418991 2002-12-13 11:45:00.00 9.511432E-03 2.031949E+04 2
vivek
#1 Unread post by vivek »
Dear All.
i am getting follwoing error end of the year. anybody help me
418991 2002-12-13 11:45:00.00 9.511432E-03 2.031949E+04 2.031950E+04 1.374943E+17
(043,065,13) 1.034506E-02 6.689479E-03 2.296315E-01 2.139033E+00
418992 2002-12-13 12:00:00.00 9.511547E-03 2.031949E+04 2.031950E+04 1.374943E+17
(043,065,13) 1.034830E-02 6.682660E-03 2.293515E-01 2.150356E+00
418993 2002-12-13 12:15:00.00 9.511688E-03 2.031949E+04 2.031950E+04 1.374943E+17
(043,065,13) 1.035154E-02 6.676890E-03 2.290836E-01 2.158636E+00
Found Error: 01 Line: 302 Source: ROMS/Nonlinear/main3d.F
Found Error: 01 Line: 274 Source: ROMS/Drivers/nl_ocean.h
Re: 418991 2002-12-13 11:45:00.00 9.511432E-03 2.031949E+0
Line 302 of main3d.F is just after a call to diag, right? I'm surprised you're not getting more verbose output from diag itself. Did the model write a restart record right at the end? You can query the fields there to see how things went bad - I assume they went bad.
You really should have gotten more from diag. Still, I wanted even more info on failure from diag - it is possible to hack it into being more verbose. Or you could shorten your timestep temporarily and try to carry on from a previous restart record.
vivek
#3 Unread post by vivek »
Dear Kate.
Herewith, i am posting. and also attaching my std.out file
418752 2002-12-11 00:00:00.00 9.606996E-03 2.031943E+04 2.031944E+04 1.374937E+17
(035,055,14) 4.031199E-02 7.942155E-03 1.811987E-01 2.106181E+00
DEF_HIS - creating history file, Grid 01: /home/cas/phd/asz178031/scratch/output_3.8/ocean_his_s_4363.nc
WRT_HIS - wrote history fields (Index=1,1) in record = 0000001
DEF_AVG - creating average file, Grid 01: /home/cas/phd/asz178031/scratch/output_3.8/ocean_avg_spin_4362.nc
WRT_AVG - wrote averaged fields in record = 0000001
GET_2DFLD - surface u-wind component, 2002-12-12 00:00:00.00
(Grid=01, Rec=0000346, Index=2, File: uwind2000.nc)
(Tmin= 4018.0000 Tmax= 4383.0000) t = 4363.0000
(Min = -1.57966310E+01 Max = 1.27824886E+01) regrid = F
GET_2DFLD - surface v-wind component, 2002-12-12 00:00:00.00
(Grid=01, Rec=0000346, Index=2, File: vwind2000.nc)
(Min = -1.34390976E+01 Max = 1.40189908E+01) regrid = F
GET_2DFLD - surface air pressure, 2002-12-12 00:00:00.00
(Grid=01, Rec=0000346, Index=2, File: msl2000.nc)
(Min = 1.00288178E+03 Max = 1.03332764E+03) regrid = F
GET_2DFLD - solar shortwave radiation flux, 2002-12-12 00:00:00.00
(Grid=01, Rec=0000346, Index=2, File: swave2000.nc)
(Min = 1.05376880E-05 Max = 8.41412232E-05) regrid = F
GET_2DFLD - net longwave radiation flux, 2002-12-12 00:00:00.00
(Grid=01, Rec=0000346, Index=2, File: lwave2000.nc)
(Min = -3.28714586E-05 Max = -4.05046406E-06) regrid = F
GET_2DFLD - surface air temperature, 2002-12-12 00:00:00.00
(Grid=01, Rec=0000346, Index=2, File: airtemp2000.nc)
(Min = -2.07092871E+01 Max = 3.74314266E+01) regrid = F
GET_2DFLD - surface air relative humidity, 2002-12-12 00:00:00.00
(Grid=01, Rec=0000346, Index=2, File: sh2000.nc)
(Min = 5.90812232E-01 Max = 2.09523956E+01) regrid = F
GET_2DFLD - rain fall rate, 2002-12-12 00:00:00.00
(Grid=01, Rec=0000346, Index=2, File: rainfall2000.nc)
(Min = 0.00000000E+00 Max = 0.00000000E+00) regrid = F
418753 2002-12-11 00:15:00.00 9.607023E-03 2.031943E+04 2.031944E+04 1.374937E+17
(035,055,14) 4.036158E-02 7.966379E-03 1.817778E-01 2.094219E+00
418754 2002-12-11 00:30:00.00 9.607087E-03 2.031943E+04 2.031944E+04 1.374937E+17
(035,055,14) 4.041007E-02 7.990506E-03 1.823481E-01 2.080777E+00
418755 2002-12-11 00:45:00.00 9.607193E-03 2.031943E+04 2.031944E+04 1.374937E+17
(035,055,14) 4.045742E-02 8.014508E-03 1.829106E-01 2.085658E+00
418756 2002-12-11 01:00:00.00 9.607301E-03 2.031943E+04 2.031944E+04 1.374937E+17
(035,055,14) 4.050360E-02 8.038351E-03 1.834644E-01 2.085939E+00
418757 2002-12-11 01:15:00.00 9.607379E-03 2.031943E+04 2.031944E+04 1.374937E+17
(035,055,14) 4.054858E-02 8.062027E-03 1.840086E-01 2.081808E+00
418758 2002-12-11 01:30:00.00 9.607435E-03 2.031944E+04 2.031944E+04 1.374937E+17
(035,055,14) 4.059227E-02 8.085516E-03 1.845457E-01 2.073429E+00
418759 2002-12-11 01:45:00.00 9.607418E-03 2.031944E+04 2.031945E+04 1.374937E+17
(035,055,14) 4.063458E-02 8.108809E-03 1.850749E-01 2.061062E+00
418760 2002-12-11 02:00:00.00 9.607421E-03 2.031944E+04 2.031945E+04 1.374937E+17
(035,055,14) 4.067549E-02 8.131867E-03 1.855973E-01 2.054554E+00
418761 2002-12-11 02:15:00.00 9.607363E-03 2.031944E+04 2.031945E+04 1.374937E+17
(035,055,14) 4.071497E-02 8.154671E-03 1.861121E-01 2.060854E+00
418762 2002-12-11 02:30:00.00 9.607228E-03 2.031944E+04 2.031945E+04 1.374937E+17
(035,055,14) 4.075296E-02 8.177202E-03 1.866194E-01 2.062301E+00
418763 2002-12-11 02:45:00.00 9.607078E-03 2.031944E+04 2.031945E+04 1.374937E+17
(035,055,14) 4.078945E-02 8.199436E-03 1.871210E-01 2.058932E+00
418764 2002-12-11 03:00:00.00 9.606917E-03 2.031944E+04 2.031945E+04 1.374937E+17
(035,055,14) 4.082445E-02 8.221358E-03 1.876167E-01 2.061593E+00
418765 2002-12-11 03:15:00.00 9.606690E-03 2.031944E+04 2.031945E+04 1.374937E+17
(007,001,14) 2.329516E-03 2.611273E-03 2.384847E-01 2.065290E+00
418766 2002-12-11 03:30:00.00 9.606404E-03 2.031944E+04 2.031945E+04 1.374937E+17
(007,001,14) 2.224053E-03 2.650805E-03 2.481263E-01 2.068958E+00
418767 2002-12-11 03:45:00.00 9.606061E-03 2.031944E+04 2.031945E+04 1.374937E+17
(007,001,14) 2.120134E-03 2.689271E-03 2.569250E-01 2.072576E+00
418768 2002-12-11 04:00:00.00 9.605710E-03 2.031944E+04 2.031945E+04 1.374938E+17
(007,001,14) 2.018153E-03 2.725973E-03 2.647864E-01 2.076148E+00
418769 2002-12-11 04:15:00.00 9.605361E-03 2.031944E+04 2.031945E+04 1.374938E+17
(007,001,14) 1.918811E-03 2.760250E-03 2.716689E-01 2.079641E+00
418770 2002-12-11 04:30:00.00 9.605012E-03 2.031944E+04 2.031945E+04 1.374938E+17
(007,001,14) 1.822549E-03 2.791722E-03 2.775749E-01 2.083015E+00
418771 2002-12-11 04:45:00.00 9.604666E-03 2.031944E+04 2.031945E+04 1.374938E+17
(007,001,14) 1.730078E-03 2.819962E-03 2.824765E-01 2.086252E+00
418772 2002-12-11 05:00:00.00 9.604307E-03 2.031944E+04 2.031945E+04 1.374938E+17
(007,001,14) 1.641961E-03 2.844484E-03 2.863330E-01 2.089455E+00
418773 2002-12-11 05:15:00.00 9.603919E-03 2.031944E+04 2.031945E+04 1.374938E+17
(007,001,14) 1.559155E-03 2.865286E-03 2.891805E-01 2.092647E+00
418774 2002-12-11 05:30:00.00 9.603518E-03 2.031944E+04 2.031945E+04 1.374938E+17
(007,001,14) 1.482027E-03 2.882165E-03 2.909749E-01 2.095838E+00
418775 2002-12-11 05:45:00.00 9.603018E-03 2.031944E+04 2.031945E+04 1.374938E+17
(007,001,14) 1.411533E-03 2.895188E-03 2.917363E-01 2.098993E+00
418776 2002-12-11 06:00:00.00 9.602492E-03 2.031944E+04 2.031945E+04 1.374938E+17
(007,001,14) 1.348364E-03 2.904235E-03 2.914680E-01 2.102115E+00
418777 2002-12-11 06:15:00.00 9.601950E-03 2.031944E+04 2.031945E+04 1.374938E+17
(007,001,14) 1.293214E-03 2.909803E-03 2.901849E-01 2.105157E+00
418778 2002-12-11 06:30:00.00 9.601376E-03 2.031944E+04 2.031945E+04 1.374938E+17
(007,001,14) 1.246661E-03 2.912158E-03 2.878984E-01 2.108113E+00
418779 2002-12-11 06:45:00.00 9.600788E-03 2.031944E+04 2.031945E+04 1.374938E+17
(007,001,14) 1.209184E-03 2.911611E-03 2.846300E-01 2.110973E+00
418780 2002-12-11 07:00:00.00 9.600159E-03 2.031944E+04 2.031945E+04 1.374938E+17
(007,001,14) 1.181122E-03 2.907886E-03 2.803985E-01 2.113736E+00
418781 2002-12-11 07:15:00.00 9.599526E-03 2.031944E+04 2.031945E+04 1.374938E+17
(007,001,14) 1.162679E-03 2.901668E-03 2.752127E-01 2.116403E+00
418782 2002-12-11 07:30:00.00 9.598881E-03 2.031944E+04 2.031945E+04 1.374938E+17
(007,001,14) 1.153995E-03 2.893603E-03 2.691093E-01 2.118974E+00
418783 2002-12-11 07:45:00.00 9.598262E-03 2.031944E+04 2.031945E+04 1.374938E+17
(007,001,14) 1.155079E-03 2.884048E-03 2.621191E-01 2.121456E+00
418784 2002-12-11 08:00:00.00 9.597699E-03 2.031944E+04 2.031945E+04 1.374938E+17
(007,001,14) 1.165554E-03 2.873480E-03 2.543010E-01 2.123851E+00
418785 2002-12-11 08:15:00.00 9.597095E-03 2.031944E+04 2.031945E+04 1.374938E+17
(007,001,14) 1.185233E-03 2.862592E-03 2.456371E-01 2.126198E+00
418786 2002-12-11 08:30:00.00 9.596480E-03 2.031944E+04 2.031945E+04 1.374938E+17
(035,055,14) 4.127305E-02 8.579600E-03 1.971503E-01 2.128504E+00
418787 2002-12-11 08:45:00.00 9.595888E-03 2.031944E+04 2.031945E+04 1.374938E+17
(035,055,14) 4.128191E-02 8.588672E-03 1.975191E-01 2.130739E+00
418788 2002-12-11 09:00:00.00 9.595304E-03 2.031944E+04 2.031945E+04 1.374938E+17
(035,055,14) 4.129001E-02 8.597022E-03 1.978805E-01 2.132873E+00
418789 2002-12-11 09:15:00.00 9.594697E-03 2.031944E+04 2.031945E+04 1.374938E+17
(035,055,14) 4.129740E-02 8.604640E-03 1.982351E-01 2.134923E+00
418790 2002-12-11 09:30:00.00 9.594146E-03 2.031944E+04 2.031945E+04 1.374938E+17
(035,055,14) 4.130409E-02 8.611527E-03 1.985820E-01 2.136877E+00
418791 2002-12-11 09:45:00.00 9.593571E-03 2.031944E+04 2.031945E+04 1.374938E+17
(035,055,14) 4.131009E-02 8.617681E-03 1.989219E-01 2.138739E+00
418792 2002-12-11 10:00:00.00 9.593127E-03 2.031944E+04 2.031945E+04 1.374938E+17
(035,055,14) 4.131540E-02 8.623093E-03 1.992539E-01 2.140490E+00
418793 2002-12-11 10:15:00.00 9.592739E-03 2.031944E+04 2.031945E+04 1.374938E+17
(035,055,14) 4.132004E-02 8.627753E-03 1.995786E-01 2.142130E+00
418794 2002-12-11 10:30:00.00 9.592368E-03 2.031944E+04 2.031945E+04 1.374938E+17
(035,055,14) 4.132402E-02 8.631666E-03 1.998944E-01 2.143649E+00
418795 2002-12-11 10:45:00.00 9.592111E-03 2.031944E+04 2.031945E+04 1.374938E+17
(035,055,14) 4.132731E-02 8.634837E-03 2.002034E-01 2.145056E+00
418796 2002-12-11 11:00:00.00 9.591886E-03 2.031944E+04 2.031945E+04 1.374938E+17
(035,055,14) 4.132993E-02 8.637263E-03 2.005040E-01 2.146349E+00
418797 2002-12-11 11:15:00.00 9.591704E-03 2.031944E+04 2.031945E+04 1.374938E+17
(035,055,14) 4.133189E-02 8.638960E-03 2.007970E-01 2.147535E+00
418798 2002-12-11 11:30:00.00 9.591573E-03 2.031944E+04 2.031945E+04 1.374938E+17
(035,055,14) 4.133323E-02 8.639961E-03 2.010819E-01 2.148595E+00
418799 2002-12-11 11:45:00.00 9.591469E-03 2.031944E+04 2.031945E+04 1.374938E+17
(035,055,14) 4.133401E-02 8.640262E-03 2.013587E-01 2.149543E+00
418800 2002-12-11 12:00:00.00 9.591430E-03 2.031944E+04 2.031945E+04 1.374938E+17
(035,055,14) 4.133429E-02 8.639886E-03 2.016259E-01 2.150368E+00
418801 2002-12-11 12:15:00.00 9.591444E-03 2.031944E+04 2.031945E+04 1.374938E+17
(035,055,14) 4.133408E-02 8.638859E-03 2.018827E-01 2.151086E+00
418802 2002-12-11 12:30:00.00 9.591469E-03 2.031944E+04 2.031945E+04 1.374938E+17
(035,055,14) 4.133337E-02 8.637203E-03 2.021298E-01 2.151707E+00
418803 2002-12-11 12:45:00.00 9.591484E-03 2.031945E+04 2.031945E+04 1.374938E+17
(035,055,14) 4.133218E-02 8.634939E-03 2.023677E-01 2.152221E+00
418804 2002-12-11 13:00:00.00 9.591493E-03 2.031945E+04 2.031946E+04 1.374938E+17
(035,055,14) 4.133054E-02 8.632119E-03 2.025948E-01 2.152632E+00
418805 2002-12-11 13:15:00.00 9.591524E-03 2.031945E+04 2.031946E+04 1.374938E+17
(035,055,14) 4.132848E-02 8.628774E-03 2.028131E-01 2.152938E+00
418806 2002-12-11 13:30:00.00 9.591533E-03 2.031945E+04 2.031946E+04 1.374938E+17
(035,055,14) 4.132604E-02 8.624935E-03 2.030211E-01 2.153094E+00
418807 2002-12-11 13:45:00.00 9.591513E-03 2.031945E+04 2.031946E+04 1.374938E+17
(035,055,14) 4.132323E-02 8.620639E-03 2.032187E-01 2.153213E+00
418808 2002-12-11 14:00:00.00 9.591454E-03 2.031945E+04 2.031946E+04 1.374938E+17
(035,055,14) 4.132007E-02 8.615924E-03 2.034049E-01 2.153273E+00
418809 2002-12-11 14:15:00.00 9.591360E-03 2.031945E+04 2.031946E+04 1.374938E+17
(035,055,14) 4.131657E-02 8.610852E-03 2.035791E-01 2.153210E+00
418810 2002-12-11 14:30:00.00 9.591255E-03 2.031945E+04 2.031946E+04 1.374938E+17
(035,055,14) 4.131279E-02 8.605483E-03 2.037417E-01 2.153071E+00
418811 2002-12-11 14:45:00.00 9.591122E-03 2.031945E+04 2.031946E+04 1.374938E+17
(035,055,14) 4.130873E-02 8.599865E-03 2.038945E-01 2.152873E+00
418812 2002-12-11 15:00:00.00 9.590976E-03 2.031945E+04 2.031946E+04 1.374938E+17
(035,055,14) 4.130442E-02 8.594048E-03 2.040353E-01 2.152596E+00
418813 2002-12-11 15:15:00.00 9.590786E-03 2.031945E+04 2.031946E+04 1.374938E+17
(035,055,14) 4.129992E-02 8.588098E-03 2.041631E-01 2.152256E+00
418814 2002-12-11 15:30:00.00 9.590523E-03 2.031945E+04 2.031946E+04 1.374938E+17
(035,055,14) 4.129527E-02 8.582086E-03 2.042791E-01 2.151867E+00
418815 2002-12-11 15:45:00.00 9.590250E-03 2.031945E+04 2.031946E+04 1.374939E+17
(035,055,14) 4.129050E-02 8.576061E-03 2.043816E-01 2.151368E+00
418816 2002-12-11 16:00:00.00 9.589941E-03 2.031945E+04 2.031946E+04 1.374939E+17
(035,055,14) 4.128564E-02 8.570081E-03 2.044711E-01 2.151732E+00
418817 2002-12-11 16:15:00.00 9.589613E-03 2.031945E+04 2.031946E+04 1.374939E+17
(035,055,14) 4.128065E-02 8.564229E-03 2.045453E-01 2.151913E+00
418818 2002-12-11 16:30:00.00 9.589299E-03 2.031945E+04 2.031946E+04 1.374939E+17
(035,055,14) 4.127551E-02 8.558554E-03 2.046080E-01 2.151861E+00
418819 2002-12-11 16:45:00.00 9.588934E-03 2.031945E+04 2.031946E+04 1.374939E+17
(035,055,14) 4.127018E-02 8.553119E-03 2.046568E-01 2.151714E+00
418820 2002-12-11 17:00:00.00 9.588564E-03 2.031945E+04 2.031946E+04 1.374939E+17
(035,055,14) 4.126464E-02 8.547994E-03 2.046936E-01 2.151481E+00
418821 2002-12-11 17:15:00.00 9.588157E-03 2.031945E+04 2.031946E+04 1.374939E+17
(035,055,14) 4.125881E-02 8.543244E-03 2.047181E-01 2.151020E+00
418822 2002-12-11 17:30:00.00 9.587723E-03 2.031945E+04 2.031946E+04 1.374939E+17
(035,055,14) 4.125267E-02 8.538935E-03 2.047326E-01 2.150412E+00
418823 2002-12-11 17:45:00.00 9.587252E-03 2.031945E+04 2.031946E+04 1.374939E+17
(035,055,14) 4.124618E-02 8.535109E-03 2.047376E-01 2.149726E+00
418824 2002-12-11 18:00:00.00 9.586753E-03 2.031945E+04 2.031946E+04 1.374939E+17
(035,055,14) 4.123933E-02 8.531818E-03 2.047333E-01 2.148867E+00
418825 2002-12-11 18:15:00.00 9.586132E-03 2.031945E+04 2.031946E+04 1.374939E+17
(035,055,14) 4.123208E-02 8.529121E-03 2.047206E-01 2.147917E+00
418826 2002-12-11 18:30:00.00 9.585464E-03 2.031945E+04 2.031946E+04 1.374939E+17
(035,055,14) 4.122444E-02 8.527028E-03 2.047044E-01 2.146855E+00
418827 2002-12-11 18:45:00.00 9.584688E-03 2.031945E+04 2.031946E+04 1.374939E+17
(035,055,14) 4.121636E-02 8.525570E-03 2.046809E-01 2.145694E+00
418828 2002-12-11 19:00:00.00 9.583844E-03 2.031945E+04 2.031946E+04 1.374939E+17
(035,055,14) 4.120780E-02 8.524770E-03 2.046525E-01 2.144394E+00
418829 2002-12-11 19:15:00.00 9.582991E-03 2.031945E+04 2.031946E+04 1.374939E+17
(035,055,14) 4.119869E-02 8.524646E-03 2.046207E-01 2.142990E+00
418830 2002-12-11 19:30:00.00 9.582083E-03 2.031945E+04 2.031946E+04 1.374939E+17
(035,055,14) 4.118906E-02 8.525199E-03 2.045879E-01 2.141540E+00
418831 2002-12-11 19:45:00.00 9.581142E-03 2.031945E+04 2.031946E+04 1.374939E+17
(035,055,14) 4.117886E-02 8.526429E-03 2.045539E-01 2.140008E+00
418832 2002-12-11 20:00:00.00 9.580163E-03 2.031945E+04 2.031946E+04 1.374939E+17
(035,055,14) 4.116806E-02 8.528317E-03 2.045216E-01 2.138335E+00
418833 2002-12-11 20:15:00.00 9.579148E-03 2.031945E+04 2.031946E+04 1.374939E+17
(035,055,14) 4.115662E-02 8.530847E-03 2.044916E-01 2.136630E+00
418834 2002-12-11 20:30:00.00 9.578103E-03 2.031945E+04 2.031946E+04 1.374939E+17
(035,055,14) 4.114447E-02 8.534018E-03 2.044666E-01 2.134849E+00
418835 2002-12-11 20:45:00.00 9.577064E-03 2.031945E+04 2.031946E+04 1.374939E+17
(035,055,14) 4.113158E-02 8.537699E-03 2.044472E-01 2.132961E+00
418836 2002-12-11 21:00:00.00 9.576034E-03 2.031945E+04 2.031946E+04 1.374939E+17
(035,055,14) 4.111790E-02 8.541914E-03 2.044358E-01 2.130952E+00
418837 2002-12-11 21:15:00.00 9.575043E-03 2.031946E+04 2.031946E+04 1.374939E+17
(035,055,14) 4.110338E-02 8.546576E-03 2.044345E-01 2.128919E+00
418838 2002-12-11 21:30:00.00 9.574020E-03 2.031946E+04 2.031946E+04 1.374939E+17
(035,055,14) 4.108800E-02 8.551614E-03 2.044449E-01 2.126803E+00
418839 2002-12-11 21:45:00.00 9.573014E-03 2.031946E+04 2.031947E+04 1.374939E+17
(035,055,14) 4.107176E-02 8.556954E-03 2.044668E-01 2.124639E+00
418840 2002-12-11 22:00:00.00 9.572022E-03 2.031946E+04 2.031947E+04 1.374939E+17
(035,055,14) 4.105466E-02 8.562521E-03 2.045010E-01 2.122312E+00
418841 2002-12-11 22:15:00.00 9.571029E-03 2.031946E+04 2.031947E+04 1.374939E+17
(035,055,14) 4.103668E-02 8.568239E-03 2.045481E-01 2.119868E+00
418842 2002-12-11 22:30:00.00 9.570054E-03 2.031946E+04 2.031947E+04 1.374939E+17
(035,055,14) 4.101781E-02 8.574033E-03 2.046088E-01 2.117394E+00
418843 2002-12-11 22:45:00.00 9.569131E-03 2.031946E+04 2.031947E+04 1.374939E+17
(035,055,14) 4.099801E-02 8.579828E-03 2.046847E-01 2.114793E+00
418844 2002-12-11 23:00:00.00 9.568230E-03 2.031946E+04 2.031947E+04 1.374939E+17
(035,055,14) 4.097724E-02 8.585546E-03 2.047763E-01 2.112190E+00
418845 2002-12-11 23:15:00.00 9.567356E-03 2.031946E+04 2.031947E+04 1.374939E+17
(035,055,14) 4.095548E-02 8.591110E-03 2.048842E-01 2.109466E+00
418846 2002-12-11 23:30:00.00 9.566489E-03 2.031946E+04 2.031947E+04 1.374939E+17
(035,055,14) 4.093270E-02 8.596452E-03 2.050079E-01 2.106826E+00
418847 2002-12-11 23:45:00.00 9.565646E-03 2.031946E+04 2.031947E+04 1.374939E+17
(035,055,14) 4.090888E-02 8.601494E-03 2.051487E-01 2.104126E+00
418848 2002-12-12 00:00:00.00 9.564848E-03 2.031946E+04 2.031947E+04 1.374939E+17
(035,055,14) 4.088405E-02 8.606176E-03 2.053055E-01 2.101408E+00
DEF_HIS - creating history file, Grid 01: /home/cas/phd/asz178031/scratch/output_3.8/ocean_his_s_4364.nc
DEF_AVG - creating average file, Grid 01: /home/cas/phd/asz178031/scratch/output_3.8/ocean_avg_spin_4363.nc
GET_2DFLD - surface u-wind component, 2002-12-13 00:00:00.00
(Grid=01, Rec=0000347, Index=1, File: uwind2000.nc)
(Tmin= 4018.0000 Tmax= 4383.0000) t = 4364.0000
(Min = -1.52937923E+01 Max = 1.58307248E+01) regrid = F
GET_2DFLD - surface v-wind component, 2002-12-13 00:00:00.00
(Grid=01, Rec=0000347, Index=1, File: vwind2000.nc)
(Min = -1.69041780E+01 Max = 1.46248834E+01) regrid = F
GET_2DFLD - surface air pressure, 2002-12-13 00:00:00.00
(Grid=01, Rec=0000347, Index=1, File: msl2000.nc)
(Min = 1.00268330E+03 Max = 1.03265984E+03) regrid = F
GET_2DFLD - solar shortwave radiation flux, 2002-12-13 00:00:00.00
(Grid=01, Rec=0000347, Index=1, File: swave2000.nc)
(Min = 8.91158464E-06 Max = 8.27960294E-05) regrid = F
GET_2DFLD - net longwave radiation flux, 2002-12-13 00:00:00.00
(Grid=01, Rec=0000347, Index=1, File: lwave2000.nc)
(Min = -3.46038738E-05 Max = -2.65196056E-06) regrid = F
GET_2DFLD - surface air temperature, 2002-12-13 00:00:00.00
(Grid=01, Rec=0000347, Index=1, File: airtemp2000.nc)
(Min = -2.46860550E+01 Max = 3.55970476E+01) regrid = F
GET_2DFLD - surface air relative humidity, 2002-12-13 00:00:00.00
(Grid=01, Rec=0000347, Index=1, File: sh2000.nc)
(Min = 2.88521601E-01 Max = 2.09923920E+01) regrid = F
GET_2DFLD - rain fall rate, 2002-12-13 00:00:00.00
(Grid=01, Rec=0000347, Index=1, File: rainfall2000.nc)
418849 2002-12-12 00:15:00.00 9.564113E-03 2.031946E+04 2.031947E+04 1.374939E+17
(035,055,14) 4.085824E-02 8.610454E-03 2.054785E-01 2.098668E+00
418850 2002-12-12 00:30:00.00 9.563394E-03 2.031946E+04 2.031947E+04 1.374939E+17
(035,055,14) 4.083151E-02 8.614267E-03 2.056679E-01 2.095914E+00
418851 2002-12-12 00:45:00.00 9.562712E-03 2.031946E+04 2.031947E+04 1.374939E+17
(035,055,14) 4.080395E-02 8.617563E-03 2.058720E-01 2.093098E+00
418852 2002-12-12 01:00:00.00 9.562072E-03 2.031946E+04 2.031947E+04 1.374939E+17
(035,055,14) 4.077564E-02 8.620320E-03 2.060892E-01 2.090247E+00
418853 2002-12-12 01:15:00.00 9.561481E-03 2.031946E+04 2.031947E+04 1.374939E+17
(035,055,14) 4.074663E-02 8.622507E-03 2.063189E-01 2.087341E+00
418854 2002-12-12 01:30:00.00 9.560923E-03 2.031946E+04 2.031947E+04 1.374939E+17
(035,055,14) 4.071694E-02 8.624103E-03 2.065593E-01 2.084386E+00
418855 2002-12-12 01:45:00.00 9.560394E-03 2.031946E+04 2.031947E+04 1.374939E+17
(035,055,14) 4.068662E-02 8.625098E-03 2.068088E-01 2.081378E+00
418856 2002-12-12 02:00:00.00 9.559905E-03 2.031946E+04 2.031947E+04 1.374939E+17
(008,003,14) 9.861432E-03 1.727154E-03 2.462114E-01 2.078322E+00
418857 2002-12-12 02:15:00.00 9.559460E-03 2.031947E+04 2.031947E+04 1.374939E+17
(008,003,14) 9.906078E-03 1.537031E-03 2.537124E-01 2.075225E+00
418858 2002-12-12 02:30:00.00 9.559047E-03 2.031947E+04 2.031948E+04 1.374940E+17
(008,003,14) 9.933637E-03 1.344522E-03 2.601653E-01 2.072086E+00
418859 2002-12-12 02:45:00.00 9.558668E-03 2.031947E+04 2.031948E+04 1.374940E+17
(008,003,14) 9.944446E-03 1.149804E-03 2.655359E-01 2.068916E+00
418860 2002-12-12 03:00:00.00 9.558279E-03 2.031947E+04 2.031948E+04 1.374940E+17
(008,003,14) 9.938613E-03 9.529652E-04 2.698129E-01 2.065713E+00
418861 2002-12-12 03:15:00.00 9.557928E-03 2.031947E+04 2.031948E+04 1.374940E+17
(008,003,14) 9.916572E-03 7.542118E-04 2.729735E-01 2.062487E+00
418862 2002-12-12 03:30:00.00 9.557595E-03 2.031947E+04 2.031948E+04 1.374940E+17
(008,003,14) 9.878448E-03 5.536429E-04 2.750085E-01 2.059240E+00
418863 2002-12-12 03:45:00.00 9.557274E-03 2.031947E+04 2.031948E+04 1.374940E+17
(008,003,14) 9.824712E-03 3.514427E-04 2.759109E-01 2.055974E+00
418864 2002-12-12 04:00:00.00 9.556948E-03 2.031947E+04 2.031948E+04 1.374940E+17
(008,003,14) 9.755834E-03 1.477060E-04 2.756747E-01 2.052669E+00
418865 2002-12-12 04:15:00.00 9.556623E-03 2.031947E+04 2.031948E+04 1.374940E+17
(008,003,14) 9.672104E-03 5.729085E-05 2.743159E-01 2.049243E+00
418866 2002-12-12 04:30:00.00 9.556307E-03 2.031947E+04 2.031948E+04 1.374940E+17
(008,003,14) 9.573974E-03 2.633801E-04 2.718402E-01 2.045813E+00
418867 2002-12-12 04:45:00.00 9.556006E-03 2.031947E+04 2.031948E+04 1.374940E+17
(008,003,14) 9.462022E-03 4.701999E-04 2.682546E-01 2.042425E+00
418868 2002-12-12 05:00:00.00 9.555706E-03 2.031947E+04 2.031948E+04 1.374940E+17
(008,003,14) 9.336752E-03 6.772519E-04 2.635661E-01 2.039004E+00
418869 2002-12-12 05:15:00.00 9.555393E-03 2.031947E+04 2.031948E+04 1.374940E+17
(008,003,14) 9.198475E-03 8.841527E-04 2.578270E-01 2.035535E+00
418870 2002-12-12 05:30:00.00 9.555061E-03 2.031947E+04 2.031948E+04 1.374940E+17
(008,003,14) 9.047768E-03 1.090305E-03 2.510495E-01 2.031964E+00
418871 2002-12-12 05:45:00.00 9.554697E-03 2.031947E+04 2.031948E+04 1.374940E+17
(035,055,14) 4.017166E-02 8.584844E-03 2.105928E-01 2.028234E+00
418872 2002-12-12 06:00:00.00 9.554284E-03 2.031947E+04 2.031948E+04 1.374940E+17
(035,055,14) 4.014032E-02 8.581468E-03 2.107407E-01 2.024291E+00
418873 2002-12-12 06:15:00.00 9.553841E-03 2.031947E+04 2.031948E+04 1.374940E+17
(035,055,14) 4.010927E-02 8.578345E-03 2.108735E-01 2.020100E+00
418874 2002-12-12 06:30:00.00 9.553355E-03 2.031947E+04 2.031948E+04 1.374940E+17
(035,055,14) 4.007852E-02 8.575526E-03 2.109905E-01 2.015676E+00
418875 2002-12-12 06:45:00.00 9.552836E-03 2.031947E+04 2.031948E+04 1.374940E+17
(035,055,14) 4.004812E-02 8.573070E-03 2.110923E-01 2.011097E+00
418876 2002-12-12 07:00:00.00 9.552289E-03 2.031947E+04 2.031948E+04 1.374940E+17
(035,055,14) 4.001813E-02 8.571018E-03 2.111793E-01 2.008250E+00
418877 2002-12-12 07:15:00.00 9.551695E-03 2.031947E+04 2.031948E+04 1.374940E+17
(035,055,14) 3.998860E-02 8.569418E-03 2.112504E-01 2.006578E+00
418878 2002-12-12 07:30:00.00 9.551075E-03 2.031947E+04 2.031948E+04 1.374940E+17
(035,055,14) 3.995958E-02 8.568431E-03 2.113063E-01 2.002498E+00
418879 2002-12-12 07:45:00.00 9.550466E-03 2.031947E+04 2.031948E+04 1.374940E+17
(035,055,14) 3.993102E-02 8.568256E-03 2.113475E-01 1.997056E+00
418880 2002-12-12 08:00:00.00 9.549859E-03 2.031947E+04 2.031948E+04 1.374940E+17
(035,055,14) 3.990291E-02 8.568594E-03 2.113711E-01 1.999202E+00
418881 2002-12-12 08:15:00.00 9.549274E-03 2.031947E+04 2.031948E+04 1.374940E+17
(035,055,14) 3.987519E-02 8.569486E-03 2.113766E-01 1.997792E+00
418882 2002-12-12 08:30:00.00 9.548692E-03 2.031947E+04 2.031948E+04 1.374940E+17
(035,055,14) 3.984767E-02 8.570808E-03 2.113641E-01 1.993037E+00
418883 2002-12-12 08:45:00.00 9.548109E-03 2.031947E+04 2.031948E+04 1.374940E+17
(035,055,14) 3.982030E-02 8.572498E-03 2.113371E-01 1.985064E+00
418884 2002-12-12 09:00:00.00 9.547529E-03 2.031947E+04 2.031948E+04 1.374940E+17
(035,055,14) 3.979296E-02 8.574485E-03 2.112992E-01 1.978139E+00
418885 2002-12-12 09:15:00.00 9.546990E-03 2.031947E+04 2.031948E+04 1.374940E+17
(035,055,14) 3.976555E-02 8.576714E-03 2.112475E-01 1.980248E+00
418886 2002-12-12 09:30:00.00 9.546435E-03 2.031947E+04 2.031948E+04 1.374940E+17
(035,055,14) 3.973794E-02 8.579117E-03 2.111861E-01 1.981364E+00
418887 2002-12-12 09:45:00.00 9.545910E-03 2.031947E+04 2.031948E+04 1.374940E+17
(035,055,14) 3.971003E-02 8.581628E-03 2.111152E-01 1.982396E+00
418888 2002-12-12 10:00:00.00 9.545389E-03 2.031947E+04 2.031948E+04 1.374940E+17
(035,055,14) 3.968176E-02 8.584194E-03 2.110349E-01 1.990665E+00
418889 2002-12-12 10:15:00.00 9.544866E-03 2.031947E+04 2.031948E+04 1.374940E+17
(035,055,14) 3.965303E-02 8.586761E-03 2.109481E-01 2.001117E+00
418890 2002-12-12 10:30:00.00 9.544376E-03 2.031947E+04 2.031948E+04 1.374940E+17
(035,055,14) 3.962381E-02 8.589277E-03 2.108545E-01 2.014964E+00
418891 2002-12-12 10:45:00.00 9.543883E-03 2.031947E+04 2.031948E+04 1.374940E+17
(035,055,14) 3.959401E-02 8.591724E-03 2.107542E-01 2.028114E+00
418892 2002-12-12 11:00:00.00 9.543431E-03 2.031947E+04 2.031948E+04 1.374940E+17
(035,055,14) 3.956350E-02 8.594100E-03 2.106511E-01 2.039766E+00
418893 2002-12-12 11:15:00.00 9.543027E-03 2.031948E+04 2.031948E+04 1.374940E+17
(035,055,14) 3.953236E-02 8.596203E-03 2.105478E-01 2.049856E+00
418894 2002-12-12 11:30:00.00 9.542540E-03 2.031948E+04 2.031949E+04 1.374940E+17
(043,065,14) 9.182729E-03 7.515117E-03 2.421947E-01 2.058300E+00
418895 2002-12-12 11:45:00.00 9.542150E-03 2.031948E+04 2.031949E+04 1.374940E+17
(043,065,14) 9.201650E-03 7.486241E-03 2.433339E-01 2.065111E+00
418896 2002-12-12 12:00:00.00 9.541840E-03 2.031948E+04 2.031949E+04 1.374940E+17
(043,065,14) 9.221073E-03 7.462276E-03 2.444314E-01 2.070401E+00
418897 2002-12-12 12:15:00.00 9.541544E-03 2.031948E+04 2.031949E+04 1.374941E+17
(043,065,14) 9.240575E-03 7.442165E-03 2.454806E-01 2.073933E+00
418898 2002-12-12 12:30:00.00 9.541333E-03 2.031948E+04 2.031949E+04 1.374941E+17
(043,065,14) 9.260076E-03 7.423513E-03 2.464961E-01 2.075788E+00
418899 2002-12-12 12:45:00.00 9.540941E-03 2.031948E+04 2.031949E+04 1.374941E+17
(043,065,14) 9.279113E-03 7.408715E-03 2.474633E-01 2.080644E+00
418900 2002-12-12 13:00:00.00 9.540602E-03 2.031948E+04 2.031949E+04 1.374941E+17
(043,065,14) 9.295273E-03 7.416804E-03 2.483734E-01 2.083983E+00
418901 2002-12-12 13:15:00.00 9.540276E-03 2.031948E+04 2.031949E+04 1.374941E+17
(043,065,14) 9.309177E-03 7.423585E-03 2.492290E-01 2.085767E+00
418902 2002-12-12 13:30:00.00 9.539929E-03 2.031948E+04 2.031949E+04 1.374941E+17
(043,065,14) 9.321441E-03 7.433898E-03 2.500390E-01 2.086042E+00
418903 2002-12-12 13:45:00.00 9.539496E-03 2.031948E+04 2.031949E+04 1.374941E+17
(043,065,14) 9.331315E-03 7.447631E-03 2.508032E-01 2.084851E+00
418904 2002-12-12 14:00:00.00 9.539060E-03 2.031948E+04 2.031949E+04 1.374941E+17
(043,065,14) 9.338718E-03 7.461955E-03 2.515165E-01 2.082259E+00
418905 2002-12-12 14:15:00.00 9.538613E-03 2.031948E+04 2.031949E+04 1.374941E+17
(043,065,14) 9.343584E-03 7.474157E-03 2.521804E-01 2.079991E+00
418906 2002-12-12 14:30:00.00 9.538280E-03 2.031948E+04 2.031949E+04 1.374941E+17
(043,065,14) 9.346739E-03 7.482916E-03 2.528058E-01 2.087243E+00
418907 2002-12-12 14:45:00.00 9.537791E-03 2.031948E+04 2.031949E+04 1.374941E+17
(043,065,14) 9.348834E-03 7.488796E-03 2.533844E-01 2.093280E+00
418908 2002-12-12 15:00:00.00 9.537261E-03 2.031948E+04 2.031949E+04 1.374941E+17
(043,065,14) 9.350505E-03 7.492592E-03 2.539096E-01 2.098078E+00
418909 2002-12-12 15:15:00.00 9.536729E-03 2.031949E+04 2.031949E+04 1.374941E+17
(043,065,14) 9.352241E-03 7.494733E-03 2.543951E-01 2.108073E+00
418910 2002-12-12 15:30:00.00 9.536247E-03 2.031949E+04 2.031950E+04 1.374941E+17
(043,065,14) 9.354519E-03 7.495449E-03 2.548379E-01 2.120987E+00
418911 2002-12-12 15:45:00.00 9.535761E-03 2.031949E+04 2.031950E+04 1.374941E+17
(043,065,14) 9.357686E-03 7.494203E-03 2.552287E-01 2.132400E+00
418912 2002-12-12 16:00:00.00 9.535274E-03 2.031949E+04 2.031950E+04 1.374941E+17
(043,065,14) 9.361927E-03 7.491977E-03 2.555706E-01 2.142203E+00
418913 2002-12-12 16:15:00.00 9.534774E-03 2.031949E+04 2.031950E+04 1.374941E+17
(043,065,14) 9.368019E-03 7.489850E-03 2.558506E-01 2.150317E+00
418914 2002-12-12 16:30:00.00 9.534276E-03 2.031949E+04 2.031950E+04 1.374941E+17
(043,065,14) 9.375581E-03 7.487028E-03 2.560941E-01 2.156673E+00
418915 2002-12-12 16:45:00.00 9.533783E-03 2.031949E+04 2.031950E+04 1.374941E+17
(043,065,14) 9.384499E-03 7.483615E-03 2.562924E-01 2.161233E+00
418916 2002-12-12 17:00:00.00 9.533245E-03 2.031949E+04 2.031950E+04 1.374941E+17
(043,065,14) 9.394612E-03 7.479122E-03 2.564495E-01 2.169891E+00
418917 2002-12-12 17:15:00.00 9.532699E-03 2.031949E+04 2.031950E+04 1.374941E+17
(043,065,14) 9.406025E-03 7.472582E-03 2.565701E-01 2.179445E+00
418918 2002-12-12 17:30:00.00 9.532141E-03 2.031949E+04 2.031950E+04 1.374941E+17
(043,065,14) 9.418283E-03 7.464152E-03 2.566592E-01 2.187204E+00
418919 2002-12-12 17:45:00.00 9.531610E-03 2.031949E+04 2.031950E+04 1.374941E+17
(043,065,14) 9.430600E-03 7.454377E-03 2.567199E-01 2.193121E+00
418920 2002-12-12 18:00:00.00 9.531075E-03 2.031949E+04 2.031950E+04 1.374941E+17
(043,065,14) 9.442720E-03 7.443703E-03 2.567591E-01 2.197173E+00
418921 2002-12-12 18:15:00.00 9.530525E-03 2.031949E+04 2.031950E+04 1.374941E+17
(043,065,14) 9.454185E-03 7.432432E-03 2.567895E-01 2.199348E+00
418922 2002-12-12 18:30:00.00 9.529927E-03 2.031949E+04 2.031950E+04 1.374941E+17
(043,065,14) 9.464713E-03 7.420271E-03 2.567957E-01 2.199633E+00
418923 2002-12-12 18:45:00.00 9.529269E-03 2.031949E+04 2.031950E+04 1.374941E+17
(043,065,14) 9.474335E-03 7.407394E-03 2.567891E-01 2.197995E+00
418924 2002-12-12 19:00:00.00 9.528565E-03 2.031949E+04 2.031950E+04 1.374941E+17
(043,065,14) 9.483277E-03 7.393712E-03 2.567661E-01 2.202599E+00
418925 2002-12-12 19:15:00.00 9.527838E-03 2.031949E+04 2.031950E+04 1.374941E+17
(043,065,14) 9.491579E-03 7.379284E-03 2.567246E-01 2.208271E+00
418926 2002-12-12 19:30:00.00 9.527072E-03 2.031949E+04 2.031950E+04 1.374941E+17
(043,065,14) 9.499467E-03 7.364026E-03 2.566703E-01 2.211790E+00
418927 2002-12-12 19:45:00.00 9.526318E-03 2.031949E+04 2.031950E+04 1.374941E+17
(043,065,14) 9.507324E-03 7.347982E-03 2.566021E-01 2.213124E+00
418928 2002-12-12 20:00:00.00 9.525563E-03 2.031949E+04 2.031950E+04 1.374942E+17
(043,065,14) 9.515518E-03 7.331097E-03 2.565193E-01 2.212199E+00
418929 2002-12-12 20:15:00.00 9.524808E-03 2.031949E+04 2.031950E+04 1.374942E+17
(043,065,14) 9.524344E-03 7.313726E-03 2.564117E-01 2.209099E+00
418930 2002-12-12 20:30:00.00 9.524045E-03 2.031949E+04 2.031950E+04 1.374942E+17
(043,065,14) 9.534138E-03 7.295820E-03 2.563035E-01 2.203864E+00
418931 2002-12-12 20:45:00.00 9.523191E-03 2.031949E+04 2.031950E+04 1.374942E+17
(043,065,14) 9.545390E-03 7.284087E-03 2.561811E-01 2.204370E+00
418932 2002-12-12 21:00:00.00 9.522321E-03 2.031949E+04 2.031950E+04 1.374942E+17
(043,065,14) 9.558107E-03 7.274718E-03 2.560506E-01 2.209049E+00
418933 2002-12-12 21:15:00.00 9.521454E-03 2.031949E+04 2.031950E+04 1.374942E+17
(043,065,14) 9.572539E-03 7.265844E-03 2.559080E-01 2.211729E+00
418934 2002-12-12 21:30:00.00 9.520641E-03 2.031949E+04 2.031950E+04 1.374942E+17
(043,065,14) 9.588870E-03 7.257240E-03 2.557524E-01 2.212457E+00
418935 2002-12-12 21:45:00.00 9.519899E-03 2.031949E+04 2.031950E+04 1.374942E+17
(043,065,14) 9.607218E-03 7.248456E-03 2.555983E-01 2.211222E+00
418936 2002-12-12 22:00:00.00 9.519189E-03 2.031949E+04 2.031950E+04 1.374942E+17
(043,065,14) 9.627663E-03 7.239641E-03 2.554186E-01 2.208055E+00
418937 2002-12-12 22:15:00.00 9.518501E-03 2.031949E+04 2.031950E+04 1.374942E+17
(043,065,14) 9.650187E-03 7.230845E-03 2.552251E-01 2.202978E+00
418938 2002-12-12 22:30:00.00 9.517858E-03 2.031949E+04 2.031950E+04 1.374942E+17
(043,065,14) 9.674483E-03 7.221455E-03 2.550124E-01 2.196042E+00
418939 2002-12-12 22:45:00.00 9.517287E-03 2.031949E+04 2.031950E+04 1.374942E+17
(043,065,14) 9.700158E-03 7.210959E-03 2.547780E-01 2.187288E+00
418940 2002-12-12 23:00:00.00 9.516773E-03 2.031949E+04 2.031950E+04 1.374942E+17
(043,065,14) 9.727159E-03 7.193647E-03 2.545249E-01 2.177573E+00
418941 2002-12-12 23:15:00.00 9.516321E-03 2.031949E+04 2.031950E+04 1.374942E+17
(043,065,14) 9.755601E-03 7.174308E-03 2.542581E-01 2.174172E+00
418942 2002-12-12 23:30:00.00 9.515905E-03 2.031949E+04 2.031950E+04 1.374942E+17
(043,065,14) 9.785076E-03 7.153769E-03 2.539767E-01 2.168845E+00
418943 2002-12-12 23:45:00.00 9.515496E-03 2.031949E+04 2.031950E+04 1.374942E+17
(043,065,14) 9.815346E-03 7.132483E-03 2.536759E-01 2.161668E+00
418944 2002-12-13 00:00:00.00 9.515141E-03 2.031949E+04 2.031950E+04 1.374942E+17
(043,065,14) 9.846163E-03 7.110627E-03 2.533603E-01 2.152746E+00
DEF_HIS - creating history file, Grid 01: /home/cas/phd/asz178031/scratch/output_3.8/ocean_his_s_4365.nc
DEF_AVG - creating average file, Grid 01: /home/cas/phd/asz178031/scratch/output_3.8/ocean_avg_spin_4364.nc
GET_2DFLD - surface u-wind component, 2002-12-14 00:00:00.00
(Grid=01, Rec=0000348, Index=2, File: uwind2000.nc)
(Tmin= 4018.0000 Tmax= 4383.0000) t = 4365.0000
(Min = -1.58818474E+01 Max = 2.06390738E+01) regrid = F
GET_2DFLD - surface v-wind component, 2002-12-14 00:00:00.00
(Grid=01, Rec=0000348, Index=2, File: vwind2000.nc)
(Min = -1.50410586E+01 Max = 1.48816240E+01) regrid = F
GET_2DFLD - surface air pressure, 2002-12-14 00:00:00.00
(Grid=01, Rec=0000348, Index=2, File: msl2000.nc)
(Min = 1.00382671E+03 Max = 1.02689172E+03) regrid = F
GET_2DFLD - solar shortwave radiation flux, 2002-12-14 00:00:00.00
(Grid=01, Rec=0000348, Index=2, File: swave2000.nc)
(Min = 1.07562120E-05 Max = 8.68039727E-05) regrid = F
GET_2DFLD - net longwave radiation flux, 2002-12-14 00:00:00.00
(Grid=01, Rec=0000348, Index=2, File: lwave2000.nc)
(Min = -3.50335644E-05 Max = -5.75366808E-06) regrid = F
GET_2DFLD - surface air temperature, 2002-12-14 00:00:00.00
(Grid=01, Rec=0000348, Index=2, File: airtemp2000.nc)
(Min = -2.27221979E+01 Max = 3.31230274E+01) regrid = F
GET_2DFLD - surface air relative humidity, 2002-12-14 00:00:00.00
(Grid=01, Rec=0000348, Index=2, File: sh2000.nc)
(Min = 4.31713670E-01 Max = 2.08712533E+01) regrid = F
GET_2DFLD - rain fall rate, 2002-12-14 00:00:00.00
(Grid=01, Rec=0000348, Index=2, File: rainfall2000.nc)
418945 2002-12-13 00:15:00.00 9.514838E-03 2.031949E+04 2.031950E+04 1.374942E+17
(043,065,14) 9.877286E-03 7.088310E-03 2.530295E-01 2.142172E+00
418946 2002-12-13 00:30:00.00 9.514554E-03 2.031949E+04 2.031950E+04 1.374942E+17
(043,065,14) 9.908462E-03 7.065619E-03 2.526807E-01 2.137008E+00
418947 2002-12-13 00:45:00.00 9.514275E-03 2.031950E+04 2.031950E+04 1.374942E+17
(043,065,14) 9.939451E-03 7.042629E-03 2.523128E-01 2.131214E+00
418948 2002-12-13 01:00:00.00 9.514037E-03 2.031950E+04 2.031951E+04 1.374942E+17
(043,065,14) 9.970010E-03 7.019399E-03 2.519268E-01 2.124265E+00
418949 2002-12-13 01:15:00.00 9.513839E-03 2.031950E+04 2.031951E+04 1.374942E+17
(043,065,14) 9.999963E-03 6.995985E-03 2.515256E-01 2.116209E+00
418950 2002-12-13 01:30:00.00 9.513676E-03 2.031950E+04 2.031951E+04 1.374942E+17
(043,065,14) 1.002919E-02 6.972410E-03 2.511096E-01 2.107168E+00
418951 2002-12-13 01:45:00.00 9.513550E-03 2.031950E+04 2.031951E+04 1.374942E+17
(043,065,14) 1.005756E-02 6.948721E-03 2.506752E-01 2.101981E+00
418952 2002-12-13 02:00:00.00 9.513442E-03 2.031950E+04 2.031951E+04 1.374942E+17
(043,065,14) 1.008498E-02 6.924967E-03 2.502231E-01 2.109726E+00
418953 2002-12-13 02:15:00.00 9.513362E-03 2.031950E+04 2.031951E+04 1.374942E+17
(043,065,14) 1.011135E-02 6.901145E-03 2.497538E-01 2.117097E+00
418954 2002-12-13 02:30:00.00 9.513313E-03 2.031950E+04 2.031951E+04 1.374942E+17
(043,065,14) 1.013663E-02 6.877270E-03 2.492688E-01 2.122986E+00
418955 2002-12-13 02:45:00.00 9.513280E-03 2.031950E+04 2.031951E+04 1.374942E+17
(043,065,14) 1.016084E-02 6.853363E-03 2.487684E-01 2.127384E+00
418956 2002-12-13 03:00:00.00 9.513255E-03 2.031950E+04 2.031951E+04 1.374942E+17
(043,065,14) 1.018398E-02 6.829436E-03 2.482523E-01 2.130241E+00
418957 2002-12-13 03:15:00.00 9.513236E-03 2.031950E+04 2.031951E+04 1.374942E+17
(043,065,14) 1.020699E-02 6.805509E-03 2.477252E-01 2.131553E+00
418958 2002-12-13 03:30:00.00 9.513222E-03 2.031950E+04 2.031951E+04 1.374942E+17
(043,065,14) 1.022953E-02 6.781609E-03 2.471795E-01 2.131324E+00
418959 2002-12-13 03:45:00.00 9.513216E-03 2.031950E+04 2.031951E+04 1.374942E+17
(043,065,14) 1.025161E-02 6.757786E-03 2.466171E-01 2.129542E+00
418960 2002-12-13 04:00:00.00 9.513225E-03 2.031950E+04 2.031951E+04 1.374943E+17
(043,065,14) 1.027335E-02 6.734059E-03 2.460413E-01 2.126252E+00
418961 2002-12-13 04:15:00.00 9.513247E-03 2.031950E+04 2.031951E+04 1.374943E+17
(043,065,14) 1.029472E-02 6.710463E-03 2.454504E-01 2.121533E+00
418962 2002-12-13 04:30:00.00 9.513276E-03 2.031950E+04 2.031951E+04 1.374943E+17
(043,065,14) 1.031573E-02 6.687033E-03 2.448450E-01 2.116289E+00
418963 2002-12-13 04:45:00.00 9.513295E-03 2.031950E+04 2.031951E+04 1.374943E+17
(043,065,14) 1.033632E-02 6.663823E-03 2.442254E-01 2.112326E+00
418964 2002-12-13 05:00:00.00 9.513295E-03 2.031950E+04 2.031951E+04 1.374943E+17
(043,065,14) 1.035649E-02 6.640861E-03 2.435947E-01 2.107087E+00
418965 2002-12-13 05:15:00.00 9.513321E-03 2.031950E+04 2.031951E+04 1.374943E+17
(043,065,14) 1.037616E-02 6.618191E-03 2.429505E-01 2.100692E+00
418966 2002-12-13 05:30:00.00 9.513321E-03 2.031950E+04 2.031951E+04 1.374943E+17
(043,065,14) 1.039528E-02 6.595875E-03 2.422964E-01 2.093260E+00
418967 2002-12-13 05:45:00.00 9.513316E-03 2.031950E+04 2.031951E+04 1.374943E+17
(043,065,14) 1.041385E-02 6.573947E-03 2.416359E-01 2.084928E+00
418968 2002-12-13 06:00:00.00 9.513313E-03 2.031950E+04 2.031951E+04 1.374943E+17
(043,065,13) 1.014506E-02 7.138468E-03 2.406808E-01 2.075794E+00
418969 2002-12-13 06:15:00.00 9.513294E-03 2.031950E+04 2.031951E+04 1.374943E+17
(043,065,13) 1.016209E-02 7.112199E-03 2.401315E-01 2.065951E+00
418970 2002-12-13 06:30:00.00 9.513256E-03 2.031950E+04 2.031951E+04 1.374943E+17
(043,065,13) 1.017833E-02 7.085739E-03 2.395746E-01 2.055496E+00
418971 2002-12-13 06:45:00.00 9.513204E-03 2.031950E+04 2.031951E+04 1.374943E+17
(043,065,13) 1.019374E-02 7.059196E-03 2.390131E-01 2.044522E+00
418972 2002-12-13 07:00:00.00 9.513120E-03 2.031950E+04 2.031951E+04 1.374943E+17
(043,065,13) 1.020833E-02 7.032682E-03 2.384518E-01 2.033135E+00
418973 2002-12-13 07:15:00.00 9.513003E-03 2.031950E+04 2.031951E+04 1.374943E+17
(043,065,13) 1.022209E-02 7.006378E-03 2.378904E-01 2.024554E+00
418974 2002-12-13 07:30:00.00 9.512865E-03 2.031950E+04 2.031951E+04 1.374943E+17
(043,065,13) 1.023502E-02 6.980413E-03 2.373310E-01 2.017966E+00
418975 2002-12-13 07:45:00.00 9.512689E-03 2.031950E+04 2.031951E+04 1.374943E+17
(043,065,13) 1.024707E-02 6.954988E-03 2.367731E-01 2.011501E+00
418976 2002-12-13 08:00:00.00 9.512515E-03 2.031950E+04 2.031951E+04 1.374943E+17
(043,065,13) 1.025821E-02 6.930273E-03 2.362201E-01 2.010148E+00
418977 2002-12-13 08:15:00.00 9.512356E-03 2.031950E+04 2.031950E+04 1.374943E+17
(043,065,13) 1.026844E-02 6.906418E-03 2.356764E-01 2.013665E+00
418978 2002-12-13 08:30:00.00 9.512240E-03 2.031950E+04 2.031950E+04 1.374943E+17
(043,065,13) 1.027778E-02 6.883531E-03 2.351428E-01 2.016982E+00
418979 2002-12-13 08:45:00.00 9.512121E-03 2.031949E+04 2.031950E+04 1.374943E+17
(043,065,13) 1.028629E-02 6.861664E-03 2.346198E-01 2.019537E+00
418980 2002-12-13 09:00:00.00 9.512024E-03 2.031949E+04 2.031950E+04 1.374943E+17
(043,065,13) 1.029398E-02 6.840872E-03 2.341062E-01 2.023495E+00
418981 2002-12-13 09:15:00.00 9.511922E-03 2.031949E+04 2.031950E+04 1.374943E+17
(043,065,13) 1.030094E-02 6.821181E-03 2.336088E-01 2.025876E+00
418982 2002-12-13 09:30:00.00 9.511795E-03 2.031949E+04 2.031950E+04 1.374943E+17
(043,065,13) 1.030725E-02 6.802595E-03 2.331271E-01 2.030893E+00
418983 2002-12-13 09:45:00.00 9.511661E-03 2.031949E+04 2.031950E+04 1.374943E+17
(043,065,13) 1.031297E-02 6.785182E-03 2.326613E-01 2.036558E+00
418984 2002-12-13 10:00:00.00 9.511564E-03 2.031949E+04 2.031950E+04 1.374943E+17
(043,065,13) 1.031817E-02 6.768978E-03 2.322119E-01 2.040712E+00
418985 2002-12-13 10:15:00.00 9.511474E-03 2.031949E+04 2.031950E+04 1.374943E+17
(043,065,13) 1.032288E-02 6.754004E-03 2.317796E-01 2.043846E+00
418986 2002-12-13 10:30:00.00 9.511445E-03 2.031949E+04 2.031950E+04 1.374943E+17
(043,065,13) 1.032718E-02 6.740252E-03 2.313681E-01 2.054818E+00
418987 2002-12-13 10:45:00.00 9.511394E-03 2.031949E+04 2.031950E+04 1.374943E+17
(043,065,13) 1.033115E-02 6.727714E-03 2.309779E-01 2.067096E+00
418988 2002-12-13 11:00:00.00 9.511372E-03 2.031949E+04 2.031950E+04 1.374943E+17
(043,065,13) 1.033486E-02 6.716381E-03 2.306093E-01 2.088590E+00
418989 2002-12-13 11:15:00.00 9.511347E-03 2.031949E+04 2.031950E+04 1.374943E+17
(043,065,13) 1.033839E-02 6.706249E-03 2.302611E-01 2.107932E+00
418990 2002-12-13 11:30:00.00 9.511373E-03 2.031949E+04 2.031950E+04 1.374943E+17
(043,065,13) 1.034178E-02 6.697286E-03 2.299353E-01 2.124827E+00
Node # 0 CPU: 6914.783
Node # 24 CPU: 6967.804
Node # 48 CPU: 6964.828
Node # 1 CPU: 6976.963
Node # 25 CPU: 6970.326
Node # 2 CPU: 6981.826
Node # 12 CPU: 6990.889
Node # 8 CPU: 6990.472
Node # 10 CPU: 6989.976
Node # 6 CPU: 6986.419
Node # 14 CPU: 6984.811
Node # 16 CPU: 6992.716
Node # 19 CPU: 6979.281
Node # 4 CPU: 6981.153
Node # 17 CPU: 6984.229
Node # 21 CPU: 6981.727
Node # 23 CPU: 6992.109
Node # 49 CPU: 6973.431
Node # 3 CPU: 6985.601
Node # 13 CPU: 6992.806
Node # 9 CPU: 6990.342
Node # 11 CPU: 6988.090
Node # 7 CPU: 6990.233
Node # 15 CPU: 6989.334
Total: 2011688.538
Allocation and array initialization .............. 10.263 ( 0.0005 %)
Ocean state initialization ....................... 11.675 ( 0.0006 %)
Reading of input data ............................ 4786.378 ( 0.2379 %)
Processing of input data ......................... 139008.134 ( 6.9100 %)
Processing of output time averaged data .......... 8179.399 ( 0.4066 %)
Computation of vertical boundary conditions ...... 818.841 ( 0.0407 %)
Computation of global information integrals ...... 13464.368 ( 0.6693 %)
Writing of output data ........................... 264310.538 (13.1387 %)
Model 2D kernel .................................. 451081.756 (22.4230 %)
2D/3D coupling, vertical metrics ................. 27665.303 ( 1.3752 %)
Omega vertical velocity .......................... 8070.221 ( 0.4012 %)
Equation of state for seawater ................... 25984.614 ( 1.2917 %)
Biological module, source/sink terms ............. 52137.427 ( 2.5917 %)
Atmosphere-Ocean bulk flux parameterization ...... 9343.004 ( 0.4644 %)
KPP vertical mixing parameterization ............. 49602.950 ( 2.4657 %)
3D equations right-side terms .................... 12677.215 ( 0.6302 %)
3D equations predictor step ...................... 115690.550 ( 5.7509 %)
Pressure gradient ................................ 3748.581 ( 0.1863 %)
Harmonic mixing of tracers, geopotentials ........ 56809.390 ( 2.8240 %)
Biharmonic mixing of tracers, geopotentials ...... 3457.965 ( 0.1719 %)
Harmonic stress tensor, S-surfaces ............... 6646.808 ( 0.3304 %)
Corrector time-step for 3D momentum .............. 27359.676 ( 1.3600 %)
Corrector time-step for tracers .................. 721658.906 (35.8733 %)
Reading model state vector ....................... 316.548 ( 0.0157 %)
Total: 2002840.510 99.5602
Message Passage: 2D halo exchanges ............... 316438.580 (15.7300 %)
Message Passage: 3D halo exchanges ............... 72369.162 ( 3.5974 %)
Message Passage: 4D halo exchanges ............... 256424.231 (12.7467 %)
Message Passage: data broadcast .................. 103689.153 ( 5.1543 %)
Message Passage: data reduction .................. 295625.197 (14.6954 %)
Message Passage: data gathering .................. 163950.556 ( 8.1499 %)
Message Passage: data scattering.................. 1157.285 ( 0.0575 %)
Message Passage: synchronization barrier ......... 63.571 ( 0.0032 %)
Total: 1209717.736 60.1344
Unique code regions profiled ..................... 2002840.510 99.5602 %
Residual, non-profiled code ...................... 8848.028 0.4398 %
All percentages are with respect to total time = 2011688.538
number of time records written in AVERAGE file = 00000001
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_stflux.h
Biology model header files used:
ROMS/Nonlinear/Biology/fennel.h
Found Error: 01 Line: 350 Source: ROMS/Utility/close_io.F
I am using
NTIMES == 420768.0d0
DT == 900
when i am doing SPUNUP model runs fine. when i shift to inter-annual, end of the year model showing like that.
Thanks..looking forward for reply.
std_ocean_bio_2000_new.dat
(6.88 MiB) Downloaded 461 times
That isn't helpful. If the model didn't write a restart record at the end, you need to write one yourself so you can examine what went wrong. Still, it's worth trying to run through the problem by temporarily using a shorter timestep.
vivek
#5 Unread post by vivek »
Dear Kate.
When i am using DT=600, It works fine. Why I am getting above error using dt=900.
#6 Unread post by kate »
You have hit upon a model instability. Just be glad you can get through it with a shorter timestep. You will have to do a good bit more digging yourself if you want to fully understand that instability.
vivek
#7 Unread post by vivek »
Okay.. thank you very much
