Unexpected behavior ROMS
adilsonborges
#1 Unread post by adilsonborges »
I was performing a long integration (1985 to 2015), when in December 2006 the model presented unexpected behavior, the model continues to run, it passes to 2007-01-01, but the .nc (avg) output file is very low values of salinity and temperature. Attached is the .out file for month 12 of 2006 and one archive .out for 2006-11-01 (normal behavior.
This warning appears only 2006 12 .out archive:
NLM: GET_STATE - Warning - NetCDF global attribute: NLM_LBC
for lateral boundary conditions not checked
in restart file: input.nc
My ini configurations:
LBC(isFsur) == Cha Cha Cha Cha ! free-surface
LBC(isUbar) == Fla Fla Fla Fla ! 2D U-momentum
LBC(isVbar) == Fla Fla Fla Fla ! 2D V-momentum
LBC(isUvel) == RadNud RadNud RadNud RadNud ! 3D U-momentum
LBC(isVvel) == RadNud RadNud RadNud RadNud ! 3D V-momentum
LBC(isMtke) == Clo Clo Clo Clo ! mixing TKE
LBC(isTvar) == RadNud RadNud RadNud RadNud \ ! temperature
RadNud RadNud RadNud RadNud ! salinity
My study domain is Equatorial Atlantic Ocean (12N 12S 60W 19.4W)
Best regards!
atleq3_20061101.txt
atleq3_20061101
(837.67 KiB) Downloaded 608 times
atleq3_20061201.txt
atleq3_20061201
(190.95 KiB) Downloaded 551 times
Re: Unexpected behavior ROMS
Do you have a restart record from before things went bad? It might be worth rerunning to see if it happens again. That warning you quote is nothing to worry about.
adilsonborges
#3 Unread post by adilsonborges »
Hi kate, again, thank you very much for your attention,
Kate, I have a restart record (2006 11) I used it to restart my experiment, when I plotted my kinetic energy and saw that in month 12 of 2006 it showed a drop reaching 0. I have another experiment that uses only the different TCLINE, and it run normally from 2006 to 2015.
Thanks!
adilsonborges
#4 Unread post by adilsonborges »
Kate,
PROBLEM SOLVED:
I come to thank you and apologize for making a silly mistake, I missed the DSTART (2006 11 01) time in the run.sh file. Sorry.
Best regards!!
Thank you!
