Roms Upwelling testing case
Lightness
#1 Unread post by Lightness »
I am a new user to ROMS but interested to use it in my PhD studies. I downloaded the codes by MobaXterm but through following the instruction of running Upwelling testing case the names and codes which I have in ROMS external folder do not match with that of roms wiki. For example I have roms_Upwelling.in instead of Ocean_Upwelling.in. The file also does not have this part of the code
else
export NETCDF_INCDIR=/opt/gfortransoft/serial/netcdf3/include
export NETCDF_LIBDIR=/opt/gfortransoft/serial/netcdf3/lib
fi
Can you kindly help what went wrong!
Kosa
Re: Roms Upwelling testing case
#2 Unread post by Kosa »
When you downloaded the ROMS trunk, you got the latest version. There have been some naming changes that are not reflected in the wiki yet but roms_Upwelling.in and ocean_Upwelling.in are effectively the same, just with a different filename. That particular change is only a few weeks old: https://www.myroms.org/projects/src/ticket/794. If you're determined to have the same default filenames as in the wiki, you could download a previous subversion of the code.
Aminrahdarian
#3 Unread post by Aminrahdarian »
Hi ,
You may find the attached pdf file useful .
Regards ,
Amin
RomsGetStart.pdf
(110.99 KiB) Downloaded 516 times
