Hi dear sir/madam,
When I installation the ROMS(run the build.bash),I have got the following error messages.
I am using gfotran 4.8 compiler,and NETCDF 4.1.3.
lbc.f90:(.text+0x217e):对‘__netcdf_MOD_nf90_get_att_text’未定义的引用
/root/Projects/upwelling/Build/libUTIL.a(lbc.o):在函数‘lbc_putatt_’中:
lbc.f90:(.text+0x2abf):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
/root/Projects/upwelling/Build/libUTIL.a(distribute.o):在函数‘__distribute_mod_MOD_mp_ncwrite2d’中:
distribute.f90:(.text+0xd0cd):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
distribute.f90:(.text+0xd384):对‘__netcdf_MOD_nf90_put_var_1d_eightbytereal’未定义的引用
distribute.f90:(.text+0xd656):对‘__netcdf_MOD_nf90_put_var_1d_eightbytereal’未定义的引用
/root/Projects/upwelling/Build/libUTIL.a(distribute.o):在函数‘__distribute_mod_MOD_mp_ncwrite1d’中:
distribute.f90:(.text+0xdea8):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
distribute.f90:(.text+0xe171):对‘__netcdf_MOD_nf90_put_var_1d_eightbytereal’未定义的引用
distribute.f90:(.text+0xe40c):对‘__netcdf_MOD_nf90_put_var_1d_eightbytereal’未定义的引用
/root/Projects/upwelling/Build/libUTIL.a(distribute.o):在函数‘__distribute_mod_MOD_mp_ncread2d’中:
distribute.f90:(.text+0xec8f):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
distribute.f90:(.text+0xf493):对‘__netcdf_MOD_nf90_get_var_1d_eightbytereal’未定义的引用
/root/Projects/upwelling/Build/libUTIL.a(distribute.o):在函数‘__distribute_mod_MOD_mp_ncread1d’中:
distribute.f90:(.text+0xfc57):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
distribute.f90:(.text+0x10345):对‘__netcdf_MOD_nf90_get_var_1d_eightbytereal’未定义的引用
/root/Projects/upwelling/Build/libUTIL.a(nf_fwrite2d.o):在函数‘__nf_fwrite2d_mod_MOD_nf_fwrite2d’中:
nf_fwrite2d.f90:(.text+0x458):对‘__netcdf_MOD_nf90_put_var_1d_eightbytereal’未定义的引用
/root/Projects/upwelling/Build/libUTIL.a(close_io.o):在函数‘close_out_’中:
close_io.f90:(.text+0x1130):对‘__netcdf_MOD_nf90_strerror’未定义的引用
/root/Projects/upwelling/Build/libUTIL.a(nf_fwrite3d.o):在函数‘__nf_fwrite3d_mod_MOD_nf_fwrite3d’中:
nf_fwrite3d.f90:(.text+0x578):对‘__netcdf_MOD_nf90_put_var_1d_eightbytereal’未定义的引用
/root/Projects/upwelling/Build/libUTIL.a(nf_fread3d.o):在函数‘__nf_fread3d_mod_MOD_nf_fread3d’中:
nf_fread3d.f90:(.text+0x83e):对‘__netcdf_MOD_nf90_get_var_1d_eightbytereal’未定义的引用
/root/Projects/upwelling/Build/libUTIL.a(nf_fread2d.o):在函数‘__nf_fread2d_mod_MOD_nf_fread2d’中:
nf_fread2d.f90:(.text+0xc27):对‘__netcdf_MOD_nf90_get_var_1d_eightbytereal’未定义的引用
/root/Projects/upwelling/Build/libUTIL.a(def_info.o):在函数‘def_info_’中:
def_info.f90:(.text+0xf2cd):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_info.f90:(.text+0xf33d):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_info.f90:(.text+0xf42c):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_info.f90:(.text+0x135f3):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_info.f90:(.text+0x13720):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
/root/Projects/upwelling/Build/libUTIL.a(def_info.o):def_info.f90:(.text+0x137e2): more undefined references to `__netcdf_MOD_nf90_put_att_text' follow
/root/Projects/upwelling/Build/libUTIL.a(def_var.o):在函数‘__def_var_mod_MOD_def_var’中:
def_var.f90:(.text+0x23d):对‘__netcdf_MOD_nf90_def_var_manydims’未定义的引用
def_var.f90:(.text+0x2f2):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_var.f90:(.text+0x36c):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_var.f90:(.text+0x41b):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_var.f90:(.text+0x4dd):对‘__netcdf_MOD_nf90_put_att_one_eightbytereal’未定义的引用
def_var.f90:(.text+0x5c9):对‘__netcdf_MOD_nf90_put_att_one_eightbytereal’未定义的引用
def_var.f90:(.text+0x6f1):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_var.f90:(.text+0x7f8):对‘__netcdf_MOD_nf90_put_att_eightbytereal’未定义的引用
def_var.f90:(.text+0x872):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_var.f90:(.text+0x8ec):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_var.f90:(.text+0x966):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_var.f90:(.text+0x9e0):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_var.f90:(.text+0xa63):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
/root/Projects/upwelling/Build/libUTIL.a(def_var.o):def_var.f90:(.text+0xae2): more undefined references to `__netcdf_MOD_nf90_put_att_text' follow
def_var.f90:(.text+0xba7):对‘__netcdf_MOD_nf90_put_att_one_eightbytereal’未定义的引用
def_var.f90:(.text+0xc95):对‘__netcdf_MOD_nf90_put_att_one_eightbytereal’未定义的引用
def_var.f90:(.text+0xd8b):对‘__netcdf_MOD_nf90_put_att_one_eightbytereal’未定义的引用
def_var.f90:(.text+0xe31):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_var.f90:(.text+0xeab):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_var.f90:(.text+0x10f6):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_var.f90:(.text+0x1172):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_var.f90:(.text+0x12c3):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
/root/Projects/upwelling/Build/libUTIL.a(def_var.o):def_var.f90:(.text+0x136d): more undefined references to `__netcdf_MOD_nf90_put_att_text' follow
def_var.f90:(.text+0x17fd):对‘__netcdf_MOD_nf90_put_att_fourbyteint’未定义的引用
def_var.f90:(.text+0x186a):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_var.f90:(.text+0x19d2):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_var.f90:(.text+0x1b1e):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_var.f90:(.text+0x1c6c):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_var.f90:(.text+0x1ceb):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
/root/Projects/upwelling/Build/libUTIL.a(def_var.o):def_var.f90:(.text+0x1d58): more undefined references to `__netcdf_MOD_nf90_put_att_text' follow
def_var.f90:(.text+0x2c47):对‘__netcdf_MOD_nf90_def_var_scalar’未定义的引用
def_var.f90:(.text+0x2d15):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_var.f90:(.text+0x2fd0):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_var.f90:(.text+0x3083):对‘__netcdf_MOD_nf90_put_att_one_fourbytereal’未定义的引用
def_var.f90:(.text+0x30f3):对‘__netcdf_MOD_nf90_put_att_one_fourbytereal’未定义的引用
def_var.f90:(.text+0x3169):对‘__netcdf_MOD_nf90_put_att_one_fourbyteint’未定义的引用
def_var.f90:(.text+0x31d9):对‘__netcdf_MOD_nf90_put_att_one_fourbyteint’未定义的引用
def_var.f90:(.text+0x362b):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_var.f90:(.text+0x3698):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_var.f90:(.text+0x3705):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_var.f90:(.text+0x3774):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_var.f90:(.text+0x38f3):对‘__netcdf_MOD_nf90_put_att_one_fourbytereal’未定义的引用
def_var.f90:(.text+0x3961):对‘__netcdf_MOD_nf90_put_att_one_fourbyteint’未定义的引用
def_var.f90:(.text+0x3d03):对‘__netcdf_MOD_nf90_put_att_one_fourbytereal’未定义的引用
def_var.f90:(.text+0x3d70):对‘__netcdf_MOD_nf90_put_att_one_fourbyteint’未定义的引用
def_var.f90:(.text+0x3de3):对‘__netcdf_MOD_nf90_put_att_one_fourbytereal’未定义的引用
def_var.f90:(.text+0x3e51):对‘__netcdf_MOD_nf90_put_att_one_fourbyteint’未定义的引用
def_var.f90:(.text+0x40b3):对‘__netcdf_MOD_nf90_put_att_text’未定义的引用
def_var.f90:(.text+0x4155):对‘__netcdf_MOD_nf90_put_att_fourbytereal’未定义的引用
def_var.f90:(.text+0x41ca):对‘__netcdf_MOD_nf90_put_att_fourbyteint’未定义的引用
/root/Projects/upwelling/Build/libUTIL.a(def_dim.o):在函数‘def_dim_’中:
def_dim.f90:(.text+0xfc):对‘__netcdf_MOD_nf90_def_dim’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_sync’中:
mod_netcdf.f90:(.text+0xba):对‘__netcdf_MOD_nf90_sync’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_redef’中:
mod_netcdf.f90:(.text+0x25a):对‘__netcdf_MOD_nf90_redef’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_open’中:
mod_netcdf.f90:(.text+0x3b3):对‘__netcdf_MOD_nf90_open’未定义的引用
mod_netcdf.f90:(.text+0x55a):对‘__netcdf_MOD_nf90_open’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_enddef’中:
mod_netcdf.f90:(.text+0x653):对‘__netcdf_MOD_nf90_enddef’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_create’中:
mod_netcdf.f90:(.text+0x846):对‘__netcdf_MOD_nf90_create’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_close’中:
mod_netcdf.f90:(.text+0xab0):对‘__netcdf_MOD_nf90_close’未定义的引用
mod_netcdf.f90:(.text+0xb3d):对‘__netcdf_MOD_nf90_get_att_text’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_get_fvar_0d.constprop.1’中:
mod_netcdf.f90:(.text+0xdb3):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
mod_netcdf.f90:(.text+0xdd8):对‘__netcdf_MOD_nf90_get_var_eightbytereal’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_put_svar_1d’中:
mod_netcdf.f90:(.text+0x134b):对‘__netcdf_MOD_nf90_put_var_1d_text’未定义的引用
mod_netcdf.f90:(.text+0x1615):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_put_svar_0d’中:
mod_netcdf.f90:(.text+0x18da):对‘__netcdf_MOD_nf90_put_var_text’未定义的引用
mod_netcdf.f90:(.text+0x1bf6):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_put_lvar_2d’中:
mod_netcdf.f90:(.text+0x21d1):对‘__netcdf_MOD_nf90_put_var_2d_fourbyteint’未定义的引用
mod_netcdf.f90:(.text+0x24cc):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_put_lvar_1d’中:
mod_netcdf.f90:(.text+0x2a45):对‘__netcdf_MOD_nf90_put_var_1d_fourbyteint’未定义的引用
mod_netcdf.f90:(.text+0x2d6b):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_put_lvar_0d’中:
mod_netcdf.f90:(.text+0x31ce):对‘__netcdf_MOD_nf90_put_var_1d_fourbyteint’未定义的引用
mod_netcdf.f90:(.text+0x3493):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
mod_netcdf.f90:(.text+0x35fd):对‘__netcdf_MOD_nf90_put_var_fourbyteint’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_put_ivar_2d’中:
mod_netcdf.f90:(.text+0x397a):对‘__netcdf_MOD_nf90_put_var_2d_fourbyteint’未定义的引用
mod_netcdf.f90:(.text+0x3c8b):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_put_ivar_1d’中:
mod_netcdf.f90:(.text+0x4115):对‘__netcdf_MOD_nf90_put_var_1d_fourbyteint’未定义的引用
mod_netcdf.f90:(.text+0x43fb):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_put_ivar_0d’中:
mod_netcdf.f90:(.text+0x4844):对‘__netcdf_MOD_nf90_put_var_1d_fourbyteint’未定义的引用
mod_netcdf.f90:(.text+0x4b13):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
mod_netcdf.f90:(.text+0x4c7d):对‘__netcdf_MOD_nf90_put_var_fourbyteint’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_put_fvar_4d’中:
mod_netcdf.f90:(.text+0x5095):对‘__netcdf_MOD_nf90_put_var_4d_eightbytereal’未定义的引用
mod_netcdf.f90:(.text+0x5411):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_put_fvar_3d’中:
mod_netcdf.f90:(.text+0x5936):对‘__netcdf_MOD_nf90_put_var_3d_eightbytereal’未定义的引用
mod_netcdf.f90:(.text+0x5c81):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_put_fvar_2d’中:
mod_netcdf.f90:(.text+0x615a):对‘__netcdf_MOD_nf90_put_var_2d_eightbytereal’未定义的引用
mod_netcdf.f90:(.text+0x646b):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_put_fvar_1d’中:
mod_netcdf.f90:(.text+0x68f5):对‘__netcdf_MOD_nf90_put_var_1d_eightbytereal’未定义的引用
mod_netcdf.f90:(.text+0x6bdb):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_put_fvar_0d’中:
mod_netcdf.f90:(.text+0x702b):对‘__netcdf_MOD_nf90_put_var_1d_eightbytereal’未定义的引用
mod_netcdf.f90:(.text+0x72e8):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
mod_netcdf.f90:(.text+0x7452):对‘__netcdf_MOD_nf90_put_var_eightbytereal’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_get_svar_1d’中:
mod_netcdf.f90:(.text+0x76e3):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
mod_netcdf.f90:(.text+0x783b):对‘__netcdf_MOD_nf90_get_var_1d_text’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_get_svar_0d’中:
mod_netcdf.f90:(.text+0x7df3):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
mod_netcdf.f90:(.text+0x7eed):对‘__netcdf_MOD_nf90_get_var_text’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_get_ivar_2d’中:
mod_netcdf.f90:(.text+0x8476):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
mod_netcdf.f90:(.text+0x85e1):对‘__netcdf_MOD_nf90_get_var_2d_fourbyteint’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_get_ivar_1d’中:
mod_netcdf.f90:(.text+0x8c23):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
mod_netcdf.f90:(.text+0x8d64):对‘__netcdf_MOD_nf90_get_var_1d_fourbyteint’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_get_ivar_0d’中:
mod_netcdf.f90:(.text+0x92f3):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
mod_netcdf.f90:(.text+0x9431):对‘__netcdf_MOD_nf90_get_var_1d_fourbyteint’未定义的引用
mod_netcdf.f90:(.text+0x962a):对‘__netcdf_MOD_nf90_get_var_fourbyteint’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_get_lvar_1d’中:
mod_netcdf.f90:(.text+0x9a4a):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
mod_netcdf.f90:(.text+0x9aa5):对‘__netcdf_MOD_nf90_inquire_variable’未定义的引用
mod_netcdf.f90:(.text+0xa0fc):对‘__netcdf_MOD_nf90_get_var_1d_fourbyteint’未定义的引用
mod_netcdf.f90:(.text+0xa35c):对‘__netcdf_MOD_nf90_get_var_1d_text’未定义的引用
mod_netcdf.f90:(.text+0xa438):对‘__netcdf_MOD_nf90_get_var_1d_fourbyteint’未定义的引用
mod_netcdf.f90:(.text+0xa4d3):对‘__netcdf_MOD_nf90_get_var_1d_text’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_get_lvar_0d’中:
mod_netcdf.f90:(.text+0xa73e):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
mod_netcdf.f90:(.text+0xa790):对‘__netcdf_MOD_nf90_inquire_variable’未定义的引用
mod_netcdf.f90:(.text+0xad79):对‘__netcdf_MOD_nf90_get_var_1d_fourbyteint’未定义的引用
mod_netcdf.f90:(.text+0xaea5):对‘__netcdf_MOD_nf90_get_var_text’未定义的引用
mod_netcdf.f90:(.text+0xaf10):对‘__netcdf_MOD_nf90_get_var_fourbyteint’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_get_fvar_0d’中:
mod_netcdf.f90:(.text+0xb193):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
mod_netcdf.f90:(.text+0xb2d3):对‘__netcdf_MOD_nf90_get_var_1d_eightbytereal’未定义的引用
mod_netcdf.f90:(.text+0xb4c8):对‘__netcdf_MOD_nf90_get_var_eightbytereal’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_get_satt’中:
mod_netcdf.f90:(.text+0xb970):对‘__netcdf_MOD_nf90_inquire’未定义的引用
mod_netcdf.f90:(.text+0xb9ef):对‘__netcdf_MOD_nf90_inq_attname’未定义的引用
mod_netcdf.f90:(.text+0xba8a):对‘__netcdf_MOD_nf90_get_att_text’未定义的引用
mod_netcdf.f90:(.text+0xbc46):对‘__netcdf_MOD_nf90_inquire_variable’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_get_fatt’中:
mod_netcdf.f90:(.text+0xc3e4):对‘__netcdf_MOD_nf90_inquire’未定义的引用
mod_netcdf.f90:(.text+0xc46f):对‘__netcdf_MOD_nf90_inq_attname’未定义的引用
mod_netcdf.f90:(.text+0xc50e):对‘__netcdf_MOD_nf90_get_att_one_eightbytereal’未定义的引用
mod_netcdf.f90:(.text+0xc6e8):对‘__netcdf_MOD_nf90_inquire_variable’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_get_fvar_4d’中:
mod_netcdf.f90:(.text+0xd8d2):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
mod_netcdf.f90:(.text+0xdaa1):对‘__netcdf_MOD_nf90_get_var_4d_eightbytereal’未定义的引用
mod_netcdf.f90:(.text+0xe3ea):对‘__netcdf_MOD_nf90_get_var_4d_eightbytereal’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_get_fvar_3d’中:
mod_netcdf.f90:(.text+0xf13a):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
mod_netcdf.f90:(.text+0xf2e0):对‘__netcdf_MOD_nf90_get_var_3d_eightbytereal’未定义的引用
mod_netcdf.f90:(.text+0xfba8):对‘__netcdf_MOD_nf90_get_var_3d_eightbytereal’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_get_fvar_2d’中:
mod_netcdf.f90:(.text+0x104f9):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
mod_netcdf.f90:(.text+0x10675):对‘__netcdf_MOD_nf90_get_var_2d_eightbytereal’未定义的引用
mod_netcdf.f90:(.text+0x10adb):对‘__netcdf_MOD_nf90_get_var_2d_eightbytereal’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_get_fvar_1d’中:
mod_netcdf.f90:(.text+0x11701):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
mod_netcdf.f90:(.text+0x11845):对‘__netcdf_MOD_nf90_get_var_1d_eightbytereal’未定义的引用
mod_netcdf.f90:(.text+0x11ca8):对‘__netcdf_MOD_nf90_get_var_1d_eightbytereal’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_inq_varid’中:
mod_netcdf.f90:(.text+0x12257):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_inq_var’中:
mod_netcdf.f90:(.text+0x124e4):对‘__netcdf_MOD_nf90_inquire’未定义的引用
mod_netcdf.f90:(.text+0x12d6d):对‘__netcdf_MOD_nf90_inquire_dimension’未定义的引用
mod_netcdf.f90:(.text+0x12f13):对‘__netcdf_MOD_nf90_inq_attname’未定义的引用
mod_netcdf.f90:(.text+0x12f7b):对‘__netcdf_MOD_nf90_inquire_attribute’未定义的引用
mod_netcdf.f90:(.text+0x13029):对‘__netcdf_MOD_nf90_get_att_one_eightbytereal’未定义的引用
mod_netcdf.f90:(.text+0x13453):对‘__netcdf_MOD_nf90_inquire_variable’未定义的引用
mod_netcdf.f90:(.text+0x1352a):对‘__netcdf_MOD_nf90_inq_attname’未定义的引用
mod_netcdf.f90:(.text+0x13767):对‘__netcdf_MOD_nf90_get_att_text’未定义的引用
mod_netcdf.f90:(.text+0x13d1c):对‘__netcdf_MOD_nf90_get_att_one_fourbyteint’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_check_var’中:
mod_netcdf.f90:(.text+0x14b6e):对‘__netcdf_MOD_nf90_inq_varid’未定义的引用
mod_netcdf.f90:(.text+0x14b99):对‘__netcdf_MOD_nf90_get_var_fourbyteint’未定义的引用
mod_netcdf.f90:(.text+0x14ce1):对‘__netcdf_MOD_nf90_inquire’未定义的引用
mod_netcdf.f90:(.text+0x1543f):对‘__netcdf_MOD_nf90_inquire_variable’未定义的引用
mod_netcdf.f90:(.text+0x15501):对‘__netcdf_MOD_nf90_inq_attname’未定义的引用
/root/Projects/upwelling/Build/libMODS.a(mod_netcdf.o):在函数‘__mod_netcdf_MOD_netcdf_get_dim’中:
mod_netcdf.f90:(.text+0x15ad0):对‘__netcdf_MOD_nf90_inquire’未定义的引用
mod_netcdf.f90:(.text+0x15ba2):对‘__netcdf_MOD_nf90_inquire_dimension’未定义的引用
collect2: 错误:ld 返回 1
make: *** [/root/Projects/upwelling/oceanM] 错误 1
I have attached the build.bash file and build.bash.log.txt file.
Thank you for your help.
The error of build.bash
- Location: Huazhong University of science and technology
build.bash.log.txt
- (48 Bytes) Downloaded 587 times
build.bash
- (16.49 KiB) Downloaded 562 times
Re: The error of build.bash
You can check our FAQ.
Thank your for your reply,I will try my best to resolve it.kate wrote:You can check our FAQ.
Thanks。
