When I run Build.Bash, I face to an Error as per bellow. How can I remove this error? Any help , please. This is :
My Command for Running Build.Bash is as:
[majid@localhost upwelling1]$ ./build.bash
and the Reply I found is as bellow:
make: *** No rule to make target `clean'. Stop.
make: *** No targets specified and no makefile found. Stop.
Error while using Run Command by Build.bash!
- m.hadfield
Re: Error while using Run Command by Build.bash!
Near the end of your build.bash file you should be able to see lines like the following
In other words, the script cd's to the directory given by the environment variable MY_ROMS_SRC and then (unless instructed otherwise by arguments passed to the script) runs "make clean".
Your error is given by make, attempting to build the "clean" target, and says it can't find a makefile. There is a makefile at the top level in the ROMS distribution, eg. this one:
https://www.myroms.org/svn/src/trunk/makefile
So, at that point in the script, what is the value of MY_ROMS_SRC? If it's empty, cd will take you to your home directory. If it's not empty then it appears that it points to a directory that does not exist, or is not a ROMS distribution.
# Go to the users source directory to compile. The options set above will
# pick up the application-specific code from the appropriate place.
cd ${MY_ROMS_SRC}
# Compile.
# Remove build directory.
if [ $clean -eq 1 ]; then
make clean
fi
