD - 2D v-momentum western boundary condition, t = 0 00:00:00
(Min = -3.00609842E-02 Max = 2.07886964E-01)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 0 00:00:00
(Min = -2.73493677E-01 Max = 3.81799936E-01)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 0 00:00:00
(Min = -2.91124165E-01 Max = 7.67858148E-01)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 0 00:00:00
(Min = -5.40703654E-01 Max = 6.88199878E-01)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 0 00:00:00
(Min = -2.17271268E-01 Max = 5.99525034E-01)
GET_NGFLD - 2D u-momentum northern boundary condition, t = 0 00:00:00
(Min = -4.79301214E-02 Max = 1.39712080E-01)
GET_NGFLD - 2D v-momentum northern boundary condition, t = 0 00:00:00
(Min = -2.22154427E-02 Max = 1.26435488E-01)
GET_NGFLD - 3D u-momentum western boundary condition, t = 0 00:00:00
(Min = -2.54327916E-02 Max = 4.86692816E-01)
GET_NGFLD - 3D v-momentum western boundary condition, t = 0 00:00:00
(Min = -6.77571893E-02 Max = 2.64625221E-01)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 0 00:00:00
(Min = -7.07323015E-01 Max = 1.51773870E+00)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 0 00:00:00
(Min = -5.39381504E-01 Max = 1.03494978E+00)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 0 00:00:00
(Min = -7.26773083E-01 Max = 1.13102090E+00)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 0 00:00:00
(Min = -4.80627805E-01 Max = 8.61527681E-01)
GET_NGFLD - 3D u-momentum northern boundary condition, t = 0 00:00:00
(Min = -2.25189328E-01 Max = 1.75515458E-01)
GET_NGFLD - 3D v-momentum northern boundary condition, t = 0 00:00:00
(Min = -7.26434067E-02 Max = 2.17351064E-01)
GET_NGFLD - temperature western boundary condition, t = 0 00:00:00
(Min = 0.00000000E+00 Max = 2.93972244E+01)
GET_NGFLD - salinity western boundary condition, t = 0 00:00:00
(Min = 0.00000000E+00 Max = 3.63715286E+01)
GET_NGFLD - temperature eastern boundary condition, t = 0 00:00:00
(Min = 0.00000000E+00 Max = 2.84820652E+01)
GET_NGFLD - salinity eastern boundary condition, t = 0 00:00:00
(Min = 0.00000000E+00 Max = 3.66891594E+01)
GET_NGFLD - temperature southern boundary condition, t = 0 00:00:00
(Min = 0.00000000E+00 Max = 2.95831852E+01)
GET_NGFLD - salinity southern boundary condition, t = 0 00:00:00
(Min = 0.00000000E+00 Max = 3.67100487E+01)
GET_NGFLD - temperature northern boundary condition, t = 0 00:00:00
(Min = 0.00000000E+00 Max = 2.05079613E+01)
GET_NGFLD - salinity northern boundary condition, t = 0 00:00:00
(Min = 0.00000000E+00 Max = 3.45250435E+01)
Maximum grid stiffness ratios: rx0 = 1.000000E-01 (Beckmann and Haidvogel)
rx1 = 6.279593E+00 (Haney)
Initial basin volumes: TotVolume = 1.5937623726E+15 m3
MinVolume = 1.2613937078E+06 m3
MaxVolume = 1.5952114150E+10 m3
Max/Min = 1.2646419632E+04
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00009216)
GET_NGFLD - river runoff mass transport, t = 1 00:00:00
(Rec=0000002, Index=1, File: mab_rivers.nc)
(Min = -4.07764800E+02 Max = 6.99429900E+01)
GET_NGFLD - river runoff potential temperature, t = 1 00:00:00
(Min = 2.28000000E+01 Max = 2.86000000E+01)
GET_NGFLD - river runoff salinity, t = 1 00:00:00
GET_2DFLD - surface u-wind component, t = 0 00:30:00
(Rec=0000002, Index=2, File: mab_wind.nc)
(Min = -2.67755614E+00 Max = 9.68387638E+00)
GET_2DFLD - surface v-wind component, t = 0 00:30:00
(Min = -3.95093540E+00 Max = 7.99857274E+00)
GET_2DFLD - surface air pressure, t = 0 00:30:00
(Min = 9.41149331E+02 Max = 1.02057863E+03)
GET_2DFLD - surface air temperature, t = 0 00:30:00
(Min = 2.01950278E+01 Max = 2.84300235E+01)
GET_2DFLD - surface air relative humidity, t = 0 00:30:00
(Min = 5.93761673E-01 Max = 9.72107867E-01)
GET_2DFLD - solar shortwave radiation flux, t = 0 00:30:00
(Min = 6.46495803E-05 Max = 1.92980171E-04)
GET_2DFLD - net longwave radiation flux, t = 0 00:30:00
(Min = -3.78018656E-05 Max = 3.42369378E-07)
GET_2DFLD - rain fall rate, t = 0 00:30:00
(Min = -6.36967807E-05 Max = 6.65809200E-04)
GET_NGFLD - free-surface western boundary condition, t = 0 00:30:00
(Rec=0000002, Index=1, File: mab_boundary.nc)
GET_NGFLD - free-surface eastern boundary condition, t = 0 00:30:00
GET_NGFLD - free-surface southern boundary condition, t = 0 00:30:00
GET_NGFLD - free-surface northern boundary condition, t = 0 00:30:00
GET_NGFLD - 2D u-momentum western boundary condition, t = 0 00:30:00
(Min = 0.00000000E+00 Max = 3.93966287E-01)
GET_NGFLD - 2D v-momentum western boundary condition, t = 0 00:30:00
(Min = -4.13958170E-02 Max = 2.13748202E-01)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 0 00:30:00
(Min = -2.73708850E-01 Max = 3.80629003E-01)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 0 00:30:00
(Min = -2.49451026E-01 Max = 7.85718977E-01)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 0 00:30:00
(Min = -5.48984230E-01 Max = 6.93641663E-01)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 0 00:30:00
(Min = -2.17264503E-01 Max = 5.96684694E-01)
GET_NGFLD - 2D u-momentum northern boundary condition, t = 0 00:30:00
(Min = -4.58427779E-02 Max = 1.48350596E-01)
GET_NGFLD - 2D v-momentum northern boundary condition, t = 0 00:30:00
(Min = -2.49377657E-02 Max = 1.22255221E-01)
GET_NGFLD - 3D u-momentum western boundary condition, t = 0 00:30:00
(Min = -2.09561586E-02 Max = 4.87650812E-01)
GET_NGFLD - 3D v-momentum western boundary condition, t = 0 00:30:00
(Min = -8.43785405E-02 Max = 2.72036523E-01)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 0 00:30:00
(Min = -6.84598923E-01 Max = 1.49319148E+00)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 0 00:30:00
(Min = -5.40083051E-01 Max = 1.02259660E+00)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 0 00:30:00
(Min = -7.36855447E-01 Max = 1.12686682E+00)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 0 00:30:00
(Min = -4.84302938E-01 Max = 8.56351137E-01)
GET_NGFLD - 3D u-momentum northern boundary condition, t = 0 00:30:00
(Min = -2.02859089E-01 Max = 1.92000151E-01)
GET_NGFLD - 3D v-momentum northern boundary condition, t = 0 00:30:00
(Min = -8.37866589E-02 Max = 2.36102208E-01)
GET_NGFLD - temperature western boundary condition, t = 0 00:30:00
(Min = 0.00000000E+00 Max = 2.94202271E+01)
GET_NGFLD - salinity western boundary condition, t = 0 00:30:00
(Min = 0.00000000E+00 Max = 3.63712006E+01)
GET_NGFLD - temperature eastern boundary condition, t = 0 00:30:00
(Min = 0.00000000E+00 Max = 2.84867821E+01)
GET_NGFLD - salinity eastern boundary condition, t = 0 00:30:00
(Min = 0.00000000E+00 Max = 3.66894455E+01)
GET_NGFLD - temperature southern boundary condition, t = 0 00:30:00
(Min = 0.00000000E+00 Max = 2.95820427E+01)
GET_NGFLD - salinity southern boundary condition, t = 0 00:30:00
(Min = 0.00000000E+00 Max = 3.67096710E+01)
GET_NGFLD - temperature northern boundary condition, t = 0 00:30:00
(Min = 0.00000000E+00 Max = 2.05952473E+01)
GET_NGFLD - salinity northern boundary condition, t = 0 00:30:00
(Min = 0.00000000E+00 Max = 3.45262375E+01)
0 0 00:00:00 3.853334E-02 2.104765E+04 2.104769E+04 1.594152E+15
(093,078,28) 4.597547E-02 3.116953E-02 0.000000E+00 1.872812E+00
DEF_HIS - creating history file, Grid 01: mab_his.nc
DEF_AVG - creating average file, Grid 01: mab_avg.nc
1 0 00:02:30 NaN NaN NaN NaN
(000,000,00) 0.000000E+00 0.000000E+00 0.000000E+00 NaN
DIAG speed trouble NaN
WRT_RST - wrote re-start fields (Index=1,2) into time record = 0000001
Node # 0 CPU: 1.870
Total: 1.870
Allocation and array initialization .............. 0.124 ( 6.6262 %)
Ocean state initialization ....................... 0.020 ( 1.0781 %)
Reading of input data ............................ 0.040 ( 2.1340 %)
Processing of input data ......................... 0.001 ( 0.0588 %)
Processing of output time averaged data .......... 0.000 ( 0.0034 %)
Computation of vertical boundary conditions ...... 0.001 ( 0.0573 %)
Computation of global information integrals ...... 0.014 ( 0.7221 %)
Writing of output data ........................... 0.233 (12.4585 %)
Model 2D kernel .................................. 0.211 (11.2898 %)
2D/3D coupling, vertical metrics ................. 0.022 ( 1.1747 %)
Omega vertical velocity .......................... 0.009 ( 0.5021 %)
Equation of state for seawater ................... 0.059 ( 3.1786 %)
Atmosphere-Ocean bulk flux parameterization ...... 0.064 ( 3.4340 %)
GLS vertical mixing parameterization ............. 0.468 (25.0481 %)
3D equations right-side terms .................... 0.027 ( 1.4612 %)
3D equations predictor step ...................... 0.097 ( 5.1795 %)
Pressure gradient ................................ 0.016 ( 0.8332 %)
Harmonic mixing of tracers, geopotentials ........ 0.025 ( 1.3593 %)
Harmonic stress tensor, S-surfaces ............... 0.013 ( 0.6728 %)
Corrector time-step for 3D momentum .............. 0.037 ( 1.9942 %)
Corrector time-step for tracers .................. 0.029 ( 1.5679 %)
Total: 1.511 80.8339
Message Passage: 2D halo exchanges ............... 0.001 ( 0.0438 %)
Message Passage: 3D halo exchanges ............... 0.000 ( 0.0032 %)
Message Passage: 4D halo exchanges ............... 0.000 ( 0.0006 %)
Message Passage: data broadcast .................. 0.002 ( 0.1176 %)
Message Passage: data reduction .................. 0.000 ( 0.0020 %)
Message Passage: data gathering .................. 0.053 ( 2.8338 %)
Message Passage: data scattering.................. 0.021 ( 1.1433 %)
Total: 0.077 4.1443
All percentages are with respect to total time = 1.870
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/TOMS: DONE... Tuesday - September 10, 2019 - 6:37:41 PM
Re: DIAG speed trouble
you have several options activated. suggest you try a more simple first approach and then add complexity. Try it without the river forcings and maybe without the volcons stuff and see if that works to start.
lizhicheng
#3 Unread post by lizhicheng »
I also find the nan; I change the initial state some times, but still in the step 362 blow up.
360 2017-01-02 00:00:00.00 4.248238E-02 7.014599E+02 7.015024E+02 4.461919E+13
(264,057,01) 1.373269E-02 4.212748E-02 1.065118E+00 2.235862E+00
WRT_HIS - wrote history fields (Index=1,1) in record = 0000025
WRT_AVG - wrote averaged fields in record = 0000001
GET_NGFLD - river runoff mass transport, 2000-01-08 00:00:00.00
(Grid= 01, Rec=0000008, Index=1, File: create-river_daily2017_cycle_add9rivers_30layers-15-change-huanghe-1996coastl_dye.nc)
(Tmin= 0.0000 Tmax= 364.0000) t = 7.0000
(Min = -1.27772940E+23 Max = 2.81650723E-37)
GET_NGFLD - river runoff potential temperature, 2000-01-08 00:00:00.00
(Min = -3.60683066E+28 Max = 1.24658598E+11)
GET_NGFLD - river runoff salinity, 2000-01-08 00:00:00.00
(Min = -2.35343828-185 Max = -2.35343828-185)
GET_2DFLD - surface u-momentum stress, 2000-01-07 06:00:00.00
(Grid=01, Rec=0000026, Index=1, File: byecs_smsUstr_from_windu_ana6hr_1993_cycle.nc)
(Tmin= 0.0000 Tmax= 364.7500) t = 6.2500
(Min = -1.53729570E-06 Max = 5.40840912E-05) regrid = T
GET_2DFLD - surface v-momentum stress, 2000-01-07 06:00:00.00
(Grid=01, Rec=0000026, Index=1, File: byecs_smsVstr_from_windv_ana6hr_1993_cycle.nc)
(Min = -9.69953848E-05 Max = -2.60725450E-06) regrid = T
361 2017-01-02 00:04:00.00 4.294329E-02 7.014896E+02 7.015326E+02 4.462479E+13
(264,057,01) 1.344975E-02 4.154651E-02 1.049825E+00 2.224724E+00
362 2017-01-02 00:08:00.00 NaN NaN NaN NaN
(264,057,01) 1.314301E-02 4.086271E-02 1.032439E+00 0.000000E+00
Found Error: 01 Line: 298 Source: ROMS/Nonlinear/main3d.F
Found Error: 01 Line: 298 Source: ROMS/Drivers/nl_ocean.h
WRT_RST - wrote re-start fields (Index=1,1) in record = 0000001
How did you make your rivers file? I don't like your min/max values at all.
lizhicheng
#5 Unread post by lizhicheng »
THANKS for your reply;
I run one case sucessfully which uses current coastline before. However, I change the grid using old coastline, initial file and river file because of river location.
