benchmark case running problem
ywang152
#1 Unread post by ywang152 »
I have one problem when I run benchmark case with oceanM: It seems the "Header file" and "Header directory" showing in the output log file of running, are immutable... I pasted the content of it:
Benchmark Test, Idealized Southern Ocean, Small Grid
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler command : /opt/openmpi401/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
Input Script : ocean_benchmark1.in
SVN Revision : 904M
Local Root : /home/ywang/roms/trunk
Header Dir : /home/ywang/roms/Projects/Upwelling
Header file : upwelling.h
Analytical Dir: /home/ywang/roms/Projects/Upwelling
After checking, I am sure the build.bash has the right path of $MY_PROJECT_DIR, and the $ROMS_APPLICATION is BENCHMARK, corresponding to benchmark.h. Please find attachment to see the build.bash file.
What I did was:
I finished compilation, which gave me the executable file oceanM, and run it with command: mpirun -np 4 oceanM ocean_benchmark1.in > test1_oceanM.log.
Then, I got blow up error after seconds:
 Analytical header files used:
     ROMS/Functionals/ana_btflux.h
     ROMS/Functionals/ana_grid.h
     ROMS/Functionals/ana_smflux.h
     ROMS/Functionals/ana_stflux.h
     ROMS/Functionals/ana_vmix.h
 Found Error: 01   Line: 350      Source: ROMS/Utility/close_io.F
 ROMS/TOMS - Blows up ................ exit_flag:   1
I saw someone got the same problem because the header file is not right, and I have the same mistake. But my re-compilation didn't work at all. Running the output oceanM keep showing the wrong header path and header file.
Thanks for your help in advance!
Best regards
Yifan
test1_oceanM.log
(28.8 KiB) Downloaded 629 times
build.bash
(17.78 KiB) Downloaded 609 times
ywang152
Re: benchmark case running problem
#2 Unread post by ywang152 »
Hello everyone,
I would like to add some additional information:
I tried to compile and run benchmark case with oceanS and everything looked fine. It finished after 167 seconds. Also tried oceanG (compiled with the same build.bash file but opened "USE_DEBUG=on"), which was finished after 1600 seconds, with some error messages:
[ywang@riis retest_Benchmark]$ mpirun -np 4 oceanG ocean_benchmark1.in > test1_oceanG.log
Program received signal 8 (SIGFPE): Floating-point exception.
Backtrace for this error:
  + /lib64/libc.so.6() [0x3adc632510]
  + function wclock_off_ (0x496C5D)
    at line 238 of file timers.f90
  + function __ocean_control_mod_MOD_roms_finalize (0x403C51)
    at line 245 of file ocean_control.f90
  + in the main program
    at line 116 of file master.f90
  + /lib64/libc.so.6(__libc_start_main+0xfd) [0x3adc61ed1d]
Primary job  terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
  Process name: [[40721,1],2]
  Exit code:    5
The header path and header name problem didn't happen when I use oceanS and oceanG. It seems only when I try to run benchmark case with oceanM,the header path and name will be the same as that of Upwelling case. The error message got after running oceanG may be the clue.
I would be appreciated if anyone could give me some input. Thank you.
Best regards
Yifan
