problem creating oceanM
adundunis
#1 Unread post by adundunis »
Hi everyone,
I was able to compile and create executables oceanS and oceanG with no problem. I edited my build.bash because I want to create oceanM and run parallel jobs.
I particularly changed the following in my build.bash:
1. I activated MPI in these parts
 export           USE_MPI=on            # distributed-memory parallelism
 export        USE_MPIF90=on            # compile with mpif90 script
 export         which_MPI=mpich         # compile with MPICH library
2. commented out the debugger and netcdf4 compiler
#export         USE_DEBUG=on            # use Fortran debugging flags
#export       USE_NETCDF4=on            # compile with NetCDF-4 library
3. changed the path in this part (in bold letters)
if [ -n "${USE_MPIF90:+1}" ]; then
case "$FORT" in
ifort )
if [ "${which_MPI}" = "mpich" ]; then
export PATH=/opt/intelsoft/mpich/bin:$PATH
elif [ "${which_MPI}" = "mpich2" ]; then
export PATH=/opt/intelsoft/mpich2/bin:$PATH
elif [ "${which_MPI}" = "openmpi" ]; then
export PATH=/opt/intelsoft/openmpi/bin:$PATH
fi
pgi )
export PATH=/usr/vimssw/pgi/mpich/bin:$PATH
export PATH=/opt/pgisoft/mpich2/bin:$PATH
export PATH=/opt/pgisoft/openmpi/bin:$PATH
fi
After I type
>> ./build.bash
it would execute the "compilation process" for a while but give the last two lines below indicating an error.
/usr/bin/ld: cannot find -lnetcdf
make: *** [/local/home/atgallentes/NAKDONG/Project1/oceanM] Error 2
Can someone enlighten me about this problem?
Also attached is a copy of my build.bash
Thank youuuu
build.bash (oceanM).rtf
(17.65 KiB) Downloaded 616 times
Re: problem creating oceanM
It's complaining about netcdf. Why did you turn off the NETCDF4 option? I would leave it on. Did you try with it on?
