blowing up: Diag Speed Trouble
jitraporn13
#1 Unread post by jitraporn13 »
Dear All,
I'm trying to run ROMs by forcing with u,v,p components
It was blowing up since the beginning.
The error:
Diag Speed Trouble
Diag speed ijk
I don't know why the max speed is so big
Please help me to figure out the problem.
Thank you so much
Here is part of my log file
____________________________________________
3600 ntimes Number of timesteps for 3-D equations.
150.000 dt Timestep size (s) for 3-D equations.
5 ndtfast Number of timesteps for 2-D equations between
30 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
30 nHIS Number of timesteps between the writing fields
into history file.
into quicksave file.
for tracer 02: salt
for turbulent energy.
1.0000E+01 blk_ZQ Height (m) of surface air humidity measurement.
1.0000E+01 blk_ZT Height (m) of surface air temperature measurement.
1.0000E-01 Dcrit Minimum depth for wetting and drying (m).
0.0000E+00 theta_s S-coordinate surface control parameter.
1.0000E-01 theta_b S-coordinate bottom control parameter.
100.000 Tcline S-coordinate surface/bottom layer width (m) used
5844.000 dstart Time-stamp assigned to model initialization (days).
20000101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
for tracer 02: salt
9.0000E+01 Tnudg_SSS Nudging/relaxation time scale (days)
for sea surface salinity.
for 3D momentum.
Output Restart File: SE_rst.nc
Output History File: SE_his.nc
Input Grid File: ../../../easygrid_v2/SE_Asia_grd.nc
Input Nonlinear Initial File: ../../../easygrid_v2/SE_ASIA2_ini.nc
Input Forcing File 01: ../../../Documents/nesting/matlab/forcing/utest.nc
Input Forcing File 02: ../../../Documents/nesting/matlab/forcing/vtest.nc
Input Forcing File 03: ../../../Documents/nesting/matlab/forcing/ptest.nc
Input Forcing File 04: ../../../Documents/nesting/matlab/forcing/SE_Tair_era.nc
Input Forcing File 05: ../../../Documents/nesting/matlab/forcing/SE_Qair_era.nc
Input Forcing File 06: ../../../Documents/nesting/matlab/forcing/SE_lwrad_era.nc
Input Forcing File 07: ../../../Documents/nesting/matlab/forcing/SE_rain_era.nc
Tile partition information for Grid 01: 0258x0221x0030 tiling: 001x001
tile Istr Iend Jstr Jend Npts
Number of tracers: 2
0 1 258 1 221 1710540
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 259.50 0.50 221.50 RHO-points
0 0.00 259.00 0.50 221.50 U-points
0 0.50 259.50 0.00 221.00 V-points
zeta 1 Closed Closed Closed Closed
ubar 1 Closed Closed Closed Closed
vbar 1 Closed Closed Closed Closed
u 1 Closed Closed Closed Closed
v 1 Closed Closed Closed Closed
temp 1 Closed Closed Closed Closed
salt 1 Closed Closed Closed Closed
tke 1 Closed Closed Closed Closed
SE2 SE Asia
ANA_SRFLUX Analytical kinematic shortwave radiation flux.
BULK_FLUXES Surface bulk fluxes parameterization.
LIMIT_BSTRESS Limit bottom stress to maintain bottom velocity direction.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
OUT_DOUBLE Double precision output fields in NetCDF files.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
Thread # 0 (pid= 61980) is active.
30 0.0000000 0.0000000 0.000 0.000 0.000 0.000
29 -0.0333333 -0.0011675 -0.128 -1.725 -6.319 -9.585
28 -0.0666667 -0.0046693 -0.257 -3.567 -18.842 -31.790
27 -0.1000000 -0.0105031 -0.386 -5.525 -37.563 -66.601
26 -0.1333333 -0.0186649 -0.516 -7.600 -62.470 -113.997
25 -0.1666667 -0.0291493 -0.646 -9.791 -93.550 -173.950
24 -0.2000000 -0.0419494 -0.776 -12.097 -130.784 -246.421
23 -0.2333333 -0.0570566 -0.906 -14.519 -174.150 -331.364
22 -0.2666667 -0.0744609 -1.037 -17.056 -223.620 -428.725
21 -0.3000000 -0.0941507 -1.168 -19.708 -279.164 -538.442
20 -0.3333333 -0.1161130 -1.300 -22.472 -340.748 -660.443
19 -0.3666667 -0.1403332 -1.432 -25.350 -408.332 -794.651
18 -0.4000000 -0.1667954 -1.564 -28.340 -481.874 -940.979
17 -0.4333333 -0.1954820 -1.697 -31.441 -561.329 -1099.333
16 -0.4666667 -0.2263742 -1.830 -34.652 -646.644 -1269.609
15 -0.5000000 -0.2594516 -1.963 -37.973 -737.768 -1451.699
14 -0.5333333 -0.2946926 -2.097 -41.401 -834.641 -1645.485
13 -0.5666667 -0.3320740 -2.231 -44.937 -937.202 -1850.842
12 -0.6000000 -0.3715715 -2.365 -48.579 -1045.387 -2067.639
11 -0.6333333 -0.4131593 -2.499 -52.325 -1159.128 -2295.736
10 -0.6666667 -0.4568104 -2.634 -56.174 -1278.352 -2534.987
9 -0.7000000 -0.5024966 -2.770 -60.125 -1402.984 -2785.239
8 -0.7333333 -0.5501882 -2.905 -64.176 -1532.946 -3046.333
7 -0.7666667 -0.5998546 -3.041 -68.326 -1668.156 -3318.103
6 -0.8000000 -0.6514640 -3.177 -72.573 -1808.530 -3600.376
5 -0.8333333 -0.7049834 -3.314 -76.916 -1953.980 -3892.975
4 -0.8666667 -0.7603786 -3.450 -81.352 -2104.415 -4195.714
3 -0.9000000 -0.8176145 -3.587 -85.881 -2259.741 -4508.404
2 -0.9333333 -0.8766550 -3.725 -90.499 -2419.864 -4830.850
1 -0.9666667 -0.9374628 -3.862 -95.206 -2584.684 -5162.850
0 -1.0000000 -1.0000000 -4.000 -100.000 -2754.099 -5504.199
Time Splitting Weights for Grid 01: ndtfast = 5 nfast = 7
1 0.0119306869089341 0.2000000000000000 0.0119306869089341 0.2000000000000000
2 0.0475049776008205 0.1976138626182131 0.0594356645097547 0.3976138626182131
3 0.1047629417620785 0.1881128670980491 0.1641986062718331 0.5857267297162622
4 0.1760826281731955 0.1671602787456334 0.3402812344450286 0.7528870084618955
5 0.2416469636634478 0.1319437531109943 0.5819281981084765 0.8848307615728898
6 0.2602974116474964 0.0836143603783047 0.8422256097559728 0.9684451219511945
7 0.1577743902440273 0.0315548780488054 1.0000000000000000 0.9999999999999999
ndtfast, nfast = 5 7 nfast/ndtfast = 1.40000
1.000000000000 1.084198606272 0.542099303136 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.00000
Minimum X-grid spacing, DXmin = 1.50000000E+01 km
Maximum X-grid spacing, DXmax = 1.50000333E+01 km
Minimum Y-grid spacing, DYmin = 1.50000000E+01 km
Maximum Y-grid spacing, DYmax = 1.55908600E+01 km
Minimum Z-grid spacing, DZmin = 1.28384748E-01 m
Maximum Z-grid spacing, DZmax = 3.41348659E+02 m
Minimum barotropic Courant Number = 1.94485509E-02
Maximum barotropic Courant Number = 6.57079840E-01
Maximum Coriolis Courant Number = 9.20089964E-03
NLM: GET_STATE - Read state initial conditions, t = 5844 00:00:00
(Grid 01, File: SE_ASIA2_ini.nc, Rec=0001, Index=1)
- free-surface
- u-momentum component
- v-momentum component
- potential temperature
(Min = 9.00000000E+00 Max = 9.00000000E+00)
- salinity
(Min = 3.00000000E+01 Max = 3.00000000E+01)
GET_2DFLD - surface u-wind component, t = 5844 00:00:00
(Rec=0000001, Index=1, File: utest.nc)
(Tmin= 5844.0000 Tmax= 5875.0000)
(Min = -1.22636754E+01 Max = 4.81609346E+00)
GET_2DFLD - surface v-wind component, t = 5844 00:00:00
(Rec=0000001, Index=1, File: vtest.nc)
(Min = -1.21289526E+01 Max = 3.68782660E+00)
GET_2DFLD - surface air pressure, t = 5844 00:00:00
(Rec=0000001, Index=1, File: ptest.nc)
(Min = 1.01185653E+01 Max = 1.03030460E+01)
GET_2DFLD - surface air temperature, t = 5844 00:00:00
(Rec=0000001, Index=1, File: SE_Tair_era.nc)
(Min = 2.56414107E+03 Max = 2.08692103E+04)
GET_2DFLD - surface air relative humidity, t = 5844 00:00:00
(Rec=0000001, Index=1, File: SE_Qair_era.nc)
(Min = 5.00000000E+01 Max = 5.00000000E+01)
GET_2DFLD - net longwave radiation flux, t = 5843 22:30:00
(Rec=0000001, Index=1, File: SE_lwrad_era.nc)
(Tmin= 5843.9375 Tmax= 5874.9375)
(Min = 6.78818394E-07 Max = 7.42758226E-07)
GET_2DFLD - rain fall rate, t = 5843 22:30:00
(Rec=0000001, Index=1, File: SE_rain_era.nc)
(Min = -2.73776874E+00 Max = -1.20218290E+00)
Maximum grid stiffness ratios: rx0 = 9.496374E-01 (Beckmann and Haidvogel)
rx1 = 3.049303E+01 (Haney)
Initial basin volumes: TotVolume = 1.3989106538E+16 m3
MinVolume = 3.4621784284E+07 m3
MaxVolume = 7.6841808058E+10 m3
Max/Min = 2.2194641220E+03
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00003600)
GET_2DFLD - surface u-wind component, t = 5844 12:00:00
(Rec=0000002, Index=2, File: utest.nc)
(Min = -1.19747591E+01 Max = 3.37829314E+00)
GET_2DFLD - surface v-wind component, t = 5844 12:00:00
(Rec=0000002, Index=2, File: vtest.nc)
(Min = -1.27883484E+01 Max = 2.67607881E+00)
GET_2DFLD - surface air pressure, t = 5844 12:00:00
(Rec=0000002, Index=2, File: ptest.nc)
(Min = 1.01103045E+01 Max = 1.02726652E+01)
GET_2DFLD - surface air temperature, t = 5844 12:00:00
(Rec=0000002, Index=2, File: SE_Tair_era.nc)
(Min = 3.66556213E+03 Max = 2.04005658E+04)
GET_2DFLD - surface air relative humidity, t = 5844 12:00:00
(Rec=0000002, Index=2, File: SE_Qair_era.nc)
GET_2DFLD - net longwave radiation flux, t = 5844 10:30:00
(Rec=0000002, Index=2, File: SE_lwrad_era.nc)
(Min = -3.83092890E-08 Max = 6.42174955E-07)
GET_2DFLD - rain fall rate, t = 5844 10:30:00
(Rec=0000002, Index=2, File: SE_rain_era.nc)
(Min = -3.03388892E+03 Max = -2.52202799E+03)
0 5844 00:00:00 0.000000E+00 1.508919E+04 1.508919E+04 1.455726E+16
DEF_HIS - creating history file, Grid 01: SE_his.nc
WRT_HIS - wrote history fields (Index=1,1) in record = 0000001
1 5844 00:02:30 2.761005E+01 1.572569E+04 1.575330E+04 1.398958E+16
(104,113,30) 1.410010E+01 1.268761E+01 0.000000E+00 1.898574E+03
DIAG speed trouble 1898.5744590090233
DIAG speed ijk 1509.5531256078064 103 113 30 1
WRT_RST - wrote re-start fields (Index=2,2) in record = 0000001
Thread # 0 CPU: 121.579
Total: 121.579
Allocation and array initialization .............. 13.727 (11.2906 %)
Ocean state initialization ....................... 2.178 ( 1.7912 %)
Reading of input data ............................ 8.801 ( 7.2387 %)
Processing of input data ......................... 0.102 ( 0.0839 %)
Computation of vertical boundary conditions ...... 0.075 ( 0.0617 %)
Computation of global information integrals ...... 4.167 ( 3.4277 %)
Writing of output data ........................... 3.613 ( 2.9721 %)
Model 2D kernel .................................. 5.005 ( 4.1169 %)
2D/3D coupling, vertical metrics ................. 3.077 ( 2.5305 %)
Omega vertical velocity .......................... 1.427 ( 1.1735 %)
Equation of state for seawater ................... 7.637 ( 6.2814 %)
Atmosphere-Ocean bulk flux parameterization ...... 0.697 ( 0.5732 %)
GLS vertical mixing parameterization ............. 26.115 (21.4800 %)
3D equations right-side terms .................... 5.254 ( 4.3217 %)
3D equations predictor step ...................... 9.365 ( 7.7025 %)
Pressure gradient ................................ 5.271 ( 4.3356 %)
Corrector time-step for 3D momentum .............. 7.315 ( 6.0166 %)
Corrector time-step for tracers .................. 8.237 ( 6.7748 %)
Total: 112.062 92.1725
All percentages are with respect to total time = 121.579
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_srflux.h
ROMS/Functionals/ana_stflux.h
Re: blowing up: Diag Speed Trouble
It is at least telling you to look at point (i,j,k) = (103,113,30)
What units is your pressure in? ROMS wants something around 1000. Maybe you're using my varinfo.dat for converting from Pascals to millibars? Better check your Qair and Tair too.
