Hello, I try to generate force.nc file by Matlab, and the variables in this file are Uwind, Vwind, Pair....
But the matrix of variables is too big and Matlab show that 'one or more variables sizes violate format'.
So I generate two force.nc, which are corresponding to different period of time.
But ROMS reported the bug:
Error when checking input Forcing file: typhoon_wind1.nc
last data time record available is for day: 1 06:00:00
but data is needed to finish run until day: 2 12:00:00
I wonder how to solve this problem.
Thank you !
out-of-memory problem in .nc file while pre-process
Re: out-of-memory problem in .nc file while pre-process
Hello there
You have to look at your files timelength, or how you set the order in your *.in file configuration
lalvarez wrote:Hello there
Thank you for your reply, the problems are solved!
