I have roms coupled with swan blows up at the edge of land masking. But I am not sure was the land masking cause this blowing up, Can anyone give me clues to solve this problem. The setting for this idealized case is :
grid: 100*600 with 50 m as resolution.
Time: 2 s as one step
forcing: constant V=10m/s by ANA_WINDS
The lats information in the log file is:
15742 0 08:44:44 6.728878E-04 7.704470E+01 7.704537E+01 1.996960E+09
(72,418,4) 1.101258E-03 3.497115E-03 1.475979E+01 1.141224E+00
15743 0 08:44:46 6.724167E-04 7.704471E+01 7.704538E+01 1.996960E+09
(72,418,4) 1.058046E-03 3.455374E-03 2.131247E+01 1.134830E+00
15744 0 08:44:48 6.727023E-04 7.704472E+01 7.704539E+01 1.996959E+09
(72,418,4) 9.984038E-04 3.450809E-03 2.334097E+01 1.154328E+00
15745 0 08:44:50 6.722832E-04 7.704473E+01 7.704540E+01 1.996959E+09
(72,418,4) 9.336520E-04 3.423746E-03 1.825475E+01 1.152967E+00
15746 0 08:44:52 6.721376E-04 7.704474E+01 7.704542E+01 1.996958E+09
(72,418,5) 8.756595E-04 3.358673E-03 2.920161E+01 1.121689E+00
15747 0 08:44:54 6.722495E-04 7.704125E+01 7.704192E+01 1.996958E+09
(25,309,8) 1.458497E-02 6.720823E-04 2.075809E-01 1.114682E+00
DIAG rho trouble 18613.744384652891 1
zeta 1 Closed Radiation Closed Closed
ubar 1 Closed Radiation Closed Closed
vbar 1 Closed Radiation Closed Closed
u 1 Closed Radiation Closed Closed
v 1 Closed Radiation Closed Closed
temp 1 Closed Radiation Closed Closed
salt 1 Closed Radiation Closed Closed
mud_01 1 Gradient Gradient Gradient Closed
tke 1 Closed Radiation Closed Closed
ubar_stokes 1 Closed Radiation Closed Closed
vbar_stokes 1 Closed Radiation Closed Closed
u_stokes 1 Closed Radiation Closed Closed
v_stokes 1 Closed Radiation Closed Closed
IDEALIZED_MOUNT_HOPEIdealized Mount Hope Case
ANA_BPFLUX Analytical bottom passive tracers fluxes.
ANA_SEDIMENT Analytical sediment initial conditions.
ANA_SPFLUX Analytical surface passive tracer fluxes.
DIAGNOSTICS_UV Computing and writing momentum diagnostic terms.
MASKING Land/Sea masking.
MCT_LIB Using Model Coupling Toolkit library.
WEC_VF Vortex Force wave current interaction.
WDISS_WAVEMOD Wave energy dissipation acquired from coupled wave model.
NONLINEAR Nonlinear Model.
SEDIMENT Cohesive and noncohesive sediments.
SED_MORPH Allow bottom model elevation to evolve.
SUSPLOAD Activate suspended sediment transport.
NONCOHESIVE_BED1 Activate non-cohesive (original) sediment bed.
SPLINES_VDIFF Parabolic Spline Reconstruction for Vertical Diffusion.
SPLINES_VVISC Parabolic Spline Reconstruction for Vertical Viscosity.
SSW_BBL Styles and Glenn Bottom Boundary Layer - modified.
SSW_CALC_ZNOT Internal computation of bottom roughness.
STATIONS Writing out station data.
SWAN_COUPLING SWAN model coupling.
UV_ADV Advection of momentum.
UV_KIRBY Compute uwave and vwave Kirby avg velocities.
WAVES_OCEAN Two-way wave-ocean models coupling.
