depth of assimilated data
xavierC
#1 Unread post by xavierC »
I am assimilating near surface current data with I4DVAR capability of ROMS. I noticed that the rejection of my data is strongly dependent from the depth i put them:
i.e
-pure surface (obs_depth=0) i get 100% data rejected
-obs_depth=-7 i get almost 100% of data accepted
-obs_depth=-1 i get around 30% of data rejected
My data are not particularly littoral with minimum depth of few 100 meters and 35 vertical levels.
I understood more or less the 0 case, but why such a difference between 7m and 1m ?
Xavier
xavierC
Re: depth of assimilated data
#2 Unread post by xavierC »
I guess it is zeta related and that obs_depth is absolute and not relative to zeta.
jivica
#3 Unread post by jivica »
ROMS is not black box model, and it is very well documented. In that sense you should dig into the source and, for example, have a look at the Utility/extract_obs.F
There you will find relevant part of the code:
          p2=REAL(i2-i1,r8)*(Xobs(iobs)-REAL(i1,r8))
          q2=REAL(j2-j1,r8)*(Yobs(iobs)-REAL(j1,r8))
          p1=1.0_r8-p2
          q1=1.0_r8-q2
          w11=p1*q1
          w21=p2*q1
          w22=p2*q2
          w12=p1*q2
          IF (Zobs(iobs).gt.0.0_r8) THEN
            k1=MAX(1,INT(Zobs(iobs)))          ! Positions in fractional
            k2=MIN(INT(Zobs(iobs))+1,N(ng))    ! levels
            r2=REAL(k2-k1,r8)*(Zobs(iobs)-REAL(k1,r8))
            r1=1.0_r8-r2
          ELSE
            Ztop=Adepth(i1,j1,N(ng))
            Zbot=Adepth(i1,j1,1    )
            IF (Zobs(iobs).ge.Ztop) THEN
              r1=0.0_r8                        ! If shallower, ignore.
              r2=0.0_r8
              ObsScale(iobs)=0.0_r8
            ELSE IF (Zbot.ge.Zobs(iobs)) THEN
              r1=0.0_r8                        ! If deeper, ignore.
              r2=0.0_r8
            ELSE
              DO k=N(ng),2,-1                  ! Otherwise, interpolate
                Ztop=Adepth(i1,j1,k  )         ! to fractional level
                Zbot=Adepth(i1,j1,k-1)
                IF ((Ztop.gt.Zobs(iobs)).and.(Zobs(iobs).ge.Zbot)) THEN
                  k1=k-1
                  k2=k
              dz=Adepth(i1,j1,k2)-Adepth(i1,j1,k1)
              r2=(Zobs(iobs)-Adepth(i1,j1,k1))/dz
              r1=1.0_r8-r2
              Zobs(iobs)=REAL(k1,r8)+r2        ! overwrite
And for example, if you have really huge range of tides and don't want ROMS to reject obs then simply change the part of code or compute zlev (model level fraction) of your obs and feed that into assimilation...
Good luck
Ivica
