why add print command alter the result in the RIVERPLUME2?
rexchiwing
#1 Unread post by rexchiwing »
First, I run the standard riverplume2 case without any change.
Then I add some print command in step2d_LF_AM3.h and step3d_uv.F to print out the value of point sources input (like: Qbar(is), cff) for checking.
In the step2d_LF_AM3.h the print statement are add like:
! Apply mass point sources.
DO j=Jstr-1,Jend+1
DO i=Istr-1,Iend+1
Dnew(i,j)=zeta(i,j,knew)+h(i,j)
DO is=1,Nsrc
i=Isrc(is)
j=Jsrc(is)
IF (((IstrR.le.i).and.(i.le.IendR)).and. &
& ((JstrR.le.j).and.(j.le.JendR))) THEN
IF (INT(Dsrc(is)).eq.0) THEN
cff=1.0_r8/(on_u(i,j)*0.5_r8*(Dnew(i-1,j)+Dnew(i,j)))
ubar(i,j,knew)=Qbar(is)*cff
if (is.eq.1)then !! rex
print *,"rex ubar(i,j,knew)", is," ", i," ", j," ",knew ," ",Qbar(is), " ", cff !! rex
end if !! rex
# ifdef SOLVE3D
DU_avg1(i,j)=Qbar(is)
print *,"rex DU_avg1(i,j)", is," ", i," ", j," ",Qbar(is), " ", cff !! rex
end if !! rex
ELSE
cff=1.0_r8/(om_v(i,j)*0.5_r8*(Dnew(i,j-1)+Dnew(i,j)))
vbar(i,j,knew)=Qbar(is)*cff
print *,"rex vbar(i,j,knew)", is," ", i," ", j," ",knew ," ",Qbar(is), " ", cff !! rex
end if !! rex
# ifdef SOLVE3D
DV_avg1(i,j)=Qbar(is)
print *,"rex DV_avg1(i,j)", is," ", i," ", j," ",Qbar(is), " ", cff !! rex
end if !! rex
And in the step3d_uv.F the print command add in:
DO is=1,Nsrc
i=Isrc(is)
j=Jsrc(is)
DO k=1,N(ng)
cff1=1.0_r8/(on_u(i,j)* &
& 0.5_r8*(z_w(i-1,j,k)-z_w(i-1,j,k-1)+ &
& z_w(i ,j,k)-z_w(i ,j,k-1)))
u(i,j,k,nnew)=Qsrc(is,k)*cff1
print *,"rex u(i,j,k,nnew)", is," ", i," ", j," ", k," ",nnew ," ",Qsrc(is,k), " ", cff1 !! rex
end if !! rex
ELSE
DO k=1,N(ng)
cff1=1.0_r8/(om_v(i,j)* &
& 0.5_r8*(z_w(i,j-1,k)-z_w(i,j-1,k-1)+ &
& z_w(i,j ,k)-z_w(i,j ,k-1)))
v(i,j,k,nnew)=Qsrc(is,k)*cff1
print *,"rex v(i,j,k,nnew)", is," ", i," ", j," ", k," ",nnew ," ",Qsrc(is,k), " ", cff1 !! rex
end if !! rex
And after adding print, the case result of u,v, S are changed as the figures attached.
Furthermore I test to add a print command in the upwelling case, it wouldn't change the result.
I have some questions:
1, why adding the print commands will change result in the riverplume2 case?
2, how to solve this problem?
step2d.f90
(36.99 KiB) Downloaded 437 times
step3d_uv.f90
(24.7 KiB) Downloaded 448 times
the different of two case of the bottom salinity
the different of two case of the surface salinity
the different of two case of the bottom velocity v
the different of two case of the surface velocity v
the different of two case of the bottom velocity u
the different of two case of the surface velocity u
