NetCDF: Start+count exceeds dimension bound
abhay
#1 Unread post by abhay »
Hi
I have configured my first ROMS application and have the executable in my work directory. When I try to run it, I get the following error:
NLM: GET_STATE - Reading state initial conditions, 2011-01-15 00:00:00.00
(Grid 01, t = 723615.0000, File: Kongs_Init.nc, Rec=0001, Index=1)
- free-surface
(Min = -8.28427366E-01 Max = NaN)
(Min = -2.02749472E-02 Max = NaN)
(Min = 1.70838046E-02 Max = NaN)
Found Error: ** Line: 754 Source: ROMS/Utility/nf_fread3d.F
Found Error: ** Line: 843 Source: ROMS/Utility/get_state.F
NLM: GET_STATE - error while reading variable: u at time record = 1
in input NetCDF file: /cfs/klemming/nobackup/g/gongjing/tegner/myroms/trunk/Model_In/Initial/Kongs_Init.nc
Found Error: 02 Line: 517 Source: ROMS/Nonlinear/initial.F
Found Error: 02 Line: 188 Source: ROMS/Drivers/nl_ocean.h
Node # 10 CPU: 0.217
Node # 5 CPU: 0.217
Node # 15 CPU: 0.217
Node # 1 CPU: 0.217
Node # 2 CPU: 0.217
Node # 3 CPU: 0.217
Node # 9 CPU: 0.217
Node # 12 CPU: 0.217
Node # 4 CPU: 0.217
Node # 11 CPU: 0.217
Node # 8 CPU: 0.217
Node # 13 CPU: 0.217
Node # 14 CPU: 0.217
Node # 7 CPU: 0.217
Node # 6 CPU: 0.217
Node # 0 CPU: 0.215
Total: 3.471
Allocation and array initialization .............. 2.833 (81.6058 %)
Total: 2.833 81.6058
Message Passage: 2D halo exchanges ............... 0.030 ( 0.8543 %)
Message Passage: 3D halo exchanges ............... 0.021 ( 0.6176 %)
Message Passage: data broadcast .................. 0.256 ( 7.3688 %)
Message Passage: data reduction .................. 0.004 ( 0.1031 %)
Message Passage: data scattering.................. 0.148 ( 4.2508 %)
Message Passage: synchronization barrier ......... 0.002 ( 0.0458 %)
Total: 0.460 13.2404
Unique code regions profiled ..................... 2.833 81.6058 %
Residual, non-profiled code ...................... 0.638 18.3942 %
All percentages are with respect to total time = 3.471
Found Error: 02 Line: 350 Source: ROMS/Utility/close_io.F
REASON: NetCDF: Start+count exceeds dimension bound
I did not use the scripts available on the website to generate my grid, populate the initial conditions, forcing fields etc. , however, I referred to the guidelines and instructions provided on ROMS Wiki. The initial conditions are generated using Matlab. Is the order of the dimensions in the initial condition file (xi, eta, s) enforced strictly? I wouldn't think so, but then I am not able to understand why it would fail to read the file.
If a similar issue has been addressed then I'm sorry for re-posting.
Thanks in advance.
Abhay
Re: NetCDF: Start+count exceeds dimension bound
yes the dimensions are strictly enforced.
If you are new, i would recommend to use m files from someone/somewhere that already work. It will save you a lot of time.
-john
abhay
#3 Unread post by abhay »
Hi John
Many thanks for helping me out. I made the changes and it works now :)
Abhay
felipe.jbarragan7
#4 Unread post by felipe.jbarragan7 »
Hi abhay
I've this same problem just now.
How did you finally?
