can't find revision #751 in new source code
jsouza
#1 Unread post by jsouza »
Hi all;
Just updated my source (have been too long since I did that!) and could not find the option from modification #751...
I used "svn update". Just to be sure, I checked out the trunk repository again and did the update - but the results are the same.
Now I am just adding it by hand, but thought it was worth the post.
Cheers
Joao
Re: can't find revision #751 in new source code
#2 Unread post by wilkin »
Joao,
Even if the Timeline in trac https://www.myroms.org/projects/src/timeline does not go back far enough in time you can choose any Changeset and edit the browser URL to enter the number you want. So for revision 751 you want:
https://www.myroms.org/projects/src/changeset/751
A LOT has changed in Jan 7, 2015. Many things added - some things taken away.
Trac is pretty powerful for browsing and comparing versions but can take some practice and perseverance to get it to display exactly what you want.
Contact me directly if you are having any specific upgrade difficulties.
John.
m.hadfield
If you use git svn to clone the trunk, as Kate has talked about from time to time, you will get a copy of the entire history of the repository and can check out any revision you want.
