I set my tracer concentrations in ana_passive, which I copied into an Inc directory in my project dir, and set the OBC for the passive tracer to periodic in ocean.in.
Now, when I run the model, I get this output:
Monday - May 29, 2017 - 3:51:54 PM
Tall Isolated Seamount Test
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler command : /usr/local/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
Input Script :
SVN Revision : 802M
Local Root : /home/nws747/trunk
Header Dir : /home/nws747/seamount/Inc
Header file : seamount.h
Analytical Dir: /home/nws747/seamount/Inc
Resolution, Grid 01: 0049x0048x013, Parallel Nodes: 1, Tiling: 001x001
259200 ntimes Number of timesteps for 3-D equations.
60.000 dt Timestep size (s) for 3-D equations.
14400 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
1440 nHIS Number of timesteps between the writing fields
into history file.
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: dye_01
0.0000E+00 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
F LtracerSponge(02) Turning OFF sponge on tracer 02: dye_01
6.5000E+00 theta_s S-coordinate surface control parameter.
2.0000E+00 theta_b S-coordinate bottom control parameter.
100.000 Tcline S-coordinate surface/bottom layer width (m) used
for 3D momentum.
32.000 S0 Background salinity (PSU) constant.
of State.
F LtracerSrc(02) Turning OFF point Sources/Sinks on tracer 02: dye_01
F LtracerCLM(02) Turning OFF processing of climatology tracer 02: dye_01
F LnudgeTCLM(02) Turning OFF nudging of climatology tracer 02: dye_01
T Hout(inert) Write out inert passive tracer 01: dye_01
Output Restart File: output/50passive_rst.nc
Output History File: output/50passive_his.nc
Tile partition information for Grid 01: 0049x0048x0013 tiling: 001x001
tile Istr Iend Jstr Jend Npts
0 1 49 1 48 30576
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 49.50 0.50 48.50 RHO-points
0 1.00 49.00 0.50 48.50 U-points
0 0.50 49.50 1.00 48.00 V-points
HaloSizeI(1) = 186
HaloSizeJ(1) = 177
TileSide(1) = 56
TileSize(1) = 2968
zeta 1 Chapman Imp Closed Chapman Imp Closed
ubar 1 Flather Closed Clamped Closed
vbar 1 Flather Closed Clamped Closed
u 1 Rad + Nud Closed Clamped Closed
v 1 Rad + Nud Closed Clamped Closed
dye_01 1 Periodic Closed Periodic Closed
SEAMOUNT Tall Isolated Seamount Test
ANA_DIAG Customized diagnostics.
ANA_M3OBC Analytical 3D momentum boundary conditions.
ANA_PASSIVE Analytical initial conditions for inert tracers.
DEBUGGING Internal debugging switch activated.
NONLINEAR Nonlinear Model.
T_PASSIVE Advecting and diffusing inert passive tracer.
TS_A4HADVECTION Fourth-order Akima horizontal advection of tracers.
TS_A4VADVECTION Fourth-order Akima vertical advection of tracers.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
Node # 0 (pid= 538) is active.
13 0.0000000 0.0000000 0.000 0.000 0.000 0.000
12 -0.0769231 -0.0008900 -5.656 -3.891 -5.822 -5.969
11 -0.1538462 -0.0037823 -11.670 -7.881 -12.047 -12.389
10 -0.2307692 -0.0093960 -18.171 -12.008 -18.822 -19.422
9 -0.3076923 -0.0191094 -25.405 -16.340 -26.425 -27.377
8 -0.3846154 -0.0352542 -33.790 -20.993 -35.325 -36.778
7 -0.4615385 -0.0615570 -43.992 -26.155 -46.276 -48.466
6 -0.5384615 -0.1036895 -57.026 -32.108 -60.421 -63.715
5 -0.6153846 -0.1697046 -74.332 -39.254 -79.387 -84.337
4 -0.6923077 -0.2696632 -97.710 -48.099 -105.203 -112.597
3 -0.7692308 -0.4128642 -128.824 -59.105 -139.747 -150.587
2 -0.8461538 -0.6002708 -167.845 -72.321 -183.213 -198.522
1 -0.9230769 -0.8118860 -211.198 -86.748 -231.564 -251.905
0 -1.0000000 -1.0000000 -250.346 -100.000 -275.173 -300.000
Time Splitting Weights for Grid 01: ndtfast = 20 nfast = 29
3-0.0011514592651644 0.0501156998674241-0.0034654566136460 0.1501639558342180
4-0.0003735756740661 0.0501732728306823-0.0038390322877122 0.2003372286649003
6 0.0029141799764308 0.0501428056118168 0.0000580677400949 0.3006719858911027
7 0.0054132615310267 0.0499970966129953 0.0054713292711215 0.3506690825040980
8 0.0084687837865133 0.0497264335364439 0.0139401130576348 0.4003955160405419
9 0.0120633394191050 0.0493029943471183 0.0260034524767398 0.4496985103876601
10 0.0161716623600090 0.0486998273761630 0.0421751148367488 0.4983983377638231
11 0.0207585511322367 0.0478912442581626 0.0629336659689855 0.5462895820219857
12 0.0257765478740990 0.0468533167015507 0.0887102138430846 0.5931428987235364
13 0.0311633730493853 0.0455644893078458 0.1198735868924699 0.6387073880313822
14 0.0368391158442262 0.0440063206553765 0.1567127027366961 0.6827137086867586
15 0.0427031802506397 0.0421643648631652 0.1994158829873358 0.7248780735499238
16 0.0486309868367616 0.0400292058506332 0.2480468698240974 0.7649072794005570
17 0.0544704302037592 0.0375976565087951 0.3025173000278565 0.8025049359093521
18 0.0600380921294286 0.0348741349986072 0.3625553921572851 0.8373790709079593
19 0.0651152103984763 0.0318722303921357 0.4276706025557614 0.8692513013000950
20 0.0694434033194839 0.0286164698722119 0.4971140058752453 0.8978677711723069
21 0.0727201499285570 0.0251442997062377 0.5698341558038023 0.9230120708785446
22 0.0745940258796570 0.0215082922098099 0.6444281816834592 0.9445203630883545
23 0.0746596950216179 0.0177785909158270 0.7190878767050771 0.9622989540041815
24 0.0724526566618460 0.0140456061647461 0.7915405333669231 0.9763445601689277
25 0.0674437485167025 0.0104229733316538 0.8589842818836255 0.9867675335005816
26 0.0590334053485720 0.0070507859058187 0.9180176872321975 0.9938183194064003
27 0.0465456732896125 0.0040991156383901 0.9645633605218099 0.9979174350447905
28 0.0292219798521905 0.0017718319739095 0.9937853403740003 0.9996892670187000
29 0.0062146596259993 0.0003107329813000 0.9999999999999997 1.0000000000000000
Minimum X-grid spacing, DXmin = 6.53061224E+00 km
Maximum X-grid spacing, DXmax = 6.53061224E+00 km
Minimum Y-grid spacing, DYmin = 6.66666667E+00 km
Maximum Y-grid spacing, DYmax = 6.66666667E+00 km
Minimum Z-grid spacing, DZmin = 5.65588275E+00 m
Maximum Z-grid spacing, DZmax = 5.33826473E+01 m
Minimum barotropic Courant Number = 3.18680830E-02
Maximum barotropic Courant Number = 3.48856020E-02
Maximum Coriolis Courant Number = 6.00000000E-03
ocean_frc.nc
call from: inquire.F
Node # 0 CPU: 0.010
Total: 0.010
Allocation and array initialization .............. 0.006 (61.5515 %)
2D/3D coupling, vertical metrics ................. 0.001 ( 7.3591 %)
Equation of state for seawater ................... 0.000 ( 3.6845 %)
Total: 0.007 72.5951
Message Passage: 2D halo exchanges ............... 0.000 ( 0.8962 %)
Message Passage: data reduction .................. 0.000 ( 0.0896 %)
Total: 0.000 0.9859
All percentages are with respect to total time = 0.010
Analytical header files used:
/home/nws747/seamount/Inc/ana_grid.h
/home/nws747/seamount/Inc/ana_initial.h
/home/nws747/seamount/Inc/ana_passive.h
REASON: No such file or directory
I can't find any reason for this - is it a known issue? Or does anyone have a suggestion for what might be wrong?
