mp_collect bug when compiling with define PARALLEL_IO
xiaozhu557
#1 Unread post by xiaozhu557 »
I want to try the parallel input/output in order to increase the speed of I/O. But I have found a bug with the function mp_collect when I compiled the ROMS code 857 with the option #define PARALLEL_IO.
I have double checked that the parameter A of function mp_collect_f(ng,model,Npts,Aspv,A) is defined in the MODULE distribute_mod as
real(r8), intent(inout) :: A(Npts)
, however it is used in the function nf_fread2d with the parameter Awrk is defined as
real(r8),allocatable :: Awrk(:,:)
So, while compling it with the option #define PARALLEL_IO, I have got the error messages as follow,
nf_fread2d.f90(314): error #6285: There is no matching specific subroutine for this generic subroutine call. [MP_COLLECT]
CALL mp_collect (ng, model, Npts, IniVal, Awrk)
compilation aborted for nf_fread2d.f90 (code 1)
make: *** [/fs01/home/Build/nf_fread2d.o] Error 1
Anyone can help me to figure out this bug? Thanks.
Re: mp_collect bug when compiling with define PARALLEL_IO
That's weird - my copy of the trunk code lists (line 2598):
Try that.
xiaozhu557
#3 Unread post by xiaozhu557 »
Thanks for your reply, Kate.
It is also
in my copy. I am sorry for the error in my last post. I have fixed it in my last post.
But I would like to let you know that the bug which I mentioned in my last post is caused by the disagreement between the shapes of the actual argument (Awrk(:,:),two dimensions) and the dummy argument (A(:), one dimension) for the subroutine mp_collect.
Ah, then the solution is to add another mp_collect_f routine to the interface with the 2-D array.
Frankly, my I/O speed is limited by the output, not the input. I separated the parallelness of the I/O into two different switches in my branch. After trying the PARALLEL_OUT option, I ended up going for compression of the output instead of parallel output. Which is faster depends on many things, but we need the disk space more. ;)
xiaozhu557
#5 Unread post by xiaozhu557 »
Thank you for your reminding on the compression of the output, Kate.
I would like to know whether you have the mp_collect_f routine to the interface with the 2-D array ? Since I am not good at the parallel programming. If you have, could you share it with me?
Thanks.
#6 Unread post by kate »
No, I don't have it. However, distribute.F has other examples of using arrays of differing shapes, such as mp_assemblef_1d and mp_assemblef_2d.
#7 Unread post by arango »
The PARALLEL_IO is slower than serial I/O, and it won't help you to improve I/O performance. The last time that I checked that option, it was not working well, and I haven't checked if the NetCDF4 library has made progress on it. I can fix the issue with nf_read2d.F but it will not help you much. There is no need to introduce mp_collect for 2D arrays to the module interface in distribute.F.
In parallel I/O, we need parallel access to all input and output files. The parallel I/O only makes sense when you have a computer infrastructure (disk storage) that allows it. As far as I know, regular desktop or clusters don't have such infrastructure. We can find it in super-computer centers.
I assume that you already know that all input files need to be NetCDF4 (HDF5) type files. Also, all output files are the NetCDF4 type.
I am planning to make an update the code tomorrow to give the user more options fine-tune the MPI communications an accelerate the I/O.
xiaozhu557
#8 Unread post by xiaozhu557 »
Many thanks Kate and Arango.
It is a good news to me. I am using super-computer to run ROMS.
Hopefully I can get your new version ASAP.
xiaozhu557
#9 Unread post by xiaozhu557 »
arango wrote:I assume that you already know that all input files need to be NetCDF4 (HDF5) type files. Also, all output files are the NetCDF4 type.
Hello, Arango, would you like to let me know once you have updated and uploaded the code for the MPI communications?
Thanks a lot.
fabeobd
#10 Unread post by fabeobd »
I'm facing this bug and wondering if any fix has been done at this point?
Fabio
Fabio Boeira Dias, PhD
Postdoctoral researcher
Climate Change Research Centre (CCRC)
University of New South Wales
fabeobd
#11 Unread post by fabeobd »
I've figured out this bug which seems to be fixed in newer versions (I'm using a branch of ROMS 3.6). For documentation in case anyone face this bug in the future, the mp_collect call should be placed before the Jstr,Jend/Istr,Iend loop that calculates Awrk (around line 345), and not after as I have in my nf_fread2d.F code. Model compiled and run fine after this, which improved significantly the speed of input reading.
Fabio
xiaozhu557
#12 Unread post by xiaozhu557 »
Thank you for your reply, Fabio.
It looks like the same for my copy with yours, after changed. It is as followed,
IF (interpolate) THEN
            CALL mp_collect (ng, model, Npts, IniVal, wrk)
            ic=0
            DO j=Jstr,Jend
              DO i=Istr,Iend
                ic=ic+1
                Awrk(i,j)=wrk(ic)
          ELSE
Is it the same with your new version?
If your version can work, would you like to provide the files distribute.F and nf_fread2d.F? Your fixing looks like not the case of mine. For my question, it is the different shape of array between A and Awrk.
Thanks again.
#13 Unread post by arango »
I can believe that this is done :shock: We are not responsible for corrections to the code by a third party. Your solution is straightforward. Update your code from the official ROMS repositories. The agreement to receive a freely distributed version of the ROMS framework from us is that Users need to keep their code up to date . I highly suggest that you read the term of the :arrow: agreement.
fabeobd
#14 Unread post by fabeobd »
Hi Xiau,
The error I initially got was the same you described in your first post:
"nf_fread2d.f90(314): error #6285: There is no matching specific subroutine for this generic subroutine call. [MP_COLLECT]"
Just changing the place where mp_collect is called fixed that (exactly as you posted). I got that by comparing the the code I'm using with the latest available. I didn't changed anything in the distribute.F. If you can't update your code as Arango suggested, I would advice you to compare files individually between your code and the latest one.
Arango, I understand the term of the agreement and would like to keep my code updated, but it seems a quite painful route in some cases. When I started my current project (Antarctic ocean-ice sheet modelling) earlier this year, I got a ROMS setup from my collaborators at University of Tasmania, which is based on ROMS 3.6 with modifications for the ice sheet coupling. They got the latest ROMS version when they starting developing the model (in 2016), but they didn't update it with the main branch in the subsequent years. I guess that is a common approach in several institutions - I have been worked with MOM previously and have seen people using different versions as they include mods for specific purposes. If I now try to merge versions it shows several hundreds of code changes, so sometimes update the code is not so straightforward.
Fabio
#15 Unread post by arango »
Well, you cannot pick and choose what routines you need to update. It doesn't work that way. Every change done to ROMS is well documented in the trac system, and the changes sometimes depend on previous changes and may be modified in future changes. The last major update to the Parallel I/O was done in :arrow: track ticket 747 on Oct 5, 2017. In that update, 38 files were modified. And many more changes have done to some of those files in the last three years. ROMS is available in both svn and git repositories. You don't need to make such changes by hand. You can introduce bugs to the code that will be a nightmare to fix, and we are not responsible for those. There are ways for branching in svn and git and resolve conflicts in the third party features that are not part of our distributed version.
You can check trac and all the changes and differences that have been made to ROMS since the base version of the code that you are using. It will take some time. There are various important changes to the ROMS kernels.
fabeobd
#16 Unread post by fabeobd »
Hi Arango,
thanks for your suggestions. The approach in compare versions of a single file was only in an attempt to diagnose the crash during the compilation with the PARALLEL_IO. I would very much like to update the code I'm currently using, if there is a doable route. I did a similar question a few months back (viewtopic.php?f=14&t=5447) and I ended up just using the code I have. But without doubt would be better to have it aligned with the newest developments. Which steps would you suggest in my case to resolve the conflicts from third party features?
Cheers
Fabio
#17 Unread post by kate »
I suggest learning about git. You can have a git repo with (a) the old ROMS you started from (b) the old ROMS with your modifications and (c) new ROMS. Or the crude thing to do is diff old ROMS vs. your code and save those diffs to a file. Then apply those changes to the new ROMS by hand. I assume that patch will fail after all the intervening ROMS changes, same with git merge.
#18 Unread post by arango »
Everybody has their own procedure for updating code from repositories. I have several research repositories, and I usually do the following steps:
  • Copy the version that I want to update to a temporary one. So, I have a version of the code that works in case something goes wrong with the updating. I also use the old version to benchmark the old code against the new code. I compare the old and new solutions
  • I get a scope of the changes by comparing old and new versions of the code in the KDiff3 tool. I highly recommend users interested in developing code to install KDiff3. It is the best tool for comparing codes in a tree directory structure. It is free.
  • Update the code with svn (svn update) or git (git pull). I am much better and experienced with svn.
  • Resolve the merging conflicts with your favorite text editor. I have been using Xemacs since I was a graduate student. It has wonderful tools for comparing files line-by-line and correcting/merging the desired lines of code. The differences are all color-coded.
Good luck
fabeobd
#19 Unread post by fabeobd »
Hi Kate and Arango,
many thanks for your suggestions. I do use git but I'm more on the newby side - I think that's a great incentive to learn it in details. Thanks for indicating the KDiff3, it does look an amazing tool. I usually use vimdiff to compare files and it's also color-code, which is handy. I going to give a try in merging the codes, and hope it's not so difficult as I was thinking.
Fabio
