Forcing file request after including ana_passive
salik
#1 Unread post by salik »
I am trying to add a passive tracer to a modified seamount set up. I have changed the boundary conditions to get a westward flowing current, and now I want to add a passive tracer to part of my domain, to see what happens to the water above the sea mount (or sea hill, in this case).
I set my tracer concentrations in ana_passive, which I copied into an Inc directory in my project dir, and set the OBC for the passive tracer to periodic in ocean.in.
Now, when I run the model, I get this output:
 Model Input Parameters:  ROMS/TOMS version 3.7
                          Monday - May 29, 2017 -  3:51:54 PM
 Tall Isolated Seamount Test
 Operating system : Linux
 CPU/hardware     : x86_64
 Compiler system  : gfortran
 Compiler command : /usr/local/bin/mpif90
 Compiler flags   : -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
 Input Script  :
 SVN Root URL  : https://www.myroms.org/svn/src/trunk
 SVN Revision  : 802M
 Local Root    : /home/nws747/trunk
 Header Dir    : /home/nws747/seamount/Inc
 Header file   : seamount.h
 Analytical Dir: /home/nws747/seamount/Inc
 Resolution, Grid 01: 0049x0048x013,  Parallel Nodes:   1,  Tiling: 001x001
     259200  ntimes            Number of timesteps for 3-D equations.
     60.000  dt                Timestep size (s) for 3-D equations.
         20  ndtfast           Number of timesteps for 2-D equations between
          1  ERstr             Starting ensemble/perturbation run number.
          1  ERend             Ending ensemble/perturbation run number.
          0  nrrec             Number of restart records to read from disk.
          T  LcycleRST         Switch to recycle time-records in restart file.
      14400  nRST              Number of timesteps between the writing of data
                                 into restart fields.
          1  ninfo             Number of timesteps between print of information
                                 to standard output.
          T  ldefout           Switch to create a new output NetCDF file(s).
       1440  nHIS              Number of timesteps between the writing fields
                                 into history file.
 0.0000E+00  nl_tnu2(01)       NLM Horizontal, harmonic mixing coefficient
                                 (m2/s) for tracer 01: temp
 0.0000E+00  nl_tnu2(02)       NLM Horizontal, harmonic mixing coefficient
                                 (m2/s) for tracer 02: dye_01
 0.0000E+00  nl_visc2          NLM Horizontal, harmonic mixing coefficient
                                 (m2/s) for momentum.
          F  LuvSponge         Turning OFF sponge on horizontal momentum.
          F  LtracerSponge(01) Turning OFF sponge on tracer 01: temp
          F  LtracerSponge(02) Turning OFF sponge on tracer 02: dye_01
 1.0000E-06  Akt_bak(01)       Background vertical mixing coefficient (m2/s)
 1.0000E-06  Akt_bak(02)       Background vertical mixing coefficient (m2/s)
 1.0000E-05  Akv_bak           Background vertical mixing coefficient (m2/s)
 3.0000E-04  rdrg              Linear bottom drag coefficient (m/s).
 3.0000E-03  rdrg2             Quadratic bottom drag coefficient.
 2.0000E-02  Zob               Bottom roughness (m).
          2  Vtransform        S-coordinate transformation equation.
          4  Vstretching       S-coordinate stretching function.
 6.5000E+00  theta_s           S-coordinate surface control parameter.
 2.0000E+00  theta_b           S-coordinate bottom  control parameter.
    100.000  Tcline            S-coordinate surface/bottom layer width (m) used
   1025.000  rho0              Mean density (kg/m3) for Boussinesq approximation.
      0.000  dstart            Time-stamp assigned to model initialization (days).
       0.00  time_ref          Reference time for units attribute (yyyymmdd.dd)
 0.0000E+00  Tnudg(01)         Nudging/relaxation time scale (days)
 0.0000E+00  Tnudg(02)         Nudging/relaxation time scale (days)
 0.0000E+00  Znudg             Nudging/relaxation time scale (days)
 0.0000E+00  M2nudg            Nudging/relaxation time scale (days)
 0.0000E+00  M3nudg            Nudging/relaxation time scale (days)
                                 for 3D momentum.
 0.0000E+00  obcfac            Factor between passive and active
          F  VolCons(1)        NLM western  edge boundary volume conservation.
          F  VolCons(2)        NLM southern edge boundary volume conservation.
          F  VolCons(3)        NLM eastern  edge boundary volume conservation.
          F  VolCons(4)        NLM northern edge boundary volume conservation.
     10.000  T0                Background potential temperature (C) constant.
     32.000  S0                Background salinity (PSU) constant.
   1027.000  R0                Background density (kg/m3) used in linear Equation
                                 of State.
 1.7000E-04  Tcoef             Thermal expansion coefficient (1/Celsius).
 7.6000E-04  Scoef             Saline contraction coefficient (1/PSU).
     -1.000  gamma2            Slipperiness variable: free-slip (1.0) or
          F  LuvSrc            Turning OFF momentum point Sources/Sinks.
          F  LwSrc             Turning OFF volume influx point Sources/Sinks.
          F  LtracerSrc(01)    Turning OFF point Sources/Sinks on tracer 01: temp
          F  LtracerSrc(02)    Turning OFF  point Sources/Sinks on tracer 02: dye_01
          F  LsshCLM           Turning OFF processing of SSH climatology.
          F  Lm2CLM            Turning OFF processing of 2D momentum climatology.
          F  Lm3CLM            Turning OFF processing of 3D momentum climatology.
          F  LtracerCLM(01)    Turning OFF processing of climatology tracer 01: temp
          F  LtracerCLM(02)    Turning OFF processing of climatology tracer 02: dye_01
          F  LnudgeM2CLM       Turning OFF nudging of 2D momentum climatology.
          F  LnudgeM3CLM       Turning OFF nudging of 3D momentum climatology.
          F  LnudgeTCLM(01)    Turning OFF nudging of climatology tracer 01: temp
          F  LnudgeTCLM(02)    Turning OFF nudging of climatology tracer 02: dye_01
          T  Hout(idFsur)      Write out free-surface.
          T  Hout(idUbar)      Write out 2D U-momentum component.
          T  Hout(idVbar)      Write out 2D V-momentum component.
          T  Hout(idUvel)      Write out 3D U-momentum component.
          T  Hout(idVvel)      Write out 3D V-momentum component.
          T  Hout(idWvel)      Write out W-momentum component.
          T  Hout(idOvel)      Write out omega vertical velocity.
          T  Hout(idTvar)      Write out tracer 01: temp
          T  Hout(inert)       Write out inert passive tracer 01: dye_01
             Output Restart File:  output/50passive_rst.nc
             Output History File:  output/50passive_his.nc
 Tile partition information for Grid 01:  0049x0048x0013  tiling: 001x001
        0        1       49        1       48    30576
   (interior points only)
        0     0.50    49.50     0.50    48.50  RHO-points
        0     1.00    49.00     0.50    48.50    U-points
        0     0.50    49.50     1.00    48.00    V-points
               HaloSizeI(1) =     186
               HaloSizeJ(1) =     177
                TileSide(1) =      56
                TileSize(1) =    2968
 zeta                     1   Chapman Imp  Closed       Chapman Imp  Closed
 ubar                     1   Flather      Closed       Clamped      Closed
 vbar                     1   Flather      Closed       Clamped      Closed
 u                        1   Rad + Nud    Closed       Clamped      Closed
 v                        1   Rad + Nud    Closed       Clamped      Closed
 temp                     1   Periodic     Closed       Periodic     Closed
 dye_01                   1   Periodic     Closed       Periodic     Closed
 SEAMOUNT            Tall Isolated Seamount Test
 ANA_DIAG            Customized diagnostics.
 ANA_FSOBC           Analytical free-surface boundary conditions.
 ANA_GRID            Analytical grid set-up.
 ANA_INITIAL         Analytical initial conditions.
 ANA_M2OBC           Analytical 2D momentum boundary conditions.
 ANA_M3OBC           Analytical 3D momentum boundary conditions.
 ANA_PASSIVE         Analytical initial conditions for inert tracers.
 ANA_SMFLUX          Analytical kinematic surface momentum flux.
 ANA_STFLUX          Analytical kinematic surface temperature flux.
 DEBUGGING           Internal debugging switch activated.
 MIX_GEO_TS          Mixing of tracers along geopotential surfaces.
 !NONLIN_EOS         Linear Equation of State for seawater.
 SPLINES_VDIFF       Parabolic Spline Reconstruction for Vertical Diffusion.
 SPLINES_VVISC       Parabolic Spline Reconstruction for Vertical Viscosity.
 T_PASSIVE           Advecting and diffusing inert passive tracer.
 TS_A4HADVECTION     Fourth-order Akima horizontal advection of tracers.
 TS_A4VADVECTION     Fourth-order Akima vertical advection of tracers.
 TS_DIF2             Harmonic mixing of tracers.
 Process Information:
 Node #  0 (pid=     538) is active.
 level   S-coord     Cs-curve   Z   at hmin       at hc    half way     at hmax
    13   0.0000000   0.0000000        0.000       0.000       0.000       0.000
    12  -0.0769231  -0.0008900       -5.656      -3.891      -5.822      -5.969
    11  -0.1538462  -0.0037823      -11.670      -7.881     -12.047     -12.389
    10  -0.2307692  -0.0093960      -18.171     -12.008     -18.822     -19.422
     9  -0.3076923  -0.0191094      -25.405     -16.340     -26.425     -27.377
     8  -0.3846154  -0.0352542      -33.790     -20.993     -35.325     -36.778
     7  -0.4615385  -0.0615570      -43.992     -26.155     -46.276     -48.466
     6  -0.5384615  -0.1036895      -57.026     -32.108     -60.421     -63.715
     5  -0.6153846  -0.1697046      -74.332     -39.254     -79.387     -84.337
     4  -0.6923077  -0.2696632      -97.710     -48.099    -105.203    -112.597
     3  -0.7692308  -0.4128642     -128.824     -59.105    -139.747    -150.587
     2  -0.8461538  -0.6002708     -167.845     -72.321    -183.213    -198.522
     1  -0.9230769  -0.8118860     -211.198     -86.748    -231.564    -251.905
     0  -1.0000000  -1.0000000     -250.346    -100.000    -275.173    -300.000
 Time Splitting Weights for Grid 01:    ndtfast =  20    nfast =  29
  3-0.0011514592651644 0.0501156998674241-0.0034654566136460 0.1501639558342180
  4-0.0003735756740661 0.0501732728306823-0.0038390322877122 0.2003372286649003
  5 0.0009829200513762 0.0501919516143856-0.0028561122363360 0.2505291802792859
  6 0.0029141799764308 0.0501428056118168 0.0000580677400949 0.3006719858911027
  7 0.0054132615310267 0.0499970966129953 0.0054713292711215 0.3506690825040980
  8 0.0084687837865133 0.0497264335364439 0.0139401130576348 0.4003955160405419
  9 0.0120633394191050 0.0493029943471183 0.0260034524767398 0.4496985103876601
 10 0.0161716623600090 0.0486998273761630 0.0421751148367488 0.4983983377638231
 11 0.0207585511322367 0.0478912442581626 0.0629336659689855 0.5462895820219857
 12 0.0257765478740990 0.0468533167015507 0.0887102138430846 0.5931428987235364
 13 0.0311633730493853 0.0455644893078458 0.1198735868924699 0.6387073880313822
 14 0.0368391158442262 0.0440063206553765 0.1567127027366961 0.6827137086867586
 15 0.0427031802506397 0.0421643648631652 0.1994158829873358 0.7248780735499238
 16 0.0486309868367616 0.0400292058506332 0.2480468698240974 0.7649072794005570
 17 0.0544704302037592 0.0375976565087951 0.3025173000278565 0.8025049359093521
 18 0.0600380921294286 0.0348741349986072 0.3625553921572851 0.8373790709079593
 19 0.0651152103984763 0.0318722303921357 0.4276706025557614 0.8692513013000950
 20 0.0694434033194839 0.0286164698722119 0.4971140058752453 0.8978677711723069
 21 0.0727201499285570 0.0251442997062377 0.5698341558038023 0.9230120708785446
 22 0.0745940258796570 0.0215082922098099 0.6444281816834592 0.9445203630883545
 23 0.0746596950216179 0.0177785909158270 0.7190878767050771 0.9622989540041815
 24 0.0724526566618460 0.0140456061647461 0.7915405333669231 0.9763445601689277
 25 0.0674437485167025 0.0104229733316538 0.8589842818836255 0.9867675335005816
 26 0.0590334053485720 0.0070507859058187 0.9180176872321975 0.9938183194064003
 27 0.0465456732896125 0.0040991156383901 0.9645633605218099 0.9979174350447905
 28 0.0292219798521905 0.0017718319739095 0.9937853403740003 0.9996892670187000
 29 0.0062146596259993 0.0003107329813000 0.9999999999999997 1.0000000000000000
 ndtfast, nfast =   20  29   nfast/ndtfast =  1.45000
 Power filter parameters, Fgamma, gamma =  0.28400   0.14200
 Minimum X-grid spacing, DXmin =  6.53061224E+00 km
 Maximum X-grid spacing, DXmax =  6.53061224E+00 km
 Minimum Y-grid spacing, DYmin =  6.66666667E+00 km
 Maximum Y-grid spacing, DYmax =  6.66666667E+00 km
 Minimum Z-grid spacing, DZmin =  5.65588275E+00 m
 Maximum Z-grid spacing, DZmax =  5.33826473E+01 m
 Minimum barotropic Courant Number =  3.18680830E-02
 Maximum barotropic Courant Number =  3.48856020E-02
 Maximum Coriolis   Courant Number =  6.00000000E-03
               ocean_frc.nc
               call from:  inquire.F
 Elapsed CPU time (seconds):
 Node   #  0 CPU:       0.010
 Total:                 0.010
 Nonlinear model elapsed time profile, Grid: 01
  Allocation and array initialization ..............         0.006  (61.5515 %)
  2D/3D coupling, vertical metrics .................         0.001  ( 7.3591 %)
  Equation of state for seawater ...................         0.000  ( 3.6845 %)
                                              Total:         0.007   72.5951
  Message Passage: 2D halo exchanges ...............         0.000  ( 0.8962 %)
  Message Passage: data reduction ..................         0.000  ( 0.0896 %)
                                              Total:         0.000    0.9859
 All percentages are with respect to total time =            0.010
 Analytical header files used:
     /home/nws747/seamount/Inc/ana_grid.h
     /home/nws747/seamount/Inc/ana_initial.h
     /home/nws747/seamount/Inc/ana_passive.h
 ROMS/TOMS - Output error ............ exit_flag:   3
 REASON: No such file or directory
where I'm basically asked for a forcing file, even though I have set all forcing analytically. The same setup works when ana_passive is disables, and all ana_* files specified in preprocessing are used. Here, however, it doesn't seem to use any other files than ana_grid, ana_initial and ana_passive, which I suppose is the reason it asks for a forcing file, but why doesn't it read those files?
I can't find any reason for this - is it a known issue? Or does anyone have a suggestion for what might be wrong?
Re: Forcing file request after including ana_passive
You need these as well:
# define ANA_BPFLUX /* analytical bottom passive tracers fluxes */
# define ANA_SPFLUX
salik
#3 Unread post by salik »
# define ANA_SPFLUX
Of course, that makes sense. Thank you!
