ECMWF REGRID-input gridded data does not contain model grid
halftao1
#1 Unread post by halftao1 »
I used ecmwf2roms generated frc file and I'm sure it contain roms grid,but I meet this promble:
 REGRID - input gridded data does not contain model grid:
          Gridded:  LonMin =   92.7429 LonMax =  145.1310
                    LatMin =  -11.7679 LatMax =   46.1067
          Model:    LonMin =   91.5336 LonMax =  147.0130
                    LatMin =   -9.0343 LatMax =   43.0000
 GET_2DFLD   - error while reading variable: Uwind   at TIME index =       1
The model grid information is right.But wind file have wrong lon and lat.I check wind file many times :cry: ,it show in Attachments.
I used cpp SPHERICAL , but I don't know whether it work.
Can someone help me?
halftao1
Re: ECMWF REGRID-input gridded data does not contain model g
#2 Unread post by halftao1 »
OK,I get the reason.Because previously input path include pure number file , it return error.For test, I added another frc file.After modify get_varcoords.F,I finded the reason.
The Roms code is right.
Scarlett
#3 Unread post by Scarlett »
Hello everyone!
Like Ruiming wu I used ecmwf2roms generated forcing file.
I did my grid, and I used the grid lat and lon for create all my inputs files.
ymax=20.3070;
ymin=-10.3042;
xmax=-76.7665;
xmin=-130.9754;
But when I run my model, I get:
Gridded: LonMin = -140.0000 LonMax = -70.0000
LatMin = -10.0000 LatMax = 40.0000
Model: LonMin = -130.9754 LonMax = -76.7665
LatMin = -10.3043 LatMax = 20.3071
I have checked the size of my input files and they are all around these coordinates, with the exception of forcings. Although these files I set them the same coordinates in the ecmwf2roms, the files still have the coordinates that the original files (the ECMWF files I downloaded with lat 40 to -10 and lon -140 a -70 )
% Various parameters.
spherical = true;                       % Spherical switch
LonMin    = -130.9754;                     % GOM left-bottom longitude
LonMax    = -76.7665;                      % GOM right-top   longitude
LatMin    = -10.3042;                       % GOM left-bottom latitude
LatMax    = 20.3070;                       % GOM right-top   latitude
FlipLat   = true;                       % Flip data in ERA NetCDF files
                                        % (see below information)
% StrDay    = datenum('01-Jan-2000');     % starting day to process
% EndDay    = datenum('31-Dec-2011');     % ending   day to process
StrDay    = datenum('01-Jan-2001');     % starting day to process
EndDay    = datenum('31-Dec-2001');     % ending   day to process
I have been reading about this problem and for the most part the cause is that the files do not have the latitude and longitude information, but my files have them.
I don't know if I need change the get_varcoords.F and where...
I appreciate any help to solve this problem.
Scarlett Mar.Mo.
It looks like your model goes to 10.3 degrees south while you only gave it forcing down to 10 degrees south. Try giving it down to 11 south.
