COAWST JOE_TC case compile error
hzh_1211
#1 Unread post by hzh_1211 »
Hi everyone, I meet some errors when compiling coawst in JOE_TC case, the detail as flow:
1. Installation environment
  • COAWST/3.3.1
    intel/18.0.0
    netcdf/4.3.0
    ncview/2.1.7
    lapack/3.8.0
    zlib/1.2.7
    mvapich2/2.3
    hdf5/1.8.20
    jasper/1.900.1
    libpng/1.5.13
    MCT/from COAWST/Lib
export MCT_INCDIR=/nuist/u/home/heyijun/app/mct/include
export MCT_LIBDIR=/nuist/u/home/heyijun/app/mct/lib
2. RUN - WRF only
serial pass
parallel pass
3. RUN - Inlet_test: ROMS+SWAN
parallel pass
4. RUN - JOE_TC: ROMS+WRF
parallel error
mct_coupler_params.f90(2): error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [MCT_WRF_COUPLER_PARAMS]
      USE mct_wrf_coupler_params
compilation aborted for mct_coupler_params.f90 (code 1)
make: *** [/nuist/p/work/heyijun/henry/COAWST/Projects/JOE_TC/Coupled_mvapich2/Build/mct_coupler_params.o] Error 1
or
atm_coupler.f90(261): error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [M_MCTWORLD]
      USE m_MCTWorld, ONLY : MCTWorld_init => init
atm_coupler.f90(290): error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [M_TRANSFER]
      USE m_Transfer, ONLY: MCT_send => send
atm_coupler.f90(266): error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [M_GLOBALSEGMAP]
      USE m_GlobalSegMap, ONLY : GlobalSegMap
I don't know what INCLUDE paths means here, how define INCLUDE paths? I have modified the coawst.bash according to the user manual, and all of libraries are complied with intel complier.
I have test openmpi mvapich2 and impi, but no one can compile passed. Maybe the problem comes from MCT, but ROMS+SWAN compile passed with this MCT.
Please give me some advise!
build.log
scrip build.log
coawst.bash -j 12
exit
(1.29 MiB) Downloaded 828 times
yxli
Re: COAWST JOE_TC case compile error
#2 Unread post by yxli »
I have the same problem, how did you solve it?
