How to restart the IS4DVAR date assimilation system?
wavewatch
#1 Unread post by wavewatch »
I can successfully run the primal form of incremental, strong constraint, 4-Dimensional Variational (4D-Var) data assimilation algorithm in the California Current System, 1/3 degree resolution, application (WC13).
Now I have a question for you:
If I complete the assimilation for 7 days, the model stops. And I want to continue assimilation on the next 7 days.
What should I do? I've tried to do this: NRREC == -1,ININAME == ***_rst.nc,just set up like non-assimilation.
However, errors are made in assimilation :( , as follows:
<<<< Descent Algorithm >>>>
  CG_DELTA not positive.
  CG_DELTA =   -227074.319591249      , outer =            1 , inner =
           1
           1
           1
           1
           1
           1
           1
Here is my output.file
Does anyone know the answer to the question?
output.log
(312.46 KiB) Downloaded 655 times
