new version about a non_zero exit code
lizhicheng
#1 Unread post by lizhicheng »
Dear all
Recently I downloaded the latest version of ROMS ,but it occurs some error.The log file is:
Monday - January 14, 2019 - 10:29:03 PM
FOU
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : /public/app/openmpi-1.8.2/intel-14.0.1/bin/mpif90
Compiler flags : -fp-model precise -ip -O3
MPI Communicator : 0 PET size = 192
Input Script : fou.in
SVN Revision : 931M
Local Root : /public/home/lizhicheng/src/ROMS2018L
Header Dir : /public/home/lizhicheng/project/fou
Header file : fou.h
Analytical Dir: /public/home/lizhicheng/project/fou
Resolution, Grid 01: 286x322x30, Parallel Nodes: 192, Tiling: 12x16
789120 ntimes Number of timesteps for 3-D equations.
120.000 dt Timestep size (s) for 3-D equations.
into restart fields.
to standard output.
into history file.
10800 ndefHIS Number of timesteps between creation of new
history files.
538976288 nQCK Number of timesteps between the writing fields
into quicksave file.
time-averaged data.
720 nAVG Number of timesteps between the writing of
10800 ndefAVG Number of timesteps between creation of new
time-averaged file.
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
1.5000E-03 rdrg2 Quadratic bottom drag coefficient.
1.0000E-03 Zob Bottom roughness (m).
4.0000E+00 theta_s S-coordinate surface control parameter.
3.0000E+00 theta_b S-coordinate bottom control parameter.
5.000 Tcline S-coordinate surface/bottom layer width (m) used
5114.000 dstart Time-stamp assigned to model initialization (days).
20000101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
2.0000E+01 Tnudg(01) Nudging/relaxation time scale (days)
2.0000E+01 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
2.0000E+01 Znudg Nudging/relaxation time scale (days)
2.0000E+01 M2nudg Nudging/relaxation time scale (days)
2.0000E+01 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
6.0000E+01 obcfac Factor between passive and active
of State.
of State.
T LuvSrc Turning ON momentum point Sources/Sinks.
T LtracerSrc(01) Turning ON point Sources/Sinks on tracer 01: temp
T LtracerSrc(02) Turning ON point Sources/Sinks on tracer 02: salt
T Hout(idu3dE) Write out 3D U-wastward component at RHO-points.
T Hout(idv3dN) Write out 3D V-northward component at RHO-points.
T Aout(idu3dE) Write out averaged 3D U-eastward at RHO-points.
T Aout(idv3dN) Write out averaged 3D V-northward at RHO-points.
Output Restart File: /public/home/lizhicheng/outputs/fou/fou_rst.nc
Prefix for History Files: /public/home/lizhicheng/outputs/fou/fou_his
Prefix for Averages Files: /public/home/lizhicheng/outputs/fou/fou_avg
Input Grid File: /public/home/lizhicheng/forcing_qsm/grid_BH1.nc
Input Nonlinear Initial File: /public/home/lizhicheng/forcing_qsm/2005to2017/INI/create-ini_woa_bio_restart_2014.nc
Input Sources/Sinks File: /public/home/lizhicheng/forcing_qsm/2005to2017/create-river_daily19900101-20171231_add9rivers_30layers-15-change-huanghe.nc
Input Forcing File 01: /public/home/lizhicheng/forcing_qsm/atm_forcing/create-frc-dqdsst_2000-2019.nc
Input Forcing File 02: /public/home/lizhicheng/forcing_qsm/2005to2017/byecs_swrad_era_1990-2017.nc
Input Forcing File 03: /public/home/lizhicheng/forcing_qsm/2005to2017/byecs_swflux_era_2005-2017.nc
Input Forcing File 04: /public/home/lizhicheng/forcing_qsm/2005to2017/byecs_shflux_era_1990-2017.nc
Input Forcing File 05: /public/home/lizhicheng/forcing_qsm/2005to2017/byecs_smsUstr_from_windu_ana6hr_1990-2017.nc
Input Forcing File 06: /public/home/lizhicheng/forcing_qsm/2005to2017/byecs_smsVstr_from_windv_ana6hr_1990-2017.nc
Input Boundary File: /public/home/lizhicheng/forcing_qsm/2005to2017/create-bry_monthly2005-2017_30layers_hycom-15.nc
Tile partition information for Grid 01: 286x322x30 tiling: 12x16
tile Istr Iend Jstr Jend Npts
0 1 23 1 14 9660
1 24 47 1 14 10080
2 48 71 1 14 10080
3 72 95 1 14 10080
4 96 119 1 14 10080
5 120 143 1 14 10080
6 144 167 1 14 10080
7 168 191 1 14 10080
8 192 215 1 14 10080
9 216 239 1 14 10080
10 240 263 1 14 10080
11 264 286 1 14 9660
12 1 23 15 35 14490
13 24 47 15 35 15120
14 48 71 15 35 15120
15 72 95 15 35 15120
16 96 119 15 35 15120
17 120 143 15 35 15120
18 144 167 15 35 15120
19 168 191 15 35 15120
20 192 215 15 35 15120
21 216 239 15 35 15120
22 240 263 15 35 15120
23 264 286 15 35 14490
24 1 23 36 56 14490
25 24 47 36 56 15120
26 48 71 36 56 15120
27 72 95 36 56 15120
28 96 119 36 56 15120
29 120 143 36 56 15120
30 144 167 36 56 15120
31 168 191 36 56 15120
32 192 215 36 56 15120
33 216 239 36 56 15120
34 240 263 36 56 15120
35 264 286 36 56 14490
36 1 23 57 77 14490
37 24 47 57 77 15120
38 48 71 57 77 15120
39 72 95 57 77 15120
40 96 119 57 77 15120
41 120 143 57 77 15120
42 144 167 57 77 15120
43 168 191 57 77 15120
44 192 215 57 77 15120
45 216 239 57 77 15120
46 240 263 57 77 15120
47 264 286 57 77 14490
48 1 23 78 98 14490
49 24 47 78 98 15120
50 48 71 78 98 15120
51 72 95 78 98 15120
154 240 263 246 266 15120
155 264 286 246 266 14490
156 1 23 267 287 14490
157 24 47 267 287 15120
158 48 71 267 287 15120
159 72 95 267 287 15120
160 96 119 267 287 15120
161 120 143 267 287 15120
162 144 167 267 287 15120
163 168 191 267 287 15120
164 192 215 267 287 15120
165 216 239 267 287 15120
166 240 263 267 287 15120
167 264 286 267 287 14490
168 1 23 288 308 14490
169 24 47 288 308 15120
170 48 71 288 308 15120
171 72 95 288 308 15120
172 96 119 288 308 15120
173 120 143 288 308 15120
174 144 167 288 308 15120
175 168 191 288 308 15120
176 192 215 288 308 15120
177 216 239 288 308 15120
178 240 263 288 308 15120
179 264 286 288 308 14490
180 1 23 309 322 9660
181 24 47 309 322 10080
182 48 71 309 322 10080
183 72 95 309 322 10080
184 96 119 309 322 10080
185 120 143 309 322 10080
186 144 167 309 322 10080
187 168 191 309 322 10080
188 192 215 309 322 10080
189 216 239 309 322 10080
190 240 263 309 322 10080
191 264 286 309 322 9660
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 23.50 0.50 14.50 RHO-points
1 23.50 47.50 0.50 14.50 RHO-points
2 47.50 71.50 0.50 14.50 RHO-points
3 71.50 95.50 0.50 14.50 RHO-points
4 95.50 119.50 0.50 14.50 RHO-points
5 119.50 143.50 0.50 14.50 RHO-points
6 143.50 167.50 0.50 14.50 RHO-points
7 167.50 191.50 0.50 14.50 RHO-points
8 191.50 215.50 0.50 14.50 RHO-points
9 215.50 239.50 0.50 14.50 RHO-points
166 239.50 263.50 266.50 287.50 V-points
167 263.50 286.50 266.50 287.50 V-points
168 0.50 23.50 287.50 308.50 V-points
169 23.50 47.50 287.50 308.50 V-points
170 47.50 71.50 287.50 308.50 V-points
171 71.50 95.50 287.50 308.50 V-points
172 95.50 119.50 287.50 308.50 V-points
173 119.50 143.50 287.50 308.50 V-points
174 143.50 167.50 287.50 308.50 V-points
175 167.50 191.50 287.50 308.50 V-points
176 191.50 215.50 287.50 308.50 V-points
177 215.50 239.50 287.50 308.50 V-points
178 239.50 263.50 287.50 308.50 V-points
179 263.50 286.50 287.50 308.50 V-points
180 0.50 23.50 308.50 322.00 V-points
181 23.50 47.50 308.50 322.00 V-points
182 47.50 71.50 308.50 322.00 V-points
183 71.50 95.50 308.50 322.00 V-points
184 95.50 119.50 308.50 322.00 V-points
185 119.50 143.50 308.50 322.00 V-points
186 143.50 167.50 308.50 322.00 V-points
187 167.50 191.50 308.50 322.00 V-points
188 191.50 215.50 308.50 322.00 V-points
189 215.50 239.50 308.50 322.00 V-points
190 239.50 263.50 308.50 322.00 V-points
191 263.50 286.50 308.50 322.00 V-points
HaloSizeI(1) = 114
HaloSizeI(1) = 114
HaloSizeJ(1) = 105
TileSide(1) = 32
TileSize(1) = 928
ubar 1 Flather Flather Flather Flather
vbar 1 Flather Flather Flather Flather
u 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
v 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
temp 1 Closed Rad + Nud Rad + Nud Closed
salt 1 Closed Rad + Nud Rad + Nud Closed
tke 1 Gradient Gradient Gradient Gradient
fou FOU
!BOUNDARY_ALLGATHER Using mpi_allreduce in mp_boundary routine.
!COLLECT_ALL... Using mpi_isend/mpi_recv in mp_collect routine.
DOUBLE_PRECISION Double precision arithmetic numerical kernel.
NONLINEAR Nonlinear Model.
REDUCE_ALLGATHER Using mpi_allgather in mp_reduce routine.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
Node # 9 (pid= 31809) is active.
Node # 105 (pid= 3433) is active.
Node # 169 (pid= 3505) is active.
Node # 137 (pid= 3420) is active.
Node # 73 (pid= 3755) is active.
Node # 104 (pid= 3432) is active.
Node # 168 (pid= 3504) is active.
Node # 136 (pid= 3419) is active.
Node # 72 (pid= 3754) is active.
Node # 8 (pid= 31808) is active.
Node # 2 (pid= 31802) is active.
Node # 130 (pid= 3413) is active.
Node # 98 (pid= 3426) is active.
Node # 66 (pid= 30961) is active.
Node # 162 (pid= 32321) is active.
Node # 1 (pid= 31801) is active.
Node # 97 (pid= 3425) is active.
Node # 129 (pid= 3412) is active.
Node # 65 (pid= 30960) is active.
Node # 161 (pid= 32320) is active.
Node # 17 (pid= 31817) is active.
Node # 21 (pid= 31825) is active.
Node # 81 (pid= 3763) is active.
Node # 49 (pid= 30944) is active.
Node # 113 (pid= 3441) is active.
Node # 177 (pid= 3513) is active.
Node # 145 (pid= 32304) is active.
Node # 85 (pid= 3767) is active.
Node # 53 (pid= 30948) is active.
Node # 117 (pid= 3445) is active.
Node # 181 (pid= 3517) is active.
Node # 149 (pid= 32308) is active.
Node # 114 (pid= 3442) is active.
Node # 50 (pid= 30945) is active.
Node # 178 (pid= 3514) is active.
Node # 18 (pid= 31818) is active.
Node # 46 (pid= 5110) is active.
Node # 28 (pid= 5092) is active.
GET_GRID - bathymetry at RHO-points: h
(Grid = 01, File: /public/home/lizhicheng/forcing_qsm/grid_BH1.nc)
(Min = 5.00000000E+00 Max = 8.35096272E+02)
GET_GRID - Coriolis parameter at RHO-points: f
(Min = 7.07770197E-05 Max = 9.77238071E-05)
GET_GRID - reciprocal XI-grid spacing: pm
(Min = 2.40123359E-04 Max = 7.70536335E-04)
GET_GRID - reciprocal ETA-grid spacing: pn
(Min = 1.35350150E-04 Max = 3.11408982E-04)
GET_GRID - x-location of RHO-points: x-rho
(Min = 1.30114621E+07 Max = 1.46397179E+07)
GET_GRID - y-location of RHO-points: y_rho
(Min = 3.37711344E+06 Max = 5.16824320E+06)
GET_GRID - x-location of PSI-points: x_psi
(Min = 1.30127967E+07 Max = 1.46358749E+07)
GET_GRID - y-location of PSI-points: y-psi
(Min = 3.37964584E+06 Max = 5.16420466E+06)
GET_GRID - x-location of U-points: x_u
(Min = 1.30121518E+07 Max = 1.46377955E+07)
GET_GRID - y-location of U-points: y_u
(Min = 3.37760454E+06 Max = 5.16786382E+06)
GET_GRID - x-location of V-points: x_v
(Min = 1.30120625E+07 Max = 1.46377511E+07)
GET_GRID - y-location of V-points: y_v
(Min = 3.37915476E+06 Max = 5.16441049E+06)
GET_GRID - latitude of RHO-points lat_rho
(Min = 2.90412446E+01 Max = 4.20870814E+01)
GET_GRID - longitude of RHO-points: lon_rho
(Min = 1.17014890E+02 Max = 1.31658146E+02)
GET_GRID - latitude of PSI-points lat_psi
(Min = 2.90611536E+01 Max = 4.20601225E+01)
GET_GRID - longitude of PSI-points: lon_psi
(Min = 1.17026892E+02 Max = 1.31623585E+02)
GET_GRID - latitude of U-points: lat_u
(Min = 2.90451057E+01 Max = 4.20845497E+01)
GET_GRID - longitude of U-points: lon_u
(Min = 1.17021092E+02 Max = 1.31640857E+02)
GET_GRID - latitude of V-points: lat_v
(Min = 2.90572932E+01 Max = 4.20614969E+01)
GET_GRID - longitude of V-points: lon_v
(Min = 1.17020289E+02 Max = 1.31640459E+02)
GET_GRID - angle between XI-axis and EAST: angler
(Min = 4.36837711E-02 Max = 6.95618605E-01)
30 0.0000000 0.0000000 0.000 0.000 0.000 0.000
29 -0.0333333 -0.0010678 -0.086 -0.086 -0.608 -1.052
28 -0.0666667 -0.0042835 -0.177 -0.177 -2.108 -3.887
27 -0.1000000 -0.0096845 -0.274 -0.274 -4.514 -8.536
26 -0.1333333 -0.0173319 -0.377 -0.377 -7.853 -15.050
25 -0.1666667 -0.0273102 -0.485 -0.485 -12.160 -23.499
24 -0.2000000 -0.0397256 -0.599 -0.599 -17.479 -33.971
23 -0.2333333 -0.0547033 -0.720 -0.720 -23.861 -46.570
22 -0.2666667 -0.0723849 -0.848 -0.848 -31.365 -61.414
21 -0.3000000 -0.0929237 -0.982 -0.982 -40.056 -78.629
20 -0.3333333 -0.1164788 -1.125 -1.125 -49.998 -98.349
19 -0.3666667 -0.1432080 -1.275 -1.275 -61.258 -120.703
18 -0.4000000 -0.1732577 -1.433 -1.433 -73.897 -145.814
17 -0.4333333 -0.2067510 -1.600 -1.600 -87.965 -173.783
16 -0.4666667 -0.2437731 -1.776 -1.776 -103.498 -204.682
15 -0.5000000 -0.2843542 -1.961 -1.961 -120.508 -238.535
14 -0.5333333 -0.3284496 -2.154 -2.154 -138.977 -275.305
13 -0.5666667 -0.3759181 -2.356 -2.356 -158.846 -314.876
12 -0.6000000 -0.4265003 -2.566 -2.566 -180.008 -357.031
11 -0.6333333 -0.4797969 -2.783 -2.783 -202.296 -401.440
10 -0.6666667 -0.5352521 -3.005 -3.005 -225.481 -447.640
9 -0.7000000 -0.5921429 -3.230 -3.230 -249.261 -495.032
8 -0.7333333 -0.6495812 -3.457 -3.457 -273.269 -542.879
7 -0.7666667 -0.7065310 -3.683 -3.683 -297.074 -590.320
6 -0.8000000 -0.7618453 -3.905 -3.905 -320.200 -636.404
5 -0.8333333 -0.8143264 -4.119 -4.119 -342.150 -680.135
4 -0.8666667 -0.8628075 -4.324 -4.324 -362.440 -720.547
3 -0.9000000 -0.9062505 -4.516 -4.516 -380.638 -756.775
2 -0.9333333 -0.9438504 -4.693 -4.693 -396.411 -788.154
1 -0.9666667 -0.9751293 -4.854 -4.854 -409.559 -814.285
0 -1.0000000 -1.0000000 -5.000 -5.000 -420.048 -835.096
37 0.0473537721847153 0.0063819206892258 0.8558961515079423 0.9882658063583315
42 0.0109897377911118 0.0003663245930371 1.0000000000000004 0.9999999999999999
Minimum X-grid spacing, DXmin = 1.29779733E+00 km
Maximum X-grid spacing, DXmax = 4.16452612E+00 km
Minimum Y-grid spacing, DYmin = 3.21121117E+00 km
Maximum Y-grid spacing, DYmax = 7.38824447E+00 km
Minimum Z-grid spacing, DZmin = 8.60027663E-02 m
Maximum Z-grid spacing, DZmax = 4.78467442E+01 m
Minimum barotropic Courant Number = 8.49963677E-03
Maximum barotropic Courant Number = 1.19626820E-01
Maximum Coriolis Courant Number = 1.17268568E-02
NLM: GET_STATE - Reading state initial conditions, 2014-01-01 00:00:00.00
(Grid 01, t = 5114.0000, File: create-ini_woa_bio_restart_2014.nc, Rec=0001, Index=1)
- free-surface
(Min = -8.79572481E-02 Max = 7.02532053E-01)
(Min = -4.46885733E-01 Max = 5.27508468E-01)
(Min = -5.68172046E-01 Max = 5.75712014E-01)
- u-momentum component
(Min = -5.53176343E-01 Max = 8.88228626E-01)
- v-momentum component
(Min = -6.50475892E-01 Max = 7.36751197E-01)
- potential temperature
(Min = 0.00000000E+00 Max = 2.03487644E+01)
- salinity
(Min = 0.00000000E+00 Max = 3.64524155E+01)
Primary job terminated normally, but 1 process returned
Process name: [[49905,1],7]
Exit code: 59
I hope someone can share your experience and help me solve the problem.I'd aprreciate it very much.
