Small bugs in CPP BIO_FENNEL with DIAG and DIAGNOSTICS_BIO
Honolulu_Wang
#1 Unread post by Honolulu_Wang »
Here are small ROMS bugs for DIAGNOSTICS_BIO terms in ROMS.
In def_diag.F
# ifdef BIO_FENNEL
          DO ivar=1,NDbio2d
            ifield=iDbio2(ivar)
            IF (TRIM(var_name(i)).eq.TRIM(Vname(1,ifield))) THEN
              got_var(ifield)=.TRUE.
              DIA(ng)%Vid(ifield)=var_id(i)
          DO ivar=1,NDbio3d
            ifield=iDbio3(ivar)
and also
# ifdef BIO_FENNEL
        DO ivar=1,NDbio2d
          ifield=iDbio2(ivar)
          IF (.not.got_var(ifield).and.Dout(ifield,ng)) THEN
            IF (Master) WRITE (stdout,60) TRIM(Vname(1,ifield)),        &
     &                                    TRIM(ncname)
            exit_flag=3
            RETURN
        DO ivar=1,NDbio3d
          ifield=iDbio3(ivar)
     &                                    TRIM(ncname)
            exit_flag=3
            RETURN
I think all this flag should be # if defined BIO_FENNEL && defined DIAGNOSTICS_BIO.
Because if one user does turn on #BIO_FENNEL, but not turn on the #DIAGNOSTICS_BIO flag, then in fennel_mod.F, finally become mod_biology.f90, will not allocate a variable called iDbio2 and iDbio3.
#if defined DIAGNOSTICS && defined DIAGNOSTICS_BIO
!  Biological 2D diagnostic variable IDs.
      integer, allocatable :: iDbio2(:)       ! 2D biological terms
      integer  :: iCOfx                       ! air-sea CO2 flux
      integer  :: iDNIT                       ! denitrification flux
      integer  :: ipCO2                       ! partial pressure of CO2
      integer  :: iO2fx                       ! air-sea O2 flux
!  Biological 3D diagnostic variable IDs.
      integer, allocatable :: iDbio3(:)       ! 3D biological terms
      integer  :: iPPro = 1                   ! primary productivity
      integer  :: iNO3u = 2                   ! NO3 uptake
However, iDbio2 and iDbio3 will be required by def_diag.F if you dod not have a DIAGNOSTICS_BIO limitation. Right?
Thanks.
Re: Small bugs in CPP BIO_FENNEL with DIAG and DIAGNOSTICS_
Nope. That's not what I have in the repository for def_diags.F:
# ifdef DIAGNOSTICS_BIO
#  if defined BIO_FENNEL || defined HYPOXIA_SRM
          DO ivar=1,NDbio2d
            ifield=iDbio2(ivar)
#  endif
          DO ivar=1,NDbio3d
            ifield=iDbio3(ivar)
#  endif
        DO ivar=1,NDbio2d
          ifield=iDbio2(ivar)
     &                                    TRIM(ncname)
            exit_flag=3
            RETURN
#  endif
        DO ivar=1,NDbio3d
          ifield=iDbio3(ivar)
     &                                    TRIM(ncname)
            exit_flag=3
            RETURN
#  endif
also fennel_mod.h is correct as it is. You either modified those files or need to update!
sun_92
#3 Unread post by sun_92 »
Hello all.
I was using Roms AGRIF for doing biogeochemical modelling, now switching to rutgers for the same. Can anyone please help me with the preliminary steps?
I created the biundary initial and forcing files using croco tools. However the bio modules in CROCO and Rutgers are not the same. Any help in this regard would be deeply appreciated.
