sustr and svstr Value has not been read
hpd14thu
#1 Unread post by hpd14thu »
My force file contains sustr and svstr , but when I run it , I find that these two variable has not been read.
I consider that there are some problems in my head file , but I don't know which CPP option I should add into head file.
Here is my head file:
** svn $Id: sandy.h 25 2007-04-09 23:43:58Z jcwarner $
** Copyright (c) 2002-2007 The ROMS/TOMS Group **
** See License_ROMS.txt **
** Options for Sandy Test.
** Application flag: SANDY
#define ROMS_MODEL
#undef NESTING
/*#define WRF_MODEL
#define SWAN_MODEL
#define MCT_LIB
#define MCT_INTERP_OC2AT
#define MCT_INTERP_WV2AT
#define MCT_INTERP_OC2WV*/
#if defined WRF_MODEL && defined SWAN_MODEL
# define DRAGLIM_DAVIS
# define COARE_TAYLOR_YELLAND
#ifdef ROMS_MODEL
/* Physics + numerics */
# define UV_ADV
# define UV_COR
# define UV_VIS2
# define MIX_S_UV
# undef TS_FIXED
# define TS_U3HADVECTION
# define TS_C4VADVECTION
# undef TS_MPDATA
# undef SSW_BBL
# ifdef SSW_BBL
# define SSW_CALC_ZNOT
/* # define ANA_SEDIMENT */
# else
# define UV_LOGDRAG
# if !defined SWAN_MODEL && defined SSW_BBL
# define ANA_WWAVE
# define DJ_GRADPS
# define TS_DIF2
# define MIX_GEO_TS
# define CURVGRID
# define SALINITY
# define SOLVE3D
# define AVERAGES
# define NONLIN_EOS
/* Grid and Initial */
# define MASKING
/* Forcing */
# ifdef WRF_MODEL
# undef BULK_FLUXES
# define ATM2OCN_FLUXES
# define ANA_SSFLUX
# undef LONGWAVE_OUT
/*# define ATM_PRESS*/
# else
/*# define BULK_FLUXES/*
# define ANA_SMFLUX
# define ANA_STFLUX
# define ANA_SSFLUX */
/*# define ATM_PRESS/*
/*# define LONGWAVE_OUT*/
# define ANA_BTFLUX
# define ANA_BSFLUX
# define ANA_SMFLUX
# define EMINUSP
/*# define SOLAR_SOURCE/*
/* Turbulence closure */
# define GLS_MIXING
# undef MY25_MIXING
# define AKLIMIT
# if defined GLS_MIXING || defined MY25_MIXING
/* Output */
# undef DIAGNOSTICS_UV
# undef DIAGNOSTICS_TS
Re: sustr and svstr Value has not been read
you basically have this set:
/* Forcing */
# ifdef WRF_MODEL
# else
# define ANA_SMFLUX
so you have ana_smflux on. that will look for analytical values and they are most likely set to 0. so you would want to use
#undef ANA_SMFLUX
and then it will look for su/vstr in forcing files.
hpd14thu
#3 Unread post by hpd14thu »
jcwarner wrote:you basically have this set:
/* Forcing */
# ifdef WRF_MODEL
# else
# define ANA_SMFLUX
#undef ANA_SMFLUX
Thanks a million! I have solved this problem by this way. But there are another new question which I don't understand:
Here is result.out , the error shows in the last few lines :
ZFIRST
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler command : /usr/local/mpich/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -ftree-vectorize -ftree-loop-linear -funroll-loops -w -ffree-form -ffree-line-length-none -frecord-marker=4 -fconvert=big-endian
Input Script :
SVN Root URL : https:://myroms.org/svn/src
SVN Revision :
Local Root : /home/hpd14/Documents/COAWST_V3.2
Header Dir : /home/hpd14/Documents/COAWST_V3.2/Projects/zfirst
Header file : zfirst.h
Analytical Dir: /home/hpd14/Documents/COAWST_V3.2/Projects/zfirst
Resolution, Grid 01: 0048x0048x020, Parallel Nodes: 1, Tiling: 001x001
8640 ntimes Number of timesteps for 3-D equations.
0.020 dt Timestep size (s) for 3-D equations.
120 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
1 nHIS Number of timesteps between the writing fields
into history file.
time-averaged data.
360 nAVG Number of timesteps between the writing of
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
5.0000E-02 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
0.000 wec_alpha WEC factor for roller/breaking energy distribution.
5.0000E-01 Zos Surface roughness (m).
1 lmd_Jwt Jerlov water type.
8.0000E+00 theta_s S-coordinate surface control parameter.
5.0000E-01 theta_b S-coordinate bottom control parameter.
20.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
0.0000E+00 Tnudg_SSS Nudging/relaxation time scale (days)
for sea surface salinity.
for 3D momentum.
T Hout(idVbms) Write out bottom V-momentum stress.
T Aout(idSdif) Write out averaged vertical diffusion: AKt(isalt).
Output History File: ocean_zfirst_his.nc
Input Grid File: /home/hpd14/Documents/COAWST_V3.2/Projects/zfirst/zfirst_grid_cco.nc
Input Nonlinear Initial File: /home/hpd14/Documents/COAWST_V3.2/Projects/zfirst/zfirst_init_cco.nc
Input Forcing File 01: /home/hpd14/Documents/COAWST_V3.2/Projects/zfirst/zfirst_str.nc
Tile partition information for Grid 01: 0048x0048x0020 tiling: 001x001
tile Istr Iend Jstr Jend Npts
Number of tracers: 2
0 1 48 1 48 46080
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 48.50 0.50 48.50 RHO-points
0 1.00 48.00 0.50 48.50 U-points
0 0.50 48.50 1.00 48.00 V-points
HaloSizeI(1) = 118
HaloSizeJ(1) = 118
TileSide(1) = 53
TileSize(1) = 2809
zeta 1 Closed Closed Closed Closed
ubar 1 Closed Closed Closed Closed
vbar 1 Closed Closed Closed Closed
u 1 Closed Closed Closed Closed
v 1 Closed Closed Closed Closed
temp 1 Closed Closed Closed Closed
salt 1 Closed Closed Closed Closed
tke 1 Closed Closed Closed Closed
ZFIRST ZFIRST
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
Node # 0 (pid= 46871) is active.
20 0.0000000 0.0000000 0.000 0.000 0.000 0.000
19 -0.0500000 -0.0000692 -0.501 -0.501 -0.501 -0.501
18 -0.1000000 -0.0002879 -1.003 -1.003 -1.003 -1.003
17 -0.1500000 -0.0006915 -1.507 -1.507 -1.507 -1.507
16 -0.2000000 -0.0013455 -2.013 -2.013 -2.013 -2.013
15 -0.2500000 -0.0023555 -2.524 -2.524 -2.524 -2.524
14 -0.3000000 -0.0038848 -3.039 -3.039 -3.039 -3.039
13 -0.3500000 -0.0061801 -3.562 -3.562 -3.562 -3.562
12 -0.4000000 -0.0096110 -4.096 -4.096 -4.096 -4.096
11 -0.4500000 -0.0147275 -4.647 -4.647 -4.647 -4.647
10 -0.5000000 -0.0223460 -5.223 -5.223 -5.223 -5.223
9 -0.5500000 -0.0336719 -5.837 -5.837 -5.837 -5.837
8 -0.6000000 -0.0504756 -6.505 -6.505 -6.505 -6.505
7 -0.6500000 -0.0753361 -7.253 -7.253 -7.253 -7.253
6 -0.7000000 -0.1119642 -8.120 -8.120 -8.120 -8.120
5 -0.7500000 -0.1655988 -9.156 -9.156 -9.156 -9.156
4 -0.8000000 -0.2434198 -10.434 -10.434 -10.434 -10.434
3 -0.8500000 -0.3548031 -12.048 -12.048 -12.048 -12.048
2 -0.9000000 -0.5110137 -14.110 -14.110 -14.110 -14.110
1 -0.9500000 -0.7235564 -16.736 -16.736 -16.736 -16.736
0 -1.0000000 -1.0000000 -20.000 -20.000 -20.000 -20.000
Time Splitting Weights for Grid 01: ndtfast = 20 nfast = 29
3-0.0011514592651644 0.0501156998674241-0.0034654566136460 0.1501639558342180
4-0.0003735756740661 0.0501732728306823-0.0038390322877122 0.2003372286649003
6 0.0029141799764308 0.0501428056118168 0.0000580677400949 0.3006719858911027
7 0.0054132615310267 0.0499970966129953 0.0054713292711215 0.3506690825040980
8 0.0084687837865133 0.0497264335364439 0.0139401130576348 0.4003955160405419
9 0.0120633394191050 0.0493029943471183 0.0260034524767398 0.4496985103876601
10 0.0161716623600090 0.0486998273761630 0.0421751148367488 0.4983983377638231
11 0.0207585511322367 0.0478912442581626 0.0629336659689855 0.5462895820219857
12 0.0257765478740990 0.0468533167015507 0.0887102138430846 0.5931428987235364
13 0.0311633730493853 0.0455644893078458 0.1198735868924699 0.6387073880313822
14 0.0368391158442262 0.0440063206553765 0.1567127027366961 0.6827137086867586
15 0.0427031802506397 0.0421643648631652 0.1994158829873358 0.7248780735499238
16 0.0486309868367616 0.0400292058506332 0.2480468698240974 0.7649072794005570
17 0.0544704302037592 0.0375976565087951 0.3025173000278565 0.8025049359093521
18 0.0600380921294286 0.0348741349986072 0.3625553921572851 0.8373790709079593
19 0.0651152103984763 0.0318722303921357 0.4276706025557614 0.8692513013000950
20 0.0694434033194839 0.0286164698722119 0.4971140058752453 0.8978677711723069
21 0.0727201499285570 0.0251442997062377 0.5698341558038023 0.9230120708785446
22 0.0745940258796570 0.0215082922098099 0.6444281816834592 0.9445203630883545
23 0.0746596950216179 0.0177785909158270 0.7190878767050771 0.9622989540041815
24 0.0724526566618460 0.0140456061647461 0.7915405333669231 0.9763445601689277
25 0.0674437485167025 0.0104229733316538 0.8589842818836255 0.9867675335005816
26 0.0590334053485720 0.0070507859058187 0.9180176872321975 0.9938183194064003
27 0.0465456732896125 0.0040991156383901 0.9645633605218099 0.9979174350447905
28 0.0292219798521905 0.0017718319739095 0.9937853403740003 0.9996892670187000
29 0.0062146596259993 0.0003107329813000 0.9999999999999997 1.0000000000000000
Minimum X-grid spacing, DXmin = 1.01116846E-03 km
Maximum X-grid spacing, DXmax = 1.01116846E-03 km
Minimum Y-grid spacing, DYmin = 9.87495621E-04 km
Maximum Y-grid spacing, DYmax = 9.87495621E-04 km
Minimum Z-grid spacing, DZmin = 5.00691658E-01 m
Maximum Z-grid spacing, DZmax = 3.26443623E+00 m
Minimum barotropic Courant Number = 1.00000000E+20
Maximum barotropic Courant Number = -1.00000000E+20
Maximum Coriolis Courant Number = -1.00000000E+20
(Grid 01, File: zfirst_init_cco.nc, Rec=0001, Index=1)
- free-surface
- u-momentum component
- v-momentum component
- potential temperature
- salinity
REGRID - input gridded data does not contain model grid:
Gridded: LonMin = -13.6075 LonMax = 35.9397
LatMin = 97.6335 LatMax = 146.0208
Model: LonMin = 0.0000 LonMax = 0.0000
LatMin = 0.0000 LatMax = 0.0000
GET_2DFLD - error while reading variable: sustr at TIME index = 1
Node # 0 CPU: 0.069
Total: 0.069
Allocation and array initialization .............. 0.028 (40.5804 %)
2D/3D coupling, vertical metrics ................. 0.001 ( 1.4495 %)
Equation of state for seawater ................... 0.005 ( 7.2461 %)
Total: 0.034 49.2760
Message Passage: data scattering.................. 0.003 ( 4.3485 %)
Total: 0.003 4.3485
All percentages are with respect to total time = 0.069
ERROR: I/O related problem.
#4 Unread post by jcwarner »
your forcing file does not have any grid data. each field needs an attribute of lon and lat. see here
viewtopic.php?f=1&t=1348
hpd14thu
#5 Unread post by hpd14thu »
jcwarner wrote:Gridded: LonMin = -13.6075 LonMax = 35.9397
Thank you for your reply. It is so kind of you!
But I have checked my forcing file , it seems that I have give each fiekd an attribute of x and y.
Here is my forcing.m ,which used to generate netcdf file:
function create_roms_stress(x,y,time,fn,varargin)
nc=netcdf.create(fn,'clobber');
if isempty(nc), return, end
disp(' ## Defining Global Attributes...')
netcdf.putAtt(nc,netcdf.getConstant('NC_GLOBAL'),'history', ['Created by ' mfilename ' on ' datestr(now)]);
netcdf.putAtt(nc,netcdf.getConstant('NC_GLOBAL'),'type', 'ROMS FORCING file');
% Dimensions:
disp(' ## Defining Dimensions...')
%dimid = netcdf.defDim(ncid,dimname,dimlen)
[ix iy]=size(x);
t=length(time);
x_dimID = netcdf.defDim(nc,'xrho',ix);
y_dimID = netcdf.defDim(nc,'yrho',iy);
t_dimID = netcdf.defDim(nc,'time',t);
% onedimID = netcdf.defDim(nc,'one',1);
% Variables and attributes:
disp(' ## Defining Variables, and Attributes...')
%varid = netcdf.defVar(ncid,varname,xtype,dimids)
%netcdf.putAtt(ncid,varid,attrname,attrvalue)
tID = netcdf.defVar(nc,'time','double',t_dimID);
netcdf.putAtt(nc,tID,'long_name','forcing time');
netcdf.putAtt(nc,tID,'units','days');
netcdf.putAtt(nc,tID,'field','time, scalar, series');
xID = netcdf.defVar(nc,'x','double',[x_dimID y_dimID]);
netcdf.putAtt(nc,xID,'long_name','x');
netcdf.putAtt(nc,xID,'units','meter');
netcdf.putAtt(nc,xID,'field','xp, scalar, series');
yID = netcdf.defVar(nc,'y','double',[x_dimID y_dimID]);
netcdf.putAtt(nc,yID,'long_name','y');
netcdf.putAtt(nc,yID,'units','meter');
netcdf.putAtt(nc,yID,'field','yp, scalar, series');
if sum(strcmpi(varargin,'sustr'))>0
st_dimID = netcdf.defDim(nc,'sms_time',t);
stID = netcdf.defVar(nc,'sms_time','double',st_dimID);
netcdf.putAtt(nc,stID,'long_name','sms_time');
netcdf.putAtt(nc,stID,'units','days');
netcdf.putAtt(nc,stID,'field','sms_time, scalar, series');
sustrID = netcdf.defVar(nc,'sustr','double',[x_dimID y_dimID st_dimID]);
netcdf.putAtt(nc,sustrID,'long_name','surface u-momentum stress');
netcdf.putAtt(nc,sustrID,'units','Newton meter-2');
netcdf.putAtt(nc,sustrID,'field','surface u-momentum stress, scalar, series');
netcdf.putAtt(nc,sustrID,'coordinates','x y');
netcdf.putAtt(nc,sustrID,'time','sms_time');
end
if sum(strcmpi(varargin,'svstr'))>0
if ~sum(strcmpi(varargin,'sustr'))>0
end
svstrID = netcdf.defVar(nc,'svstr','double',[x_dimID y_dimID st_dimID]);
netcdf.putAtt(nc,svstrID,'long_name','surface v-momentum stress');
netcdf.putAtt(nc,svstrID,'units','Newton meter-2');
netcdf.putAtt(nc,svstrID,'field','surface v-momentum stre, scalar, series');
netcdf.putAtt(nc,svstrID,'coordinates','x y');
netcdf.putAtt(nc,svstrID,'time','sms_time');
end
if sum(strcmpi(varargin,'shflux'))>0
shft_dimID = netcdf.defDim(nc,'shf_time',t);
shftID = netcdf.defVar(nc,'shf_time','double',shft_dimID);
netcdf.putAtt(nc,stID,'long_name','surface heat flux time');
netcdf.putAtt(nc,stID,'field','shf_time, scalar, series');
shfluxID = netcdf.defVar(nc,'shflux','double',[x_dimID y_dimID shft_dimID]);
netcdf.putAtt(nc,shfluxID,'long_name','surface net heat flux');
netcdf.putAtt(nc,shfluxID,'units','Watts meter-2');
netcdf.putAtt(nc,shfluxID,'field','surface heat flux, scalar, series');
netcdf.putAtt(nc,shfluxID,'coordinates','x y');
netcdf.putAtt(nc,shfluxID,'time','shf_time');
end
netcdf.close(nc)
#6 Unread post by kate »
Your model grid doesn't appear to have lat,lon values in it. The gridded forcing does have them, though one might question your latitude values. Are you sure you didn't swap lat and lon?
fdaryabor
#7 Unread post by fdaryabor »
Dear,
As stated by Katherine and John, such errors :arrow: (GET_2DFLD - error while reading variable: or GET_3DFLD - error while reading variable:) are due to the definition of input variables. To avoid encountering such a problem is essential check consistency of the variables in ".nc" file with the list of variables sorted in ".../trunk/ROMS/External/varinfo.dat", even though although want to have an own script I suggest you that have a look at the Matlab toolbox from the ROMS repository. :arrow: "svn checkout https://www.myroms.org/svn/src/matlab MyDir"
Good luck to you,
Farshid
hpd14thu
#8 Unread post by hpd14thu »
Thanks a lot! I made some changes, and now there is another problem:
NETCDF_INQ_VAR - requested variable: x
not found in input file: /home/hpd14/Documents/COAWST_V3.2/Projects/zfirst/zfirst_str.nc
call from: get_varcoords.F
hpd14thu
#9 Unread post by hpd14thu »
fdaryabor wrote:Dear,
Good luck to you,
Farshid
Thanks a million, it's really so kind of you!
According to the BUG :GET_2DFLD - error while reading variable: sustr at TIME index = 1 ,
I have checked my sustr value in forcing file carefully, but I didn't find anything abnormal.
I don't know if there is anything wrong with the time value.( I'm not clear about the time value yet)
Here is my forcing file, if possible, could you please see if there is anything wrong in my forcing file? I really thank you for your self-giving help !
zfirst_str_20180510.nc
(216.43 KiB) Downloaded 948 times
fdaryabor
#10 Unread post by fdaryabor »
Dear,
Your attached file is completely wrong :shock: and it's not really readable for the ROMS, such attributions, dimensions and time format. I suggest you that follow directory :arrow: ".../trunk/Data/ROMS/CDL" it can help you to find your questions :?: . Good luck to you
Farshid
hpd14thu
#11 Unread post by hpd14thu »
Farshid
Thanks a lot! I'm a beginner at computer programming. According to your suggestion, I found the frc_uvstress.cdl file in ".../trunk/Data/ROMS/CDL" which you recommend, and I transfered it into netcdf file. Then I use a matlab file(which named str_cdl_nc.m) to write values into the ncfile
But when I check the forcing.nc file. The value of sms time is very strange, and the dimension of it is incorrect.( I just want to calculate in 2 days since 0:00:00 0)
So I wonder if there is anything wrong in my matlab file(which used to write value into ncfile) ? Thank you so much!
frc_uvstress.nc
(15.15 MiB) Downloaded 865 times
str_cdl_nc.m
(1.64 KiB) Downloaded 858 times
fdaryabor
#12 Unread post by fdaryabor »
Dear,
Alright, use the following linux commands to convert nc2cdl.
:arrow: ncdump -b c myfile.nc > myfile.cdl
by the command "vim" or "gedit" (recommended for you to see as .txt file for edit) open myfile.cdl;
:arrow: gedit myfile.cdl
and also open "frcfile.cdl" from ../trunk/Data/ROMS/CDL;
:arrow: gedit frcfile.cdl
copy and paste "attributes, dimension, variables definition" from "frcfile.cdl" in "myfile.cdl", then convert "myfile.cdl" to ".nc" file as follow;
:arrow: ncgen -b myfile.cdl > myfile.nc
Now you try new ".nc" file and see how is work.
Good luck,
