How to adjust roms temperature with observation (Bias)
azamocndu
#1 Unread post by azamocndu »
My model result is not good enough. Salinity is not a big problem but Temperature(within 50-200 meters’ depth) is the main problem (low:3 to 4 degrees C).
I'm giving details to express my problem in easier way. Sorry for your time.
I'm using MY2.5 scheme,
AKT_BAK == 1.0d-6 1.0d-6 ! m2/s
AKV_BAK == 1.0d-5 ! m2/s
AKK_BAK == 5.0d-6 ! m2/s
AKP_BAK == 5.0d-6 ! m2/s
TKENU2 == 0.0d0 ! m2/s
TKENU4 == 0.0d0 ! m4/s
TNU2 == 0.0d0 0.0d0 ! m2/s
TNU4 == 2*0.0d0 ! m4/s
ad_TNU2 == 0.0d0 0.0d0 ! m2/s
ad_TNU4 == 0.0d0 0.0d0 ! m4/s
! and adjoint-based algorithms: [Ngrids]..
VISC2 == 5.0d0 ! m2/s
VISC4 == 0.0d0 ! m4/s
ad_VISC2 == 0.0d0 ! m2/s
ad_VISC4 == 0.0d0 ! m4/s
 Basin averaged temperature (T) of model is 0.5ºC lower (vertically mean) and hence it is lower in all depth than SODA data. Suddenly T is 2-3ºC lower in model within the depth of 55-98m. But the T difference gradually reduces with the increase of the depth after 200m. (higher mixing might solve the problem?)
## I have attached some of output figure and description for details. kindly see.
## I have increased AKT_BAK and also Turbulence closure par (AKK_BAK AND AKP_BAK) by two decimal from the stated above to see if it increase mixing. Yes, model 2nd year result shows huge increase of mixing. But it doesn't increase 50-200 meters depths temperature that much. surface T is reduced a lot. How to reduce the Bias of the upper 200m? my focus on upper layer study.
I'm hanging with this problem for long time.
I will be very glad somebody help me out.
Azam
compare model with SODA data.docx
(1.53 MiB) Downloaded 348 times
Re: How to adjust roms temperature with observation (Bias)
You've told us about your vertical and horizontal diffusion, but what is the vertical boundary condition? In other words, the surface heat flux? Can you output it and look at it? Is it computed internally (bulk fluxes) or provided externally?
azamocndu
#3 Unread post by azamocndu »
kate wrote:You've told us about your vertical and horizontal diffusion, but what is the vertical boundary condition? In other words, the surface heat flux? Can you output it and look at it? Is it computed internally (bulk fluxes) or provided externally?
Hi Kate
Yes, I have used COADS climatology atmospheric forcing.
My .h file:
/* atomosphere forcing: */
#define QCORRECTION
#define SCORRECTION
