Please note the deadline for applications for the below position has been extended to the 2nd of April.
Below and attached are details regarding an open position for a Project Coordinator - Copernicus Marine Biogeochemistry within the Marine Institute based in Galway, Ireland. It is a 2 year position. Please see below and attached job advert for more details:
As the Temporary Project Co-ordinator, your main responsibility will be to ensure delivery of the validation of the Copernicus Marine Environment Monitoring Service (CMEMS) biogeochemical models of Iberia-Biscay-Ireland region. You will work closely with Mercator Ocean who are the international partner for this project. As the Project Co-ordinator, you will contribute to the validation and reanalysis and forecasting systems of marine bio-geochemistry used in IBI-MFC, will work on the development of the validation toolbox, Ocean Monitoring Indicators and for the Ocean State Report and will prepare Quality Information Documents (QUID).
More details on the duties, qualifications and skills required can be found in the attached job description.
Vacancy at Marine Institute, Ireland - Copernicus Service
- Final JD - HEO Copernicus Marine Biogeochemistry - Feb 2019_0.pdf
- (658.32 KiB) Downloaded 645 times
