The values related with viscosity/diffusivity
changjw214
#1 Unread post by changjw214 »
Hi friends~
I'm trying to make model using different two model(Delft 3d, ROMS)at same estuary, and compare the result.
for this,I want to change 4 things in ROMS(Horizontal eddy viscosity/diffusivity, Vertical eddy viscosity/diffusivity) to let same condition with Delft 3D.
I look into ocean.in, and know VISC= horizontal viscosity, Akv = vertical viscosity
Is it right?? and How about diffusivity??
Re: The values related with viscosity/diffusivity
You were in the right neighborhood of the ocean.in file:
        TNU2 == 0.0d0  0.0d0                    ! m2/s
        TNU4 == 2*0.0d0                         ! m4/s
     ad_TNU2 == 0.0d0  0.0d0                    ! m2/s
     ad_TNU4 == 0.0d0  0.0d0                    ! m4/s
       VISC2 == 5.0d0                           ! m2/s
       VISC4 == 0.0d0                           ! m4/s
    ad_VISC2 == 0.0d0                           ! m2/s
    ad_VISC4 == 0.0d0                           ! m4/s
For the vertical, these are the background values:
     AKT_BAK == 1.0d-6 1.0d-6                   ! m2/s
  ad_AKT_fac == 1.0d0  1.0d0                    ! nondimensional
     AKV_BAK == 1.0d-5                          ! m2/s
  ad_AKV_fac == 1.0d0                           ! nondimensional
Most models use some sort of parameterization, with names like Mellor-Yamada, Large et al., etc. Those are more complex, using both the cppdefs and ocean.in parameters (for GLS at least) to adjust.
